  <title>CAD Forum discussion (EN) : Ticking overlapping objects</title>
  <description><![CDATA[This is an XML content feed of; CAD Forum discussion (EN) : AutoCAD : Ticking overlapping objects]]></description>
  <pubDate>Sat, 05 Sep 2026 03:56:27 +0000</pubDate>
  <lastBuildDate>Mon, 23 Jan 2012 01:31:23 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum_en/RSS_post_feed.asp?TID=7197</WebWizForums:feedURL>
   <title><![CDATA[Ticking overlapping objects : Glad that was it. There is a caveat...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=7197&amp;PID=18681&amp;title=ticking-overlapping-objects#18681</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=35918">heinsite</a><br /><strong>Subject:</strong> 7197<br /><strong>Posted:</strong> 23.Jan.2012 at 01:31<br /><br />Glad that was it.&nbsp; There is a caveat about it however.&nbsp; In large drawings with lots of overlapping objects leaving selection cycling turned on can have an adverse effect on performance.&nbsp; I've learned that the hard way.&nbsp; As a result I leave it turned off most of the time.<br><br>Dave.<br>]]>
   <pubDate>Mon, 23 Jan 2012 01:31:23 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=7197&amp;PID=18681&amp;title=ticking-overlapping-objects#18681</guid>
   <title><![CDATA[Ticking overlapping objects : See also the tip: http://www....]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=7197&amp;PID=18678&amp;title=ticking-overlapping-objects#18678</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=3">Vladimir Michl</a><br /><strong>Subject:</strong> 7197<br /><strong>Posted:</strong> 22.Jan.2012 at 22:26<br /><br />See also the tip:<DIV><a href="http://www.cadforum.cz/cadforum_en/overlapping-selecti&#111;n-cycling-in-autocad-2011-2012-tip8137" target="_blank">http://www.cadforum.cz/cadforum_en/overlapping-selection-cycling-in-autocad-2011-2012-tip8137</A></DIV>]]>
   <pubDate>Sun, 22 Jan 2012 22:26:34 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=7197&amp;PID=18678&amp;title=ticking-overlapping-objects#18678</guid>
   <title><![CDATA[Ticking overlapping objects : Thanks. Learn something new everyday.  ...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=7197&amp;PID=18676&amp;title=ticking-overlapping-objects#18676</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=165260">John Connor</a><br /><strong>Subject:</strong> 7197<br /><strong>Posted:</strong> 22.Jan.2012 at 20:56<br /><br />Thanks.&nbsp; Learn something new everyday.]]>
   <pubDate>Sun, 22 Jan 2012 20:56:40 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=7197&amp;PID=18676&amp;title=ticking-overlapping-objects#18676</guid>
   <title><![CDATA[Ticking overlapping objects :    heinsite wrote:Try Ctrl-W...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=7197&amp;PID=18671&amp;title=ticking-overlapping-objects#18671</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=238812">Keleris</a><br /><strong>Subject:</strong> 7197<br /><strong>Posted:</strong> 22.Jan.2012 at 16:26<br /><br /><table width="99%"><tr><td class="BBquote"><img src="forum_images/quote_box.png" title="Originally posted by heinsite" alt="Originally posted by heinsite" style="vertical-align: text-bottom;" /> <strong>heinsite wrote:</strong><br /><br />Try Ctrl-W (Selection cycling).&nbsp; There's also a button for it on the bottom of your screen below the command prompt.&nbsp; It's the last one on the right.&nbsp; You probably turned it off.<br><br>Dave.<br></td></tr></table><div>Ctrl+w helped, thanks!</div><div><br></div><div>Here is the table for John Connor. &nbsp;<div><img src="http://img99.imageshack.us/img99/9039/tablev.png" border="0" /><br></div></div>]]>
   <pubDate>Sun, 22 Jan 2012 16:26:08 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=7197&amp;PID=18671&amp;title=ticking-overlapping-objects#18671</guid>
   <title><![CDATA[Ticking overlapping objects : Try Ctrl-W (Selection cycling)....]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=7197&amp;PID=18664&amp;title=ticking-overlapping-objects#18664</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=35918">heinsite</a><br /><strong>Subject:</strong> 7197<br /><strong>Posted:</strong> 22.Jan.2012 at 06:31<br /><br />Try Ctrl-W (Selection cycling).&nbsp; There's also a button for it on the bottom of your screen below the command prompt.&nbsp; It's the last one on the right.&nbsp; You probably turned it off.<br><br>Dave.<br>]]>
   <pubDate>Sun, 22 Jan 2012 06:31:22 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=7197&amp;PID=18664&amp;title=ticking-overlapping-objects#18664</guid>
   <title><![CDATA[Ticking overlapping objects : I&amp;#039;ve yet to see this table...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=7197&amp;PID=18659&amp;title=ticking-overlapping-objects#18659</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=165260">John Connor</a><br /><strong>Subject:</strong> 7197<br /><strong>Posted:</strong> 21.Jan.2012 at 15:14<br /><br />I've yet to see this table you speak of in the version of 2012 I'm running.&nbsp; Is there a name for this feature as I'd like to learn more about it myself.&nbsp; Perhaps you can find and post an image of the table?]]>
   <pubDate>Sat, 21 Jan 2012 15:14:44 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=7197&amp;PID=18659&amp;title=ticking-overlapping-objects#18659</guid>
   <title><![CDATA[Ticking overlapping objects : It was a small table with the...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=7197&amp;PID=18654&amp;title=ticking-overlapping-objects#18654</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=238812">Keleris</a><br /><strong>Subject:</strong> 7197<br /><strong>Posted:</strong> 21.Jan.2012 at 11:26<br /><br />It was a small table with the list of all objects which are located in the area where the cursor is moved over. For example if the view was zoomed out, it would be a table with list of all objects located in the drawing. As I know, it didn't exist in previous versions of Autocad.<div><br></div><div>Pickadd and pickfirst are set to "1".</div>]]>
   <pubDate>Sat, 21 Jan 2012 11:26:42 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=7197&amp;PID=18654&amp;title=ticking-overlapping-objects#18654</guid>
   <title><![CDATA[Ticking overlapping objects : What table are you referring to?...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=7197&amp;PID=18587&amp;title=ticking-overlapping-objects#18587</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=165260">John Connor</a><br /><strong>Subject:</strong> 7197<br /><strong>Posted:</strong> 18.Jan.2012 at 17:49<br /><br />What table are you referring to?&nbsp; Properties?&nbsp; Quick Properties?&nbsp; Other?<br><br>Are both PIKFIRST and PICKADD set to "1"?<br>]]>
   <pubDate>Wed, 18 Jan 2012 17:49:28 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=7197&amp;PID=18587&amp;title=ticking-overlapping-objects#18587</guid>
   <title><![CDATA[Ticking overlapping objects :  Hi,First of all i would like...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=7197&amp;PID=18580&amp;title=ticking-overlapping-objects#18580</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=238812">Keleris</a><br /><strong>Subject:</strong> 7197<br /><strong>Posted:</strong> 18.Jan.2012 at 15:16<br /><br /><span style="color: rgb(0, 0, 0); line-height: 18px; : rgb(239, 239, 239); ">Hi,&nbsp;</span><br style="color: rgb(0, 0, 0); line-height: 18px; : rgb(239, 239, 239); "><span style="color: rgb(0, 0, 0); line-height: 18px; : rgb(239, 239, 239); ">First of all i would like to notice that</span>&nbsp;<span style="color: rgb(0, 0, 0); line-height: 18px; : rgb(239, 239, 239); ">I haven't read all the topics so sorry if somebody has already asked the same question.</span>&nbsp;<span style="color: rgb(0, 0, 0); line-height: 18px; : rgb(239, 239, 239); "><br></span><div><span style="color: rgb(0, 0, 0); line-height: 18px; : rgb(239, 239, 239); "><br></span></div><div><span style="color: rgb(0, 0, 0); line-height: 18px; : rgb(239, 239, 239); ">I use Autocad 2012. In the default settings when i moved the cursor over two or more overlapping objects, a table appeared with a list of all these objects. In the table i could choose the object that should be ticked. But I clicked on something by fortune and I lost this useful setting. Now when I click on the overlapping objects only the newest is ticked and it is not possible to choose the others. I look forward for your suggestions:)</span></div><span style="font-size:10px"><br /><br />Edited by Keleris - 18.Jan.2012 at 15:17</span>]]>
   <pubDate>Wed, 18 Jan 2012 15:16:44 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=7197&amp;PID=18580&amp;title=ticking-overlapping-objects#18580</guid>
