  <title>CAD Forum discussion (EN) : Viewport Plot Style</title>
  <description><![CDATA[This is an XML content feed of; CAD Forum discussion (EN) : AutoCAD : Viewport Plot Style]]></description>
  <pubDate>Tue, 27 Oct 2026 19:18:50 +0000</pubDate>
  <lastBuildDate>Thu, 25 Oct 2012 08:03:58 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum_en/RSS_post_feed.asp?TID=8427</WebWizForums:feedURL>
   <title><![CDATA[Viewport Plot Style :  The Plot Style setting controls...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=8427&amp;PID=21894&amp;title=viewport-plot-style#21894</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=35918">heinsite</a><br /><strong>Subject:</strong> 8427<br /><strong>Posted:</strong> 25.Oct.2012 at 08:03<br /><br />The Plot Style setting controls the Layout, not the viewport.&nbsp; So you can't control things that way.&nbsp; But you can do a work-around.<br><br>Let's say you have a Layout tab with two (or more) viewports.&nbsp; One of them you want to print with colors.&nbsp; The other one you'd like to print in black and white (monochrome).&nbsp; Here's how I'd do it:<br><br>Set the Layout Plot Style to acad.ctb or one of your own that includes full color.&nbsp; In the viewport that you want to plot B&amp;W activate it (double click inside to enter model space) and open the Layers palette.&nbsp; Modify all the layers VP Color setting to Black.<br><br>When you plot this Layout now you'll have one viewport in color and the other in B&amp;W.&nbsp; It should be easy for you now to use this idea to get what you're after.<br><br>Dave.<br><img src="uploads/20121025_081108_ViewportColors.png" height="507" width="652" border="0" /><br><span style="font-size:10px"><br /><br />Edited by heinsite - 25.Oct.2012 at 08:11</span>]]>
   <pubDate>Thu, 25 Oct 2012 08:03:58 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=8427&amp;PID=21894&amp;title=viewport-plot-style#21894</guid>
   <title><![CDATA[Viewport Plot Style :   When I want a drawing in Monochrome...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=8427&amp;PID=21891&amp;title=viewport-plot-style#21891</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=315784">DBARN</a><br /><strong>Subject:</strong> 8427<br /><strong>Posted:</strong> 24.Oct.2012 at 23:14<br /><br />When I want a drawing in Monochrome and one viewport to be different, I have all viewports (that are to be plotted in Mono) set to wireframe and the vport that&nbsp;I want shaded, conceptual, etc. set as I want.<div>then i plot using monochrome.&nbsp; It works.</div>]]>
   <pubDate>Wed, 24 Oct 2012 23:14:37 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=8427&amp;PID=21891&amp;title=viewport-plot-style#21891</guid>
   <title><![CDATA[Viewport Plot Style : I&amp;#039;m trying to print a viewport...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=8427&amp;PID=21633&amp;title=viewport-plot-style#21633</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=303626">HookahBill</a><br /><strong>Subject:</strong> 8427<br /><strong>Posted:</strong> 26.Sep.2012 at 22:40<br /><br />I'm trying to print a viewport on a different plot style than the rest of the drawing. I noticed that in a viewport's properties there is a "plot style" section, but its grayed out and won't let me change it from "by color".<div><br></div><div>Does anyone know if it is possible to changed the plot style for a viewport? And if so, how?</div>]]>
   <pubDate>Wed, 26 Sep 2012 22:40:34 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=8427&amp;PID=21633&amp;title=viewport-plot-style#21633</guid>
