  <title>CAD Forum discussion (EN) : Autocad Electrical 2012</title>
  <description><![CDATA[This is an XML content feed of; CAD Forum discussion (EN) : AutoCAD : Autocad Electrical 2012]]></description>
  <pubDate>Wed, 28 Oct 2026 12:10:10 +0000</pubDate>
  <lastBuildDate>Sat, 22 Sep 2012 15:31:17 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum_en/RSS_post_feed.asp?TID=8383</WebWizForums:feedURL>
   <title><![CDATA[Autocad Electrical 2012 :   Very differant as far as I...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=8383&amp;PID=21587&amp;title=autocad-electrical-2012#21587</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=305764">MikeSr</a><br /><strong>Subject:</strong> 8383<br /><strong>Posted:</strong> 22.Sep.2012 at 15:31<br /><br />Very differant as far as I can tell. When selecting components, you can set the scale factor at that time. Then it will work to your paper space.<div>or</div><div>Scale the drawing such that the rectangle that is drawn to represent the sub panel fits the drawing borders.</div><div>Not exactly sure yet. I purchased the "Autocad Electrical 2012 for Electrical control designers" written by Sham Tickoo of Purdue University. It is an excellant book. But it doesn't cover some particulars like this!</div><div>&nbsp;</div><div>Thanks for you repsonce,&nbsp;in a short time ( I hope)&nbsp;I will post the correct methodology for drawing/object scaling in Acad Electrical.</div><div>&nbsp;</div><div>Kind Regards,<img src="https://www.cadforum.cz/forum_en/smileys/smiley2.gif" height="17" width="17" border="0" align="absmiddle" alt="Wink" /></div>]]>
   <pubDate>Sat, 22 Sep 2012 15:31:17 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=8383&amp;PID=21587&amp;title=autocad-electrical-2012#21587</guid>
   <title><![CDATA[Autocad Electrical 2012 : Hello, I know about AutoCAD and...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=8383&amp;PID=21530&amp;title=autocad-electrical-2012#21530</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=175428">philippe JOSEPH</a><br /><strong>Subject:</strong> 8383<br /><strong>Posted:</strong> 18.Sep.2012 at 07:34<br /><br />Hello, I know about AutoCAD and not AutoCAD Electrical but I guess that it's the same on every sofware :<DIV>You draw or use component drawn at <strong><U>scale 1</U></strong> and set a zoom in the paper space ( in different viewports if different scales ) to have them entering in the sheet dimension that you want to use ( may be US 11""x8.5" or US 17"x11" in your case ).</DIV><DIV>model space and paper space may be difficult to understand but you can do that example :</DIV><DIV>Draw a rectangle of 11"x8.5" in the model space.</DIV><DIV>Make some copies of it, scale the copies at different exact scales and open viewports in the paper space dimension 11"x8.5"&nbsp;+ zooms to set the diffrent scales on that different rectangles&nbsp;( open the viewport, Zoom 1/your scale XP or exact Zoom on the extremities of the rectangles&nbsp;).</DIV><DIV>Please tell us if it's OK or if the concept is not applicable to your AutoCAD Electrical or else...</DIV>]]>
   <pubDate>Tue, 18 Sep 2012 07:34:45 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=8383&amp;PID=21530&amp;title=autocad-electrical-2012#21530</guid>
   <title><![CDATA[Autocad Electrical 2012 : Was ACADE meant to take advantage...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=8383&amp;PID=21529&amp;title=autocad-electrical-2012#21529</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=165260">John Connor</a><br /><strong>Subject:</strong> 8383<br /><strong>Posted:</strong> 18.Sep.2012 at 00:12<br /><br />Was ACADE meant to take advantage of a paper space layout?]]>
   <pubDate>Tue, 18 Sep 2012 00:12:48 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=8383&amp;PID=21529&amp;title=autocad-electrical-2012#21529</guid>
   <title><![CDATA[Autocad Electrical 2012 :   Getting started with ACAD...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=8383&amp;PID=21528&amp;title=autocad-electrical-2012#21528</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=305764">MikeSr</a><br /><strong>Subject:</strong> 8383<br /><strong>Posted:</strong> 17.Sep.2012 at 22:53<br /><br />Getting started with ACAD Elec 2012. Not&nbsp;very experienced with Cad. <div></div>I understand most of the basics in this package, but I can't seem to find information regarding the model space and the paper space.<div></div>EX:. I have a border/title block template (ACAD default) that I am using. When I place an object from "Instert from Schematic List ". The object is full scale or close to it. I either have to draw to full scale and use a viewport to place it in the paper space , or scale the components. either way I am lost. Any help with this would be appreciated.<img src="https://www.cadforum.cz/forum_en/smileys/smiley4.gif" height="17" width="17" border="0" align="absmiddle" alt="Big%20smile" />]]>
   <pubDate>Mon, 17 Sep 2012 22:53:18 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=8383&amp;PID=21528&amp;title=autocad-electrical-2012#21528</guid>
