  <title>CAD Forum discussion (EN) : Coordinating</title>
  <description><![CDATA[This is an XML content feed of; CAD Forum discussion (EN) : AutoCAD : Coordinating]]></description>
  <pubDate>Sat, 05 Sep 2026 09:24:51 +0000</pubDate>
  <lastBuildDate>Tue, 10 Jun 2008 16:48:04 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum_en/RSS_post_feed.asp?TID=798</WebWizForums:feedURL>
   <title><![CDATA[Coordinating : A cooridnator has many different...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=798&amp;PID=2110&amp;title=coordinating#2110</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=12340">kkrippene</a><br /><strong>Subject:</strong> 798<br /><strong>Posted:</strong> 10.Jun.2008 at 16:48<br /><br />A cooridnator has many different resposibilities depending on the type and size of the buisness.&nbsp; It could mean what the last poster said or it could mean that they are looking for someone who can gather other drawings together and make one complete set of drawings.&nbsp; They will be required to check the drawings for accuracy and completeness.&nbsp; Some coordinators are expected to take on more of a Project Manager role instead of drafting, meaning you won't be drawing, but talking with the people who are drawing to make sure they are doing what is required for the project.]]>
   <pubDate>Tue, 10 Jun 2008 16:48:04 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=798&amp;PID=2110&amp;title=coordinating#2110</guid>
   <title><![CDATA[Coordinating : draughtman is only produce the...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=798&amp;PID=2077&amp;title=coordinating#2077</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=9328">samlimct</a><br /><strong>Subject:</strong> 798<br /><strong>Posted:</strong> 05.Jun.2008 at 00:42<br /><br />draughtman is only produce the drawing, cad coordinator responsible to find the design n data of the cad drawing example give the information to draughtman produce a correct drawing. they also able to check the drawing&nbsp; as well<br><br>]]>
   <pubDate>Thu, 05 Jun 2008 00:42:10 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=798&amp;PID=2077&amp;title=coordinating#2077</guid>
   <title><![CDATA[Coordinating : I guess it&amp;#039;s the guy that...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=798&amp;PID=2076&amp;title=coordinating#2076</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=11861">zotrik</a><br /><strong>Subject:</strong> 798<br /><strong>Posted:</strong> 04.Jun.2008 at 23:30<br /><br />I guess it's the guy that tells other cad drawers what to do...]]>
   <pubDate>Wed, 04 Jun 2008 23:30:20 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=798&amp;PID=2076&amp;title=coordinating#2076</guid>
   <title><![CDATA[Coordinating : Sorry i meant, say when you go...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=798&amp;PID=2074&amp;title=coordinating#2074</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=11918">98wilkinsc</a><br /><strong>Subject:</strong> 798<br /><strong>Posted:</strong> 04.Jun.2008 at 21:33<br /><br />Sorry i meant, say when you go for a job as a cad draftsman and they say they want a coordinator, what does this mean<DIV>&nbsp;</DIV><DIV>Regards</DIV><DIV>Craig</DIV>]]>
   <pubDate>Wed, 04 Jun 2008 21:33:05 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=798&amp;PID=2074&amp;title=coordinating#2074</guid>
   <title><![CDATA[Coordinating : if u understand about math coordinating...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=798&amp;PID=2072&amp;title=coordinating#2072</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=9328">samlimct</a><br /><strong>Subject:</strong> 798<br /><strong>Posted:</strong> 04.Jun.2008 at 17:59<br /><br />if u understand about math coordinating (x,y,z) then&nbsp; u should able to understood the cad coordinating.<br><br>x and y to let u view 2d <br><br>if u want to draw 3d or different elevation on 2d view then u need to use Z coordinate as well.<br><br><br><br><br>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; <br>]]>
   <pubDate>Wed, 04 Jun 2008 17:59:39 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=798&amp;PID=2072&amp;title=coordinating#2072</guid>
   <title><![CDATA[Coordinating : Hello, please could someone help...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=798&amp;PID=2071&amp;title=coordinating#2071</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=11918">98wilkinsc</a><br /><strong>Subject:</strong> 798<br /><strong>Posted:</strong> 04.Jun.2008 at 17:07<br /><br />Hello, please could someone help me out and tell me what exactly Cad Coordinating is and involves.<DIV>&nbsp;</DIV><DIV>&nbsp;</DIV><DIV>Regards</DIV><DIV>Craig</DIV>]]>
   <pubDate>Wed, 04 Jun 2008 17:07:10 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=798&amp;PID=2071&amp;title=coordinating#2071</guid>
