  <title>CAD Forum discussion (EN) : Autocad Vs Revit</title>
  <description><![CDATA[This is an XML content feed of; CAD Forum discussion (EN) : AutoCAD : Autocad Vs Revit]]></description>
  <pubDate>Mon, 02 Nov 2026 16:25:42 +0000</pubDate>
  <lastBuildDate>Wed, 07 May 2008 02:42:44 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum_en/RSS_post_feed.asp?TID=709</WebWizForums:feedURL>
   <title><![CDATA[Autocad Vs Revit :  there is pros and con in both...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=709&amp;PID=1850&amp;title=autocad-vs-revit#1850</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=9671">gnowxed</a><br /><strong>Subject:</strong> 709<br /><strong>Posted:</strong> 07.May.2008 at 02:42<br /><br /><P>&nbsp;</P><P =Ms&#111;normal style="MARGIN: 0cm 0cm 0pt"><SPAN lang=EN style="FONT-SIZE: 9pt; mso-ansi-: EN"><FONT color=#000000><FONT face="Times New Roman">there is pros and con in both software. It will be good if they can combine both good capability together.</P><DIV><P =Ms&#111;normal style="MARGIN: 0cm 0cm 0pt"><?:namespace prefix = o ns = "urn:schemas-microsoft-com:office:office" /><o:p></o:p></FONT></FONT></SPAN></P><SPAN lang=EN style="FONT-SIZE: 9pt; mso-ansi-: EN"><FONT color=#000000><FONT face="Times New Roman">It will be like drawing using heaven drafting software.<o:p></o:p></FONT></FONT></SPAN></DIV><P>&nbsp;</P>]]>
   <pubDate>Wed, 07 May 2008 02:42:44 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=709&amp;PID=1850&amp;title=autocad-vs-revit#1850</guid>
   <title><![CDATA[Autocad Vs Revit : More than just referencing existing...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=709&amp;PID=1842&amp;title=autocad-vs-revit#1842</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=9717">Capone</a><br /><strong>Subject:</strong> 709<br /><strong>Posted:</strong> 06.May.2008 at 17:18<br /><br />More than just referencing existing drawings tho. I have literally hundreds of wall, door, window, cabinetry, structural members, etc... AEC objects and multi-view blocks that are created to the exact specs and textures of the actual product along with all of the property set data and BOM information for costing and schedules. I would really like to be able to bring that with me when I jump ship. <img src="https://www.cadforum.cz/forum_en/smileys/smiley24.gif" border="0" align="absmiddle" alt="Ermm" />&nbsp;]]>
   <pubDate>Tue, 06 May 2008 17:18:36 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=709&amp;PID=1842&amp;title=autocad-vs-revit#1842</guid>
   <title><![CDATA[Autocad Vs Revit : Yes, some AEC users still prefer...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=709&amp;PID=1839&amp;title=autocad-vs-revit#1839</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=3">Vladimir Michl</a><br /><strong>Subject:</strong> 709<br /><strong>Posted:</strong> 06.May.2008 at 16:09<br /><br />Yes, some AEC users still prefer AutoCAD-based tools for similar reasons.<DIV>&nbsp;</DIV><DIV>ad 1) you can still read/reference existing DWG details in Revit quite easily</DIV><DIV>&nbsp;</DIV><DIV>ad 2) right, utilities are harder to make in Revit (you do not need them so often in Revit but still...)</DIV><DIV>&nbsp;</DIV><DIV>ad 3) yes, for bi-directional communication it could be more pain; for exporting of&nbsp;plain DWG files (clean file, subset of layers), Revit could be paradoxically easier to use than AutoCAD Architecture</DIV><DIV>&nbsp;</DIV>]]>
   <pubDate>Tue, 06 May 2008 16:09:49 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=709&amp;PID=1839&amp;title=autocad-vs-revit#1839</guid>
   <title><![CDATA[Autocad Vs Revit : Well said Vladimir. There are...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=709&amp;PID=1836&amp;title=autocad-vs-revit#1836</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=9717">Capone</a><br /><strong>Subject:</strong> 709<br /><strong>Posted:</strong> 06.May.2008 at 15:38<br /><br />Well said Vladimir. <br><br>There are a few main reasons that I still prefer ACA or ADT over Revit:<br><br>1. I have a decade of details and drawings that I can still reference in AutoCAD and not have to completely start over. And along those lines I have created AEC objects that reflect the actual products that we use.<br><br>2. I have countless .vba and .lisp routines that save me a lot of time. Revit (at least when I initially looked into it) was not as versatile and harder to customize. <br><br>3. Compatibility. Most firms still use AutoCAD in some form or another. It's a pain when you can't effectively share information back and forth. I think Revit will get there eventually, but IMHO it's ot there yet for me.<br>]]>
   <pubDate>Tue, 06 May 2008 15:38:00 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=709&amp;PID=1836&amp;title=autocad-vs-revit#1836</guid>
   <title><![CDATA[Autocad Vs Revit : ... which is better - a humvee...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=709&amp;PID=1834&amp;title=autocad-vs-revit#1834</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=3">Vladimir Michl</a><br /><strong>Subject:</strong> 709<br /><strong>Posted:</strong> 06.May.2008 at 07:56<br /><br />... which is better - a humvee or a bulldozer?<DIV>&nbsp;</DIV><DIV>You can hardly compare a general purpose CAD application (AutoCAD) and a BIM architectural software (Revit).</DIV><DIV>&nbsp;</DIV><DIV>You could compare these two applications&nbsp;in AEC usage only&nbsp;- in AutoCAD (or rather AutoCAD Architecture - ADT) you can draw anything but it takes time and your learn curve is rather steep. In Revit, all you draw has to "make sense", drawing/modeling is easier and all schedules and tables are automatic (associative).</DIV>]]>
   <pubDate>Tue, 06 May 2008 07:56:03 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=709&amp;PID=1834&amp;title=autocad-vs-revit#1834</guid>
   <title><![CDATA[Autocad Vs Revit : Hi all,   Iknow all lot of...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=709&amp;PID=1832&amp;title=autocad-vs-revit#1832</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=9671">gnowxed</a><br /><strong>Subject:</strong> 709<br /><strong>Posted:</strong> 06.May.2008 at 00:41<br /><br />Hi all,<DIV>&nbsp;</DIV><DIV>&nbsp;</DIV><DIV>I&nbsp;know all lot of you have hear about revit-&nbsp; faster and better, while some still prefer Autocad.</DIV><DIV>so i was thinking to start a&nbsp;Topic &nbsp;to dicsuss all about it.</DIV><DIV>&nbsp;</DIV><DIV>&nbsp;</DIV>]]>
   <pubDate>Tue, 06 May 2008 00:41:23 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=709&amp;PID=1832&amp;title=autocad-vs-revit#1832</guid>
