  <title>CAD Forum discussion (EN) : hlsettings</title>
  <description><![CDATA[This is an XML content feed of; CAD Forum discussion (EN) : AutoCAD : hlsettings]]></description>
  <pubDate>Tue, 03 Nov 2026 02:00:08 +0000</pubDate>
  <lastBuildDate>Thu, 08 May 2008 22:45:07 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum_en/RSS_post_feed.asp?TID=716</WebWizForums:feedURL>
   <title><![CDATA[hlsettings : ... and Visual styles set different...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=716&amp;PID=1881&amp;title=hlsettings#1881</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=3">Vladimir Michl</a><br /><strong>Subject:</strong> 716<br /><strong>Posted:</strong> 08.May.2008 at 22:45<br /><br />... and Visual styles set different things than HLSETTINGS<span style="font-size:10px"><br /><br />Edited by Vladimir Michl - 08.May.2008 at 22:45</span>]]>
   <pubDate>Thu, 08 May 2008 22:45:07 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=716&amp;PID=1881&amp;title=hlsettings#1881</guid>
   <title><![CDATA[hlsettings : According to  THIS COMPARISON...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=716&amp;PID=1876&amp;title=hlsettings#1876</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=9717">Capone</a><br /><strong>Subject:</strong> 716<br /><strong>Posted:</strong> 08.May.2008 at 19:49<br /><br />According to <a href="http://www.rand.com/imaginit/1/pdfs/technology/software/autocad08_vs_autocadlt08_release_comparis&#111;n_matrix.pdf" target="_blank"> THIS COMPARISON MATRIX </a> Visual Styles are not supported in LT.]]>
   <pubDate>Thu, 08 May 2008 19:49:13 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=716&amp;PID=1876&amp;title=hlsettings#1876</guid>
   <title><![CDATA[hlsettings : Thanks, I appreciate the response....]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=716&amp;PID=1875&amp;title=hlsettings#1875</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=9974">baxter45</a><br /><strong>Subject:</strong> 716<br /><strong>Posted:</strong> 08.May.2008 at 19:15<br /><br /><P>Thanks, I appreciate the response.&nbsp; I tried the repair installation but I still can't get the dialog box.&nbsp; </P><P>The _visualstyles command doesn't work in AutoCad LT 2008.</P><P>I downloaded a LT drawing from a manufacturers website and as you went from view to view the hidden lines disappear.&nbsp; I can draw in 3D/Iso but I do not know enough about how to set my drawing up.&nbsp; When checking the objects in the downloaded drawings they are called a 'polygon mesh' in properties.</P><P>Thanks again for all your help!</P>]]>
   <pubDate>Thu, 08 May 2008 19:15:19 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=716&amp;PID=1875&amp;title=hlsettings#1875</guid>
   <title><![CDATA[hlsettings : _visualstylesThat brings up the...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=716&amp;PID=1873&amp;title=hlsettings#1873</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=9717">Capone</a><br /><strong>Subject:</strong> 716<br /><strong>Posted:</strong> 08.May.2008 at 18:57<br /><br />_visualstyles<br><br>That brings up the same dialog box.&nbsp; I have MEP 2008 so I'm not sure if LT has anything to do with it or not.<br>]]>
   <pubDate>Thu, 08 May 2008 18:57:02 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=716&amp;PID=1873&amp;title=hlsettings#1873</guid>
   <title><![CDATA[hlsettings : This command should work in LT....]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=716&amp;PID=1870&amp;title=hlsettings#1870</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=3">Vladimir Michl</a><br /><strong>Subject:</strong> 716<br /><strong>Posted:</strong> 08.May.2008 at 18:25<br /><br /><P>This command should work in LT. Try the repair installation, or the dialog may be dragged off-screen.</P><P>In any case, all settings from HLSETTINGS can be also set with the corresponding system variables.</P>]]>
   <pubDate>Thu, 08 May 2008 18:25:05 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=716&amp;PID=1870&amp;title=hlsettings#1870</guid>
   <title><![CDATA[hlsettings : I am using AutoCad 2008 LT an...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=716&amp;PID=1865&amp;title=hlsettings#1865</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=9974">baxter45</a><br /><strong>Subject:</strong> 716<br /><strong>Posted:</strong> 08.May.2008 at 16:13<br /><br />I am using AutoCad 2008 LT an have been trying to learn about the 'hlsettings' command.&nbsp; when I type the command nothing happens.<DIV>AutoCad help list the command but I do not get a dialog box as it says.</DIV><DIV>Can anyone help.</DIV>]]>
   <pubDate>Thu, 08 May 2008 16:13:25 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=716&amp;PID=1865&amp;title=hlsettings#1865</guid>
