  <title>CAD Forum discussion (EN) : PROBLEM WITH TRIM</title>
  <description><![CDATA[This is an XML content feed of; CAD Forum discussion (EN) : AutoCAD : PROBLEM WITH TRIM]]></description>
  <pubDate>Sat, 05 Sep 2026 04:33:17 +0000</pubDate>
  <lastBuildDate>Mon, 06 Feb 2012 19:17:04 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum_en/RSS_post_feed.asp?TID=7278</WebWizForums:feedURL>
   <title><![CDATA[PROBLEM WITH TRIM : Just another lucky guess.   ]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=7278&amp;PID=18943&amp;title=problem-with-trim#18943</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=165260">John Connor</a><br /><strong>Subject:</strong> 7278<br /><strong>Posted:</strong> 06.Feb.2012 at 19:17<br /><br />Just another lucky guess.]]>
   <pubDate>Mon, 06 Feb 2012 19:17:04 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=7278&amp;PID=18943&amp;title=problem-with-trim#18943</guid>
   <title><![CDATA[PROBLEM WITH TRIM : THAT SEEMS TO HAVE WORKED.  THANK...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=7278&amp;PID=18942&amp;title=problem-with-trim#18942</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=85972">thegodian</a><br /><strong>Subject:</strong> 7278<br /><strong>Posted:</strong> 06.Feb.2012 at 18:23<br /><br />THAT SEEMS TO HAVE WORKED.<DIV>&nbsp;</DIV><DIV>THANK YOU</DIV>]]>
   <pubDate>Mon, 06 Feb 2012 18:23:19 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=7278&amp;PID=18942&amp;title=problem-with-trim#18942</guid>
   <title><![CDATA[PROBLEM WITH TRIM : Maybe it&amp;#039;s your EDGEMODE...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=7278&amp;PID=18904&amp;title=problem-with-trim#18904</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=165260">John Connor</a><br /><strong>Subject:</strong> 7278<br /><strong>Posted:</strong> 02.Feb.2012 at 18:07<br /><br />Maybe it's your EDGEMODE setting?]]>
   <pubDate>Thu, 02 Feb 2012 18:07:41 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=7278&amp;PID=18904&amp;title=problem-with-trim#18904</guid>
   <title><![CDATA[PROBLEM WITH TRIM : Hi All,  Having a small problem...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=7278&amp;PID=18902&amp;title=problem-with-trim#18902</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=85972">thegodian</a><br /><strong>Subject:</strong> 7278<br /><strong>Posted:</strong> 02.Feb.2012 at 17:00<br /><br />Hi All,<DIV>&nbsp; Having a small problem with the trim command. When I pick trim then right click i used to be able to remove whole lines. It now only removes a tiny bit of the line. This happens on all lines not just poly lines. If I pick the trim command and pick a trimming line it works fine.</DIV><DIV>&nbsp;Any ideas on how to fix this.</DIV><DIV>&nbsp;</DIV><DIV>Ian</DIV>]]>
   <pubDate>Thu, 02 Feb 2012 17:00:51 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=7278&amp;PID=18902&amp;title=problem-with-trim#18902</guid>
