  <title>CAD Forum discussion (EN) : Custom Fields / Properties</title>
  <description><![CDATA[This is an XML content feed of; CAD Forum discussion (EN) : AutoCAD : Custom Fields / Properties]]></description>
  <pubDate>Sun, 06 Sep 2026 09:52:32 +0000</pubDate>
  <lastBuildDate>Fri, 17 Feb 2012 14:39:08 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum_en/RSS_post_feed.asp?TID=7332</WebWizForums:feedURL>
   <title><![CDATA[Custom Fields / Properties : Awesome, just what I wanted to...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=7332&amp;PID=19060&amp;title=custom-fields-properties#19060</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=250747">goŘn</a><br /><strong>Subject:</strong> 7332<br /><strong>Posted:</strong> 17.Feb.2012 at 14:39<br /><br />Awesome, just what I wanted to know, Thanks for your response Dave.<div><br></div><div>I now understand, only thing left to do is the drawn out task of getting my blocks perfect with attributes as there are 100's if not 1000's&nbsp;<div><br></div><div>We &nbsp;love it, hahah&nbsp;</div></div><div><br></div><div>Have a good weekend</div><div><br></div><div><img src="https://www.cadforum.cz/forum_en/smileys/smiley30.gif" border="0" align="absmiddle" alt="Pig" /><br></div>]]>
   <pubDate>Fri, 17 Feb 2012 14:39:08 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=7332&amp;PID=19060&amp;title=custom-fields-properties#19060</guid>
   <title><![CDATA[Custom Fields / Properties : Including attributes ispart of...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=7332&amp;PID=19043&amp;title=custom-fields-properties#19043</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=35918">heinsite</a><br /><strong>Subject:</strong> 7332<br /><strong>Posted:</strong> 16.Feb.2012 at 20:29<br /><br />Including attributes is&nbsp;part of the block definition process.&nbsp; You&nbsp;can put blocks that contain&nbsp;attributes on a tool palette, yes.&nbsp; Attribute values do&nbsp; show up in the Properties Manager when you select a block object.&nbsp; But they won't show up on the tool palette. <DIV>&nbsp;</DIV><DIV>If you want to see (or not see) what the particular attribute values are for a particular block, you need to either make them visible or invisible when you define the block.&nbsp; That's up to you.</DIV><DIV>&nbsp;</DIV><DIV>Hope this helped.</DIV><DIV>Dave.</DIV><span style="font-size:10px"><br /><br />Edited by heinsite - 16.Feb.2012 at 20:31</span>]]>
   <pubDate>Thu, 16 Feb 2012 20:29:17 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=7332&amp;PID=19043&amp;title=custom-fields-properties#19043</guid>
   <title><![CDATA[Custom Fields / Properties : Good Morning world!Get the coffees...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=7332&amp;PID=19034&amp;title=custom-fields-properties#19034</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=250747">goŘn</a><br /><strong>Subject:</strong> 7332<br /><strong>Posted:</strong> 16.Feb.2012 at 10:52<br /><br /><div>Good Morning world!</div><div><br></div><div>Get the coffees in.</div><div><br></div><div>I was wondering if you guys can help me out with something i don't know if&nbsp;</div><div>i make myself clear.</div><div><br></div><div>For example say if i have some blocks in my tool palette&nbsp;</div><div>can i add custom attributes to that block for example i know how much each component weighs,&nbsp;</div><div>is it possible to create a field for the value that will display in the properties box.</div><div><br></div><div>Thanks guys &nbsp;&nbsp;</div><div><img src="https://www.cadforum.cz/forum_en/smileys/smiley10.gif" border="0" align="absmiddle" alt="Star" /><br></div>]]>
   <pubDate>Thu, 16 Feb 2012 10:52:49 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=7332&amp;PID=19034&amp;title=custom-fields-properties#19034</guid>
