  <title>CAD Forum discussion (EN) : Publishing</title>
  <description><![CDATA[This is an XML content feed of; CAD Forum discussion (EN) : AutoCAD : Publishing]]></description>
  <pubDate>Sat, 05 Sep 2026 04:18:15 +0000</pubDate>
  <lastBuildDate>Fri, 04 May 2012 08:25:40 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum_en/RSS_post_feed.asp?TID=7756</WebWizForums:feedURL>
   <title><![CDATA[Publishing :   Thats right. Thanks for sharing....]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=7756&amp;PID=20055&amp;title=publishing#20055</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=196209">FarooqiSA</a><br /><strong>Subject:</strong> 7756<br /><strong>Posted:</strong> 04.May.2012 at 08:25<br /><br />Thats right. Thanks for sharing.]]>
   <pubDate>Fri, 04 May 2012 08:25:40 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=7756&amp;PID=20055&amp;title=publishing#20055</guid>
   <title><![CDATA[Publishing : Hello, this is true? I can attend?  ...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=7756&amp;PID=20053&amp;title=publishing#20053</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=275888">rappelzdzd</a><br /><strong>Subject:</strong> 7756<br /><strong>Posted:</strong> 04.May.2012 at 05:30<br /><br /><span id="result_" ="short_text" lang="en"><span ="">Hello</span><span ="">, this is</span> <span ="hps">true?</span> <span ="hps">I can</span> <span ="hps">attend?</span></span>]]>
   <pubDate>Fri, 04 May 2012 05:30:00 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=7756&amp;PID=20053&amp;title=publishing#20053</guid>
   <title><![CDATA[Publishing : I have just found out that there...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=7756&amp;PID=20051&amp;title=publishing#20051</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=99066">paullafferty55</a><br /><strong>Subject:</strong> 7756<br /><strong>Posted:</strong> 03.May.2012 at 14:18<br /><br />I have just found out that there is a way of doing it.<div><br></div><div>When setting up the page set up for the layout tabs you generally have a standard default one. &nbsp;Mine was to plot in colour to out A1 plotter.</div><div><br></div><div>However, after you have set up you page set up, right click on the layout tab, go to page set up manager and go to NEW. &nbsp;Then set up the same layout tab to plot to your alternative plotter (A3)</div><div><br></div><div>When you then go to publish the layout tabs you can change the default page set up to print to your alternative plotter from the drop down menu.</div><div><br></div><div>Hope this helps. &nbsp;It worked for me.</div>]]>
   <pubDate>Thu, 03 May 2012 14:18:31 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=7756&amp;PID=20051&amp;title=publishing#20051</guid>
   <title><![CDATA[Publishing :   There is no other shortcut...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=7756&amp;PID=20050&amp;title=publishing#20050</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=196209">FarooqiSA</a><br /><strong>Subject:</strong> 7756<br /><strong>Posted:</strong> 03.May.2012 at 13:43<br /><br />There is no other shortcut for publishing&nbsp;on a different plotter other than what you are already doing. ]]>
   <pubDate>Thu, 03 May 2012 13:43:48 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=7756&amp;PID=20050&amp;title=publishing#20050</guid>
   <title><![CDATA[Publishing : my company using pdf files,autocad...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=7756&amp;PID=20021&amp;title=publishing#20021</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=272988">xrayrays</a><br /><strong>Subject:</strong> 7756<br /><strong>Posted:</strong> 02.May.2012 at 04:22<br /><br />my company using pdf files,<div>autocad 3d to pdf 3d files</div><div>ang proe 3d to pdf 3d files</div><div><br></div><div>maybe someone have the idea on this.</div><div><br></div><div>i update this thread. coz i need also this.</div>]]>
   <pubDate>Wed, 02 May 2012 04:22:02 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=7756&amp;PID=20021&amp;title=publishing#20021</guid>
   <title><![CDATA[Publishing : Hi All. This is my first post...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=7756&amp;PID=20012&amp;title=publishing#20012</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=99066">paullafferty55</a><br /><strong>Subject:</strong> 7756<br /><strong>Posted:</strong> 01.May.2012 at 13:18<br /><br />Hi All. &nbsp;This is my first post on cad forum and it relates to publishing.<div><br></div><div>I want to publish a full set of our tender drawings for a recent project. &nbsp;When i open all the cad files and hit the publish tool it gives you a few options.</div><div><br></div><div>You can publish to PDF, DWF etc as well as publishing to a plotter. &nbsp;The issue i have is all my layout tabs are set up to plot to an A1 HP plotter and are all set to A1 size sheets. &nbsp;Is there a way to publish all the drawings to a different plotter (A3) size without having to go in and change the plotting setting of each individual layout tab.</div><div><br></div><div>To do this in the past i would generally publish all the drawings into one large PDF document &amp; then print to the required plotter, however i was hoping there is a way to do this without having to publish the pdf first.</div><div><br></div><div>Thanks Guys &amp; Gals.</div>]]>
   <pubDate>Tue, 01 May 2012 13:18:09 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=7756&amp;PID=20012&amp;title=publishing#20012</guid>
