  <title>CAD Forum discussion (EN) : Array window missed</title>
  <description><![CDATA[This is an XML content feed of; CAD Forum discussion (EN) : AutoCAD : Array window missed]]></description>
  <pubDate>Tue, 27 Oct 2026 07:00:09 +0000</pubDate>
  <lastBuildDate>Thu, 05 Apr 2012 23:29:02 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum_en/RSS_post_feed.asp?TID=7631</WebWizForums:feedURL>
   <title><![CDATA[Array window missed :    John Connor wrote:The ARRAYCLASSIC...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=7631&amp;PID=19729&amp;title=array-window-missed#19729</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=267773">rbocaz</a><br /><strong>Subject:</strong> 7631<br /><strong>Posted:</strong> 05.Apr.2012 at 23:29<br /><br /><table width="99%"><tr><td class="BBquote"><img src="forum_images/quote_box.png" title="Originally posted by John Connor" alt="Originally posted by John Connor" style="vertical-align: text-bottom;" /> <strong>John Connor wrote:</strong><br /><br />The ARRAYCLASSIC command is what you need and it was included in Service Pack 1 for AutoCAD 2012.&nbsp; You should have downloaded and installed it by now since AutoCAD 2013 just released.&nbsp; You didn't do it did you?</td></tr></table><br><br>Thanks, that was it. Now working. <br>]]>
   <pubDate>Thu, 05 Apr 2012 23:29:02 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=7631&amp;PID=19729&amp;title=array-window-missed#19729</guid>
   <title><![CDATA[Array window missed : The ARRAYCLASSIC command is what...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=7631&amp;PID=19727&amp;title=array-window-missed#19727</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=165260">John Connor</a><br /><strong>Subject:</strong> 7631<br /><strong>Posted:</strong> 05.Apr.2012 at 18:49<br /><br />The ARRAYCLASSIC command is what you need and it was included in Service Pack 1 for AutoCAD 2012.&nbsp; You should have downloaded and installed it by now since AutoCAD 2013 just released.&nbsp; You didn't do it did you?]]>
   <pubDate>Thu, 05 Apr 2012 18:49:37 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=7631&amp;PID=19727&amp;title=array-window-missed#19727</guid>
   <title><![CDATA[Array window missed :    John Connor wrote:Isn&amp;#039;t...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=7631&amp;PID=19726&amp;title=array-window-missed#19726</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=267773">rbocaz</a><br /><strong>Subject:</strong> 7631<br /><strong>Posted:</strong> 05.Apr.2012 at 14:44<br /><br /><table width="99%"><tr><td class="BBquote"><img src="forum_images/quote_box.png" title="Originally posted by John Connor" alt="Originally posted by John Connor" style="vertical-align: text-bottom;" /> <strong>John Connor wrote:</strong><br /><br />Isn't there an Array Classic command in Update 1 for 2012?<br><br>Pretty sure there is.<br></td></tr></table><br><br>In deed, there must be one, but I don't know how to make it show.<br>]]>
   <pubDate>Thu, 05 Apr 2012 14:44:49 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=7631&amp;PID=19726&amp;title=array-window-missed#19726</guid>
   <title><![CDATA[Array window missed : Isn&amp;#039;t there an Array Classic...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=7631&amp;PID=19713&amp;title=array-window-missed#19713</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=165260">John Connor</a><br /><strong>Subject:</strong> 7631<br /><strong>Posted:</strong> 05.Apr.2012 at 00:10<br /><br />Isn't there an Array Classic command in Update 1 for 2012?<br><br>Pretty sure there is.<br>]]>
   <pubDate>Thu, 05 Apr 2012 00:10:05 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=7631&amp;PID=19713&amp;title=array-window-missed#19713</guid>
   <title><![CDATA[Array window missed : When I run the array button it...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=7631&amp;PID=19711&amp;title=array-window-missed#19711</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=267773">rbocaz</a><br /><strong>Subject:</strong> 7631<br /><strong>Posted:</strong> 05.Apr.2012 at 00:03<br /><br />When I run the array button it show a textual configuration of the array. I would like the neat graphic array window, that somehow is missing. So, how I make it show?<br><br>Thanks<br><br><br>]]>
   <pubDate>Thu, 05 Apr 2012 00:03:21 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=7631&amp;PID=19711&amp;title=array-window-missed#19711</guid>
