  <title>CAD Forum discussion (EN) : Print in pdf</title>
  <description><![CDATA[This is an XML content feed of; CAD Forum discussion (EN) : AutoCAD : Print in pdf]]></description>
  <pubDate>Sun, 06 Sep 2026 17:22:39 +0000</pubDate>
  <lastBuildDate>Fri, 09 Dec 2011 10:29:27 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum_en/RSS_post_feed.asp?TID=6895</WebWizForums:feedURL>
   <title><![CDATA[Print in pdf : I&amp;#039;m totally agree with Vladimir...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=6895&amp;PID=18071&amp;title=print-in-pdf#18071</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=238194">Dandre</a><br /><strong>Subject:</strong> 6895<br /><strong>Posted:</strong> 09.Dec.2011 at 10:29<br /><br />I'm totally agree with Vladimir that higher Auto cad versions have direct output to pdf.You should be try other virtual pdf printer.Thanks for taking this opportunity to discuss this.<div><span style="font-size:12.0pt;font-family:"Arial","sans-serif";  mso-fareast-font-family:"Times New Roman";mso-fareast-theme-font:minor-fareast;  color:black;mso-themecolor:text1;mso-ansi-:EN-US;mso-fareast-:  EN-US;mso-bidi-:AR-SA"><br></span></div><div><font ="Apple-style-span" color="#000000" face="Arial, sans-serif" size="3"><br></font></div>]]>
   <pubDate>Fri, 09 Dec 2011 10:29:27 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=6895&amp;PID=18071&amp;title=print-in-pdf#18071</guid>
   <title><![CDATA[Print in pdf :  I&amp;#039;ve seen apps for printing...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=6895&amp;PID=17966&amp;title=print-in-pdf#17966</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=228382">cajunady</a><br /><strong>Subject:</strong> 6895<br /><strong>Posted:</strong> 29.Nov.2011 at 07:09<br /><br /><p ="ms&#111;normal"=""><span ="apple-style-span"=""><span style="font-size:8.0pt;  line-height:115%;font-family:" verdana","sans-serif";color:black;:="" #fafafa"="">I've seen apps for printing to real printers (PrintCentral) but Ihaven't owned a printer in five years. I always print everything from my Mac toa PDF (build in on a Mac) and I want to do the same on my iPad. If I ever needa hard copy I can print the PDF at work or a business center.</span><o:p></o:p></span></p><span style="font-size:10px"><br /><br />Edited by cajunady - 30.Nov.2011 at 07:32</span>]]>
   <pubDate>Tue, 29 Nov 2011 07:09:42 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=6895&amp;PID=17966&amp;title=print-in-pdf#17966</guid>
   <title><![CDATA[Print in pdf : You can try primopdf..its free...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=6895&amp;PID=17937&amp;title=print-in-pdf#17937</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=124949">CAD library</a><br /><strong>Subject:</strong> 6895<br /><strong>Posted:</strong> 26.Nov.2011 at 18:33<br /><br />You can try primopdf..its free download..]]>
   <pubDate>Sat, 26 Nov 2011 18:33:56 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=6895&amp;PID=17937&amp;title=print-in-pdf#17937</guid>
   <title><![CDATA[Print in pdf : Higher AutoCAD versions have direct...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=6895&amp;PID=17794&amp;title=print-in-pdf#17794</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=3">Vladimir Michl</a><br /><strong>Subject:</strong> 6895<br /><strong>Posted:</strong> 16.Nov.2011 at 10:17<br /><br />Higher AutoCAD versions have direct output to PDF. You can also try other virtual PDF printer.]]>
   <pubDate>Wed, 16 Nov 2011 10:17:54 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=6895&amp;PID=17794&amp;title=print-in-pdf#17794</guid>
   <title><![CDATA[Print in pdf : Go to layout. Next to model. Create...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=6895&amp;PID=17789&amp;title=print-in-pdf#17789</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=230939">freead</a><br /><strong>Subject:</strong> 6895<br /><strong>Posted:</strong> 15.Nov.2011 at 23:20<br /><br />Go to layout. Next to model. Create a rectangle of the size of the page in wich you will print your drawing. Then add 1 viewport (menu toolbar). you will need to select the rectangle that&nbsp;you created (remember the size must be i think in milimeters). after creating 1 viewport you double click inside it. Now to scale do this press z enter, and write 1000/100 xp and click enter. The drawing will be in 1:100. Hope you understand my reply. good luck<DIV>pd.: when yoy print it put 1:1 </DIV>]]>
   <pubDate>Tue, 15 Nov 2011 23:20:08 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=6895&amp;PID=17789&amp;title=print-in-pdf#17789</guid>
   <title><![CDATA[Print in pdf : I have Cad 2006 and i printed...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=6895&amp;PID=17787&amp;title=print-in-pdf#17787</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=23429">Ferna</a><br /><strong>Subject:</strong> 6895<br /><strong>Posted:</strong> 15.Nov.2011 at 19:02<br /><br /><P>I have Cad 2006 and i printed always in .pdf, I see the quality of the pdf&nbsp;print and it looks very blurry, Is there any option to improve the quality? TXS</P>]]>
   <pubDate>Tue, 15 Nov 2011 19:02:01 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=6895&amp;PID=17787&amp;title=print-in-pdf#17787</guid>
