  <title>CAD Forum discussion (EN) : CUI to MNU</title>
  <description><![CDATA[This is an XML content feed of; CAD Forum discussion (EN) : ARKANCE (CAD Studio) applications : CUI to MNU]]></description>
  <pubDate>Sat, 05 Sep 2026 05:14:15 +0000</pubDate>
  <lastBuildDate>Fri, 25 May 2012 22:46:25 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum_en/RSS_post_feed.asp?TID=7880</WebWizForums:feedURL>
   <title><![CDATA[CUI to MNU : Trying to convert back a custom...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=7880&amp;PID=20353&amp;title=cui-to-mnu#20353</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=165260">John Connor</a><br /><strong>Subject:</strong> 7880<br /><strong>Posted:</strong> 25.May.2012 at 22:46<br /><br />Trying to convert back a custom CUI to use on AutoCAD 2006?<br><br>It begs the question..."Why"?&nbsp; Any functionality present in the 2010 CUI that was not present in the 2006 CUI is going to be worthless isn't it?<br>]]>
   <pubDate>Fri, 25 May 2012 22:46:25 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=7880&amp;PID=20353&amp;title=cui-to-mnu#20353</guid>
   <title><![CDATA[CUI to MNU : My next question about CUI to...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=7880&amp;PID=20334&amp;title=cui-to-mnu#20334</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=281836">mtslights</a><br /><strong>Subject:</strong> 7880<br /><strong>Posted:</strong> 24.May.2012 at 23:30<br /><br />My next question about CUI to MNU:<div>I am trying to convert back a custom CUIX file to use on previous AutoCAD versions.</div><div>When I unzip the CUIX file from AutoCAD 2010, there are 20 CUI files in there.</div><div>In order to make a single CUI file that will work in AutoCAD 2006, can I just combine all the text in those files into a single CUI file? &nbsp;Starting with the Header file and inserting the rest before "&lt;/CustSection&gt;"?</div><div>Can I skip the CUI files that don't have any custom information?</div><div>Thanks,</div><div><br></div><div>Mark Simpson</div>]]>
   <pubDate>Thu, 24 May 2012 23:30:44 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=7880&amp;PID=20334&amp;title=cui-to-mnu#20334</guid>
   <title><![CDATA[CUI to MNU : CuitoMnu. I found it. For some...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=7880&amp;PID=20333&amp;title=cui-to-mnu#20333</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=281836">mtslights</a><br /><strong>Subject:</strong> 7880<br /><strong>Posted:</strong> 24.May.2012 at 23:23<br /><br />CuitoMnu. &nbsp;I found it. &nbsp;For some reason the first time I loaded it the text line telling me to type "CuitoMnu" didn't show. &nbsp;After a restart and reload, the instruction popped up.]]>
   <pubDate>Thu, 24 May 2012 23:23:53 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=7880&amp;PID=20333&amp;title=cui-to-mnu#20333</guid>
   <title><![CDATA[CUI to MNU : How to use what utility?   ]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=7880&amp;PID=20332&amp;title=cui-to-mnu#20332</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=165260">John Connor</a><br /><strong>Subject:</strong> 7880<br /><strong>Posted:</strong> 24.May.2012 at 23:18<br /><br />How to use what utility?]]>
   <pubDate>Thu, 24 May 2012 23:18:15 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=7880&amp;PID=20332&amp;title=cui-to-mnu#20332</guid>
   <title><![CDATA[CUI to MNU : Any support documents how to use...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=7880&amp;PID=20330&amp;title=cui-to-mnu#20330</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=281836">mtslights</a><br /><strong>Subject:</strong> 7880<br /><strong>Posted:</strong> 24.May.2012 at 22:12<br /><br />Any support documents how to use this utility? &nbsp;I loaded it into AutoCAD, but what are the commands?<div>Thx,</div><div><br></div><div>Mark Simpson</div>]]>
   <pubDate>Thu, 24 May 2012 22:12:56 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=7880&amp;PID=20330&amp;title=cui-to-mnu#20330</guid>
