  <title>CAD Forum discussion (EN) : Help my plot rotates?</title>
  <description><![CDATA[This is an XML content feed of; CAD Forum discussion (EN) : AutoCAD : Help my plot rotates?]]></description>
  <pubDate>Sat, 31 Oct 2026 06:19:12 +0000</pubDate>
  <lastBuildDate>Wed, 19 Sep 2012 20:37:20 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum_en/RSS_post_feed.asp?TID=8370</WebWizForums:feedURL>
   <title><![CDATA[Help my plot rotates? :   I works hooray! how silly...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=8370&amp;PID=21553&amp;title=help-my-plot-rotates#21553</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=304990">Gombert</a><br /><strong>Subject:</strong> 8370<br /><strong>Posted:</strong> 19.Sep.2012 at 20:37<br /><br />I works <img src="https://www.cadforum.cz/forum_en/smileys/smiley1.gif" height="17" width="17" border="0" align="absmiddle" alt="Smile" />&nbsp;hooray!&nbsp; how silly i have been not dooing this at first time. thank you wery much.<div>&nbsp;</div><div>&nbsp;</div>]]>
   <pubDate>Wed, 19 Sep 2012 20:37:20 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=8370&amp;PID=21553&amp;title=help-my-plot-rotates#21553</guid>
   <title><![CDATA[Help my plot rotates? : Hello, well done John, it&amp;#039;s...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=8370&amp;PID=21504&amp;title=help-my-plot-rotates#21504</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=175428">philippe JOSEPH</a><br /><strong>Subject:</strong> 8370<br /><strong>Posted:</strong> 14.Sep.2012 at 13:25<br /><br />Hello, well done John, it's after all these years of PDF from AutoCAD that I did realize that what I've been doing on other programs was applicable directly to AutoCAD instead of having to rotate each file from portrait to landscape !!!<DIV></DIV>When you lauch a print&nbsp;from AutoCAD to&nbsp;PDF, go to properties, go to customized properties, go to disposition and there you have portrait OR landscape.]]>
   <pubDate>Fri, 14 Sep 2012 13:25:08 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=8370&amp;PID=21504&amp;title=help-my-plot-rotates#21504</guid>
   <title><![CDATA[Help my plot rotates? : There are only two places where...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=8370&amp;PID=21502&amp;title=help-my-plot-rotates#21502</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=165260">John Connor</a><br /><strong>Subject:</strong> 8370<br /><strong>Posted:</strong> 14.Sep.2012 at 11:26<br /><br />There are only two places where one can specify the orientation of a plot.&nbsp; That would be inside AutoCAD itself and the other is within the properties of the printer being used.&nbsp; Have you checked both?]]>
   <pubDate>Fri, 14 Sep 2012 11:26:35 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=8370&amp;PID=21502&amp;title=help-my-plot-rotates#21502</guid>
   <title><![CDATA[Help my plot rotates? : The first thing I would recommend...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=8370&amp;PID=21501&amp;title=help-my-plot-rotates#21501</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=35918">heinsite</a><br /><strong>Subject:</strong> 8370<br /><strong>Posted:</strong> 14.Sep.2012 at 10:18<br /><br />The first thing I would recommend would be for you to try using the built in DWG to PDF.pc3 Printer/plotter instead of either the Cute or Bullzip driver.<DIV>&nbsp;</DIV><DIV>This will verify for you&nbsp;first that the driver is not the problem.</DIV><DIV>&nbsp;</DIV><DIV>Dave.</DIV>]]>
   <pubDate>Fri, 14 Sep 2012 10:18:15 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=8370&amp;PID=21501&amp;title=help-my-plot-rotates#21501</guid>
   <title><![CDATA[Help my plot rotates? :   Hi, i have problems with my...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=8370&amp;PID=21500&amp;title=help-my-plot-rotates#21500</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=304990">Gombert</a><br /><strong>Subject:</strong> 8370<br /><strong>Posted:</strong> 14.Sep.2012 at 08:53<br /><br />Hi, i have problems with my plottings, whwn i plot to PDF, also to my plotter Cannon IPF 605.<div>The preview is ok, but when it comes "out" the "paper" has turned 90deg. ??</div><div>Last week i uninstallaed the "Cute pdf whrither" and installed Bullzip instead, and i worked wery fine, until to day <img src="https://www.cadforum.cz/forum_en/smileys/smiley7.gif" height="17" width="17" border="0" align="absmiddle" alt="Angry" />&nbsp;i</div><div>&nbsp;</div><div>What can i do?</div>]]>
   <pubDate>Fri, 14 Sep 2012 08:53:12 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=8370&amp;PID=21500&amp;title=help-my-plot-rotates#21500</guid>
