  <title>CAD Forum discussion (EN) : AutoCAD 2010 3D users</title>
  <description><![CDATA[This is an XML content feed of; CAD Forum discussion (EN) : CAD - general : AutoCAD 2010 3D users]]></description>
  <pubDate>Thu, 01 Oct 2026 05:39:40 +0000</pubDate>
  <lastBuildDate>Tue, 28 Feb 2012 07:04:43 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum_en/RSS_post_feed.asp?TID=7376</WebWizForums:feedURL>
   <title><![CDATA[AutoCAD 2010 3D users : Hello N&#176; 3, I read your answer...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=7376&amp;PID=19171&amp;title=autocad-2010-3d-users#19171</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=175428">philippe JOSEPH</a><br /><strong>Subject:</strong> 7376<br /><strong>Posted:</strong> 28.Feb.2012 at 07:04<br /><br />Hello N° 3, I read your answer of 16:25 and I found that you were sad or frustrated. You should not.<DIV>The use of AutoCAD 3D is not the all day user capacities, and then you found a solution on your own. This is good.</DIV><DIV>A lot of things can be done. I learned AutoCAD 3D on my own reading the old R13 book + the PDF book that you can find now&nbsp;in : c\program files\Autodesk\ACADM 2008\Setup\Docs.</DIV><DIV>For&nbsp;my job tasks, I found solutions for : Topo survey, developing sheets of special parts etc...</DIV><DIV>AutoCAD 3D may not be the more up to date and friendly user software but if you push it ( and you ) to the limits it will be more than sufficient and efficient.</DIV>]]>
   <pubDate>Tue, 28 Feb 2012 07:04:43 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=7376&amp;PID=19171&amp;title=autocad-2010-3d-users#19171</guid>
   <title><![CDATA[AutoCAD 2010 3D users : Another solution found today. When...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=7376&amp;PID=19165&amp;title=autocad-2010-3d-users#19165</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=255510">kstull</a><br /><strong>Subject:</strong> 7376<br /><strong>Posted:</strong> 27.Feb.2012 at 18:38<br /><br /><P>Another solution found today.</P><P>When rotating a 3D part, right click after selecting the part, choose "align Gizmo with current UCS".</P>]]>
   <pubDate>Mon, 27 Feb 2012 18:38:42 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=7376&amp;PID=19165&amp;title=autocad-2010-3d-users#19165</guid>
   <title><![CDATA[AutoCAD 2010 3D users : Well OK then, I really only draw...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=7376&amp;PID=19162&amp;title=autocad-2010-3d-users#19162</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=255510">kstull</a><br /><strong>Subject:</strong> 7376<br /><strong>Posted:</strong> 27.Feb.2012 at 16:25<br /><br /><P>Well OK then, I really only draw simple stuff in autoCAD 3D for now, time to end this discussion for now. I will use the "align" command more often until I get a bit more experience, stumble across another solution or get "Inventor" to use for 3D.</P><DIV>Thanks for your input!</DIV>]]>
   <pubDate>Mon, 27 Feb 2012 16:25:26 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=7376&amp;PID=19162&amp;title=autocad-2010-3d-users#19162</guid>
   <title><![CDATA[AutoCAD 2010 3D users : Hello, it&amp;#039;s good to share...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=7376&amp;PID=19135&amp;title=autocad-2010-3d-users#19135</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=175428">philippe JOSEPH</a><br /><strong>Subject:</strong> 7376<br /><strong>Posted:</strong> 24.Feb.2012 at 10:03<br /><br />Hello, it's good to share informations and/or problems with that interresting subject that is working in 3D ( I also have problems and questions without answers ).<DIV></DIV><DIV>&nbsp;</DIV><DIV>What I mean when saying working directly in 3 dimensions is that with old release you could only work in x, y confomably to your UCS.</DIV><DIV>Now you can draw a line in&nbsp;X following the red direction,&nbsp;Y following the green direction and also in Z&nbsp;following the blue direction.</DIV><DIV>This is good but can lead you not working in the right direction ( and worse if you don't have F8 on ).</DIV><DIV>&nbsp;</DIV><DIV><DIV>There is an option to "Ignore snapping objects negative Z USC dyn" in the "OPTION" menu / Drawing that may allow you working in 3D with a 2D viewpoint ( I havn't try ).</DIV><DIV>&nbsp;</DIV></DIV><DIV>What happen to me is having my UCS changing automaticaly ( not my will, not my choise and&nbsp;making troubles )&nbsp;when approching a 3D object.</DIV><DIV>It looks like it have to see with the "dynamic UCS" but I havn't done searches on this subject.</DIV><DIV>May be your problems have things to see with this.</DIV><DIV>&nbsp;</DIV><DIV>3D is so interresting , so difficult and problematic is you start your dwg with wrong first steps that I switch to old and slow drawing methods not to have to redraw everything in the middle of the work.</DIV><DIV>I have only AutoCAD 2008 and so my informations can be outdated ( I think that the "old and slow methods" are still OK on recent releases and may be better before you validate your drawings ).</DIV>]]>
   <pubDate>Fri, 24 Feb 2012 10:03:22 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=7376&amp;PID=19135&amp;title=autocad-2010-3d-users#19135</guid>
   <title><![CDATA[AutoCAD 2010 3D users : Not sure what you mean by &amp;#034;draw...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=7376&amp;PID=19131&amp;title=autocad-2010-3d-users#19131</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=255510">kstull</a><br /><strong>Subject:</strong> 7376<br /><strong>Posted:</strong> 23.Feb.2012 at 22:01<br /><br /><P>Not sure what you mean by "draw directly in 3 dimension". Let me try to better explain my command execution process and results.</P><P>I have one box drawn, aligned to the UCS. I draw a second box with the 1st corner snapped to the corner of the existing box. I usually like the "length" subcommand&nbsp; then I can choose the length (x), width (y) and height (z) for the new box.</P><DIV>I almost always draw "ortho on" when in 3D but thank you for clarification.</DIV><DIV>I then use the 3D rotate command, choosing a corner or a mid-point as the base point. I then select one of the three axis to rotate on using the Gizmo. The results is the rotation of the box, out of the UCS.</DIV><DIV>Interesting enough that the gizmo line that flashes when selecting&nbsp; an axis from the Gizmo appears to be out of align from the UCS.</DIV><DIV>Graphics issue?</DIV><DIV>Thanks for reviewing my post.</DIV>]]>
   <pubDate>Thu, 23 Feb 2012 22:01:12 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=7376&amp;PID=19131&amp;title=autocad-2010-3d-users#19131</guid>
   <title><![CDATA[AutoCAD 2010 3D users : Hello, if you draw your objects...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=7376&amp;PID=19127&amp;title=autocad-2010-3d-users#19127</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=175428">philippe JOSEPH</a><br /><strong>Subject:</strong> 7376<br /><strong>Posted:</strong> 23.Feb.2012 at 07:51<br /><br />Hello, if you draw your objects with F8 on ( ortho ) you shouldn't have problems ( if you do your commands with a 3D point of view.<DIV>Notice that with the recent release that you have you can draw directly in the 3 dimensions ( x, y, and z ).</DIV><DIV>If you rotate your objects beware of setting F8 on and set an UCS comformably to your rotation.</DIV><DIV>With 3D objects I frequently use ALIGN&nbsp;&nbsp;rather than rotate so I can also move them to the right place in the same command ( with the option of scaling them also ).</DIV><DIV>With the 3D align command ( egal to the 2D ALIGN command ) beware of giving three points and not 2 ( even if you think it's OK with 2 because in some case you will not obtain the right rotation ( it's noticed in the help ).</DIV><DIV>May be it's your case.</DIV><DIV>Ask for more, and have a good day.</DIV>]]>
   <pubDate>Thu, 23 Feb 2012 07:51:52 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=7376&amp;PID=19127&amp;title=autocad-2010-3d-users#19127</guid>
   <title><![CDATA[AutoCAD 2010 3D users : Why are the objects that I draw...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=7376&amp;PID=19123&amp;title=autocad-2010-3d-users#19123</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=255510">kstull</a><br /><strong>Subject:</strong> 7376<br /><strong>Posted:</strong> 22.Feb.2012 at 20:16<br /><br />Why are the objects that I draw in 3D not aligned with the current UCS? Sometimes when I move or rotate an object in the 3D enviroment, the command is not executed in the current UCS.]]>
   <pubDate>Wed, 22 Feb 2012 20:16:36 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=7376&amp;PID=19123&amp;title=autocad-2010-3d-users#19123</guid>
