  <title>CAD Forum discussion (EN) : appint-Apparent Intersection Command Gone</title>
  <description><![CDATA[This is an XML content feed of; CAD Forum discussion (EN) : AutoCAD : appint-Apparent Intersection Command Gone]]></description>
  <pubDate>Mon, 26 Oct 2026 21:36:27 +0000</pubDate>
  <lastBuildDate>Wed, 11 Apr 2012 15:30:03 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum_en/RSS_post_feed.asp?TID=7649</WebWizForums:feedURL>
   <title><![CDATA[appint-Apparent Intersection Command Gone : So you are working in 3D?AutoCAD...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=7649&amp;PID=19766&amp;title=appintapparent-intersection-command-gone#19766</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=165260">John Connor</a><br /><strong>Subject:</strong> 7649<br /><strong>Posted:</strong> 11.Apr.2012 at 15:30<br /><br />So you are working in 3D?<br><br>AutoCAD 2004 I see.&nbsp; You might just have to copy a line up to the correct elevation and use it to trim your other line.<br>]]>
   <pubDate>Wed, 11 Apr 2012 15:30:03 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=7649&amp;PID=19766&amp;title=appintapparent-intersection-command-gone#19766</guid>
   <title><![CDATA[appint-Apparent Intersection Command Gone : Wow, it appears I had a case of...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=7649&amp;PID=19764&amp;title=appintapparent-intersection-command-gone#19764</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=257301">Edward Fasula</a><br /><strong>Subject:</strong> 7649<br /><strong>Posted:</strong> 11.Apr.2012 at 14:57<br /><br />Wow, it appears I had a case of wishful thinking.&nbsp; I've used it as a running snap function, and that's why I never invoked the command.<br><br>Perhaps I should start a new thread for what I'm trying to do.&nbsp; I want to be able to trim to a line that is on another elevation.... trim to the apparent intersection looking from, say, the right view.<br><br>THANKS for ending my wild goose chase, at lest this aspect of it!<br><br>Ed<br>]]>
   <pubDate>Wed, 11 Apr 2012 14:57:12 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=7649&amp;PID=19764&amp;title=appintapparent-intersection-command-gone#19764</guid>
   <title><![CDATA[appint-Apparent Intersection Command Gone : APPINT is a command MODIFIER meaning...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=7649&amp;PID=19760&amp;title=appintapparent-intersection-command-gone#19760</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=165260">John Connor</a><br /><strong>Subject:</strong> 7649<br /><strong>Posted:</strong> 11.Apr.2012 at 11:49<br /><br />APPINT is a command MODIFIER meaning you must use it while in a command (ex. - such as the LINE command) you can't just type APPINT as AutoCAD does not recognize it as a standalone command.&nbsp; You can also use APP, again, as a command MODIFIER, to invoke the Apparent Intersection osnap.]]>
   <pubDate>Wed, 11 Apr 2012 11:49:37 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=7649&amp;PID=19760&amp;title=appintapparent-intersection-command-gone#19760</guid>
   <title><![CDATA[appint-Apparent Intersection Command Gone : APPINT is not a valid command,...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=7649&amp;PID=19754&amp;title=appintapparent-intersection-command-gone#19754</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=35918">heinsite</a><br /><strong>Subject:</strong> 7649<br /><strong>Posted:</strong> 11.Apr.2012 at 07:06<br /><br />APPINT is not a valid command, but you can set a running apparent intersection osnap&nbsp;from the task bar object snap settings&nbsp;dialog, or by setting the OSMODE system variable = 2048.&nbsp; Try this last idea first on your drawing by itself and see if it works.&nbsp; Then check the Object Snaps settings dialog and look for it there. <DIV>&nbsp;</DIV><DIV>Dave.</DIV><span style="font-size:10px"><br /><br />Edited by heinsite - 11.Apr.2012 at 07:07</span>]]>
   <pubDate>Wed, 11 Apr 2012 07:06:50 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=7649&amp;PID=19754&amp;title=appintapparent-intersection-command-gone#19754</guid>
   <title><![CDATA[appint-Apparent Intersection Command Gone : Hi,I don&amp;#039;t use the apparent...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=7649&amp;PID=19752&amp;title=appintapparent-intersection-command-gone#19752</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=257301">Edward Fasula</a><br /><strong>Subject:</strong> 7649<br /><strong>Posted:</strong> 11.Apr.2012 at 03:10<br /><br />Hi,<br><br>I don't use the apparent intersection command normally, so I just noticed it's not working.&nbsp; <br><br>I did a fresh install of AC 2005, not adding or importing any custom settings and still it does not work.<br><br>I found advice online to make sure acad.mnl is loaded, and this is what I still get after even manually doing so:<br><br>Command: (load "acad.mnl")<br>AutoCAD menu utilities loaded.<br>Command: _appint Unknown command "APPINT".&nbsp; Press F1 for help.<br><br>2004 and 2010 are loaded on the same machine and they come up with the same problem!!!<br><br>I have some 3D wireframe models to prepare to load into a structural analysis program, and apparent intersection seems to be the only way to do the work I need to in 3D.<br><br>Any help appreciated!!!&nbsp; <br><br>Ed<br>]]>
   <pubDate>Wed, 11 Apr 2012 03:10:20 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=7649&amp;PID=19752&amp;title=appintapparent-intersection-command-gone#19752</guid>
