  <title>CAD Forum discussion (EN) : Problem network login</title>
  <description><![CDATA[This is an XML content feed of; CAD Forum discussion (EN) : AutoCAD : Problem network login]]></description>
  <pubDate>Tue, 20 Oct 2026 10:45:10 +0000</pubDate>
  <lastBuildDate>Thu, 15 May 2008 10:48:11 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum_en/RSS_post_feed.asp?TID=739</WebWizForums:feedURL>
   <title><![CDATA[Problem network login : At the University Zuyd in Heerlen...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=739&amp;PID=1934&amp;title=problem-network-login#1934</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=10421">Kupie</a><br /><strong>Subject:</strong> 739<br /><strong>Posted:</strong> 15.May.2008 at 10:48<br /><br /><P =Ms&#111;normal style="MARGIN: 0cm 0cm 0pt"><SPAN lang=EN-GB style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'; mso-ansi-: EN-GB"><FONT color=#000000>At the University Zuyd in <?:namespace prefix = st1 ns = "urn:schemas-microsoft-com:office:smarttags" /><st1:City w:st="&#111;n"><st1:place w:st="&#111;n">Heerlen</st1:place></st1:City> we use Autocad 2005.<?:namespace prefix = o ns = "urn:schemas-microsoft-com:office:office" /><o:p></o:p></FONT></SPAN></P><P =Ms&#111;normal style="MARGIN: 0cm 0cm 0pt"><SPAN lang=EN-GB style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'; mso-ansi-: EN-GB"><FONT color=#000000>We installed this as network version using the deploy function. When we login with administrator rights we get a autocad installation sequence. This is not a problem because we have admin rights.<o:p></o:p></FONT></SPAN></P><P =Ms&#111;normal style="MARGIN: 0cm 0cm 0pt"><SPAN lang=EN-GB style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'; mso-ansi-: EN-GB"><FONT color=#000000>However as normal users login, they get a autocad install wich they can’t finish because they don’t have the right to install. We managed to get autocad running for these users by copying part of the registry and a profile path. The problem is now, every time a user tries to login he will get a autocad install wither he wants to work with autocad or not.<o:p></o:p></FONT></SPAN></P><P =Ms&#111;normal style="MARGIN: 0cm 0cm 0pt"><SPAN lang=EN-GB style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'; mso-ansi-: EN-GB"><FONT color=#000000>I looked already in the registry and removed anything from the RUN section, but I can’t stop this install.<o:p></o:p></FONT></SPAN></P><P =Ms&#111;normal style="MARGIN: 0cm 0cm 0pt"><SPAN lang=EN-GB style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'; mso-ansi-: EN-GB"><FONT color=#000000>Do you have a solution or something I can try to prohibit this initial install.</FONT></SPAN></P><P =Ms&#111;normal style="MARGIN: 0cm 0cm 0pt"><SPAN lang=EN-GB style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'; mso-ansi-: EN-GB"></SPAN>&nbsp;</P><P =Ms&#111;normal style="MARGIN: 0cm 0cm 0pt"><SPAN lang=EN-GB style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'; mso-ansi-: EN-GB"></SPAN><SPAN lang=EN-GB style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'; mso-ansi-: EN-GB"><FONT color=#000000>With kind regards,<o:p></o:p></FONT></SPAN></P><P =Ms&#111;normal style="MARGIN: 0cm 0cm 0pt"><SPAN style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'"><FONT color=#000000>Huub Paas<img src="http://www.cadforum.cz/forum_en/smileys/smiley2.gif" height="17" width="17" border="0" align="absmiddle" alt="Wink" /><o:p></o:p></FONT></SPAN></P><P =Ms&#111;normal style="MARGIN: 0cm 0cm 0pt"><SPAN style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'"><FONT color=#000000><o:p></o:p></FONT></SPAN>&nbsp;</P>]]>
   <pubDate>Thu, 15 May 2008 10:48:11 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=739&amp;PID=1934&amp;title=problem-network-login#1934</guid>
