  <title>CAD Forum discussion (EN) : autocad analyze dump file &quot;acminidump.dmp&quot;</title>
  <description><![CDATA[This is an XML content feed of; CAD Forum discussion (EN) : AutoCAD : autocad analyze dump file &quot;acminidump.dmp&quot;]]></description>
  <pubDate>Fri, 04 Sep 2026 23:13:55 +0000</pubDate>
  <lastBuildDate>Thu, 10 May 2012 11:50:39 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum_en/RSS_post_feed.asp?TID=7780</WebWizForums:feedURL>
   <title><![CDATA[autocad analyze dump file &quot;acminidump.dmp&quot; : AutoCAD LT 2008. So you have had...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=7780&amp;PID=20124&amp;title=autocad-analyze-dump-file-acminidumpdmp#20124</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=165260">John Connor</a><br /><strong>Subject:</strong> 7780<br /><strong>Posted:</strong> 10.May.2012 at 11:50<br /><br />AutoCAD LT 2008.&nbsp; So you have had this program up and running for a while.&nbsp; <br><br>When did the problem first occur?<br><br>What is the exact nature of the problem?<br><br>What steps have you taken to troubleshoot the problem so far?<br><br>Have you tried a REPAIR of AutoCAD?&nbsp;]]>
   <pubDate>Thu, 10 May 2012 11:50:39 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=7780&amp;PID=20124&amp;title=autocad-analyze-dump-file-acminidumpdmp#20124</guid>
   <title><![CDATA[autocad analyze dump file &quot;acminidump.dmp&quot; : It&amp;#039;s important for you to...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=7780&amp;PID=20122&amp;title=autocad-analyze-dump-file-acminidumpdmp#20122</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=175428">philippe JOSEPH</a><br /><strong>Subject:</strong> 7780<br /><strong>Posted:</strong> 10.May.2012 at 10:37<br /><br />It's important for you to know on what particular command your crash happens, then you can do a "save" before trying that commnad again.<DIV>I don't know if your "lt 2008" has any updating releases ( SP1 to&nbsp;SP2 etc... ).</DIV><DIV>Try to contact your AutoCAD dealer to download the latest ( normaly these SP2 etc... cure the different bugs ).</DIV><DIV>Isn't your file too big for your computer ?</DIV><DIV>If the crash happens one one particular file and not on the others try to "control" and&nbsp;"repair" your file with the commands "AUDIT" ( VERIFICA in italian ) and "RECOVER" ( RECUPERA in italian ).</DIV><DIV>Do you PURGE your files ( command "ELIMINA" in italian ) ?</DIV><DIV>Please let us know how and if you managed to cure the problems.</DIV>]]>
   <pubDate>Thu, 10 May 2012 10:37:21 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=7780&amp;PID=20122&amp;title=autocad-analyze-dump-file-acminidumpdmp#20122</guid>
   <title><![CDATA[autocad analyze dump file &quot;acminidump.dmp&quot; : no, no other error; is autocad...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=7780&amp;PID=20121&amp;title=autocad-analyze-dump-file-acminidumpdmp#20121</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=277071">grusticali</a><br /><strong>Subject:</strong> 7780<br /><strong>Posted:</strong> 10.May.2012 at 10:19<br /><br />no, no other error; is autocad lt 2008 sp1 with winxp sp3 32bit with full update<br><br>click on file &gt; stampa (italian) and acad crash <br><br>i have also stopped the spooler service but the problem persist ..<br><br>i can try to move ctb and/or pc3 ?<br><br><br>tnx 1k<br>]]>
   <pubDate>Thu, 10 May 2012 10:19:11 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=7780&amp;PID=20121&amp;title=autocad-analyze-dump-file-acminidumpdmp#20121</guid>
   <title><![CDATA[autocad analyze dump file &quot;acminidump.dmp&quot; :   Are there any other error...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=7780&amp;PID=20114&amp;title=autocad-analyze-dump-file-acminidumpdmp#20114</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=3">Vladimir Michl</a><br /><strong>Subject:</strong> 7780<br /><strong>Posted:</strong> 09.May.2012 at 23:25<br /><br />Are there any other error messages displayed? Try to use the error reporting utility (customer error reporting) to send the error to Autodesk.]]>
   <pubDate>Wed, 09 May 2012 23:25:52 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=7780&amp;PID=20114&amp;title=autocad-analyze-dump-file-acminidumpdmp#20114</guid>
   <title><![CDATA[autocad analyze dump file &quot;acminidump.dmp&quot; : the reason why autocad always...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=7780&amp;PID=20112&amp;title=autocad-analyze-dump-file-acminidumpdmp#20112</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=277071">grusticali</a><br /><strong>Subject:</strong> 7780<br /><strong>Posted:</strong> 09.May.2012 at 21:38<br /><br /><span id="result_" ="" lang="en"><span ="hps">the reason why</span> <span ="hps">autocad</span> <span ="hps">always stops</span> <span ="hps">at that point</span> <span ="hps">...</span></span>]]>
   <pubDate>Wed, 09 May 2012 21:38:29 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=7780&amp;PID=20112&amp;title=autocad-analyze-dump-file-acminidumpdmp#20112</guid>
   <title><![CDATA[autocad analyze dump file &quot;acminidump.dmp&quot; : What do you hope to find?   ]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=7780&amp;PID=20086&amp;title=autocad-analyze-dump-file-acminidumpdmp#20086</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=165260">John Connor</a><br /><strong>Subject:</strong> 7780<br /><strong>Posted:</strong> 08.May.2012 at 22:39<br /><br />What do you hope to find?]]>
   <pubDate>Tue, 08 May 2012 22:39:39 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=7780&amp;PID=20086&amp;title=autocad-analyze-dump-file-acminidumpdmp#20086</guid>
   <title><![CDATA[autocad analyze dump file &quot;acminidump.dmp&quot; : Hello to all is possible to analyze...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=7780&amp;PID=20084&amp;title=autocad-analyze-dump-file-acminidumpdmp#20084</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=277071">grusticali</a><br /><strong>Subject:</strong> 7780<br /><strong>Posted:</strong> 08.May.2012 at 19:02<br /><br /><span id="result_" ="" lang="en"><span ="hps">Hello</span> <span ="hps">to all</span><br> <span ="hps">is possible to analyze the </span><span ="hps atn">file "</span><span>acminidump.dmp</span><span>"</span> <span ="hps">that are created</span> <span ="hps">from</span> <span ="hps">Autodesk</span> <span ="hps">products</span> <span ="hps">when</span> <span ="hps">crashing</span> <span ="hps">..</span><br><br> <span ="hps">using</span> <span ="hps">any</span> <span ="hps">software or utility</span> <span ="hps">even paid</span><span>?</span><br><br><span ="hps">Thanks</span> <span ="hps">to all ..</span></span>]]>
   <pubDate>Tue, 08 May 2012 19:02:31 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=7780&amp;PID=20084&amp;title=autocad-analyze-dump-file-acminidumpdmp#20084</guid>
