  <title>CAD Forum discussion (EN) : Accociate parts with drawings</title>
  <description><![CDATA[This is an XML content feed of; CAD Forum discussion (EN) : Inventor : Accociate parts with drawings]]></description>
  <pubDate>Sat, 05 Sep 2026 08:20:16 +0000</pubDate>
  <lastBuildDate>Thu, 28 Jun 2012 23:53:04 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum_en/RSS_post_feed.asp?TID=8026</WebWizForums:feedURL>
   <title><![CDATA[Accociate parts with drawings : Renaming parts doesn&amp;#039;t work...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=8026&amp;PID=20726&amp;title=accociate-parts-with-drawings#20726</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=109461">kaomomak</a><br /><strong>Subject:</strong> 8026<br /><strong>Posted:</strong> 28.Jun.2012 at 23:53<br /><br />Renaming parts doesn't work like windows does.<DIV>Renaming parts you will get only errors. It is way how to fix pbut try designer assistant if you dont have vault.</DIV>]]>
   <pubDate>Thu, 28 Jun 2012 23:53:04 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=8026&amp;PID=20726&amp;title=accociate-parts-with-drawings#20726</guid>
   <title><![CDATA[Accociate parts with drawings : No, I am using neither. I simply...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=8026&amp;PID=20709&amp;title=accociate-parts-with-drawings#20709</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=289294">ddredd99</a><br /><strong>Subject:</strong> 8026<br /><strong>Posted:</strong> 27.Jun.2012 at 22:25<br /><br />No, I am using neither.&nbsp; I simply rename them to what I want by doing a save as function, renaming them both exactly the same, but maybe this is not the issue here, I do not know.&nbsp; Thanks.]]>
   <pubDate>Wed, 27 Jun 2012 22:25:45 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=8026&amp;PID=20709&amp;title=accociate-parts-with-drawings#20709</guid>
   <title><![CDATA[Accociate parts with drawings : Are you using Design Assistant...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=8026&amp;PID=20708&amp;title=accociate-parts-with-drawings#20708</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=109461">kaomomak</a><br /><strong>Subject:</strong> 8026<br /><strong>Posted:</strong> 27.Jun.2012 at 18:55<br /><br />Are you using Design Assistant or Vault to rename your parts names?<DIV></DIV>]]>
   <pubDate>Wed, 27 Jun 2012 18:55:19 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=8026&amp;PID=20708&amp;title=accociate-parts-with-drawings#20708</guid>
   <title><![CDATA[Accociate parts with drawings : Hello all, a newby here. I am...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=8026&amp;PID=20668&amp;title=accociate-parts-with-drawings#20668</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=289294">ddredd99</a><br /><strong>Subject:</strong> 8026<br /><strong>Posted:</strong> 25.Jun.2012 at 23:15<br /><br />Hello all, a newby here.&nbsp; I am using inventor 10, and i have no trouble creating a drawing from a part, but it seems if I want to rename the part and drawing, whenever i update something on the part, it fails to show up on the drawing then.&nbsp; is there a way to keep the files associated or reconnect them after i do this?&nbsp; Thanks.<br><br>Dave<br>]]>
   <pubDate>Mon, 25 Jun 2012 23:15:59 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=8026&amp;PID=20668&amp;title=accociate-parts-with-drawings#20668</guid>
