  <title>CAD Forum discussion (EN) : Landscapes</title>
  <description><![CDATA[This is an XML content feed of; CAD Forum discussion (EN) : AutoCAD : Landscapes]]></description>
  <pubDate>Sat, 05 Sep 2026 09:29:13 +0000</pubDate>
  <lastBuildDate>Tue, 16 Oct 2012 12:33:07 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum_en/RSS_post_feed.asp?TID=8488</WebWizForums:feedURL>
   <title><![CDATA[Landscapes :       Normal   0       ...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=8488&amp;PID=21790&amp;title=landscapes#21790</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=165260">John Connor</a><br /><strong>Subject:</strong> 8488<br /><strong>Posted:</strong> 16.Oct.2012 at 12:33<br /><br /><!--&#091;if gte mso 9&#093;> <w:Word>  <w:View>Normal</w:View>  <w:Zoom>0</w:Zoom>  <w:Punctuati&#111;nKerning/>  <w:ValidateAgainstSchemas/>  <w:SaveIfInvalid>false</w:SaveIfInvalid>  <w:IgnoreMixedC&#111;ntent>false</w:IgnoreMixedC&#111;ntent>  <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText>  <w:Compatibility>   <w:BreakWrappedTables/>   <w:SnapToGridInCell/>   <w:WrapTextWithPunct/>   <w:UseAsianBreakRules/>   <w:D&#111;ntGrowAutofit/>  </w:Compatibility>  <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:Word><!&#091;endif&#093;--><p ="ms&#111;normal"=""><b style="mso-bidi-font-weight:normal"><span style="font-size:10.0pt;font-family:Verdana;color:black">Speed up AutoCAD</span></b><span style="font-size:10.0pt;font-family:Verdana;color:black"><br></span></p><p ="ms&#111;normal"=""><span style="font-size:10.0pt;font-family:Verdana;  color:black"><br>Options&gt; Open and Save &gt; Turn off display digital signature information.</span></p><p ="ms&#111;normal"=""><span style="font-size:10.0pt;font-family:Verdana;  color:black"><br>Check in Layer Manager to make sure you don't have 100's of layer filters, if so delete them.</span></p><p ="ms&#111;normal"=""><span style="font-size:10.0pt;font-family:Verdana;  color:black"><br>Check the Scale List to make sure you don't have 100's of scale lists.</span></p><p ="ms&#111;normal"=""><span style="font-size:10.0pt;font-family:Verdana;  color:black"><br>Don't use True Type Fonts (TTF) and see if that helps, lots of those will slowthings down.</span></p><p ="ms&#111;normal"=""><span style="font-size:10.0pt;font-family:Verdana;  color:black"><br>Go through the file paths in Options&gt;Files and make sure every single pathlisted actually exists, be meticulous.</span></p><p ="ms&#111;normal"=""><span style="font-size:10.0pt;font-family:Verdana;  color:black"><br>Dock the command line in the lower or upper portion of the AutoCAD screen.</span></p><p ="ms&#111;normal"=""><span style="font-size:10.0pt;font-family:Verdana;  color:black"><br>Close the new Layer Manager in 2009. Use LAYERDLGMODE set to 0.</span></p><p ="ms&#111;normal"=""><span style="font-size:10.0pt;font-family:Verdana;  color:black"><br>Use -purge, Regapps, purge all.</span></p><p ="ms&#111;normal"=""><span style="font-size:10.0pt;font-family:Verdana;  color:black"><br> Pick the Enable hardware acceleration to see if that helps. Further down move the sliders over to the left.</span></p><p ="ms&#111;normal"=""><span style="font-size:10.0pt;font-family:Verdana;  color:black"><br>Set LTscale to the proper value, a large drawing with linetypes will slow down when in MS with LTscale set to 1 or a small value.</span></p><p ="ms&#111;normal"=""><span style="font-size:10.0pt;font-family:Verdana;  color:black"><br>Set the virtual memory paging file to a larger size with a min and max rather than letting Windows handle it for you. Custom Size: Initial size = 3X ram (3GB ram = 9GB paging file size), maximum size = 4X ram. <br></span></p><p ="ms&#111;normal"=""><span style="font-size:10.0pt;font-family:Verdana;  color:black"><br>In the same area as immediately listed above, instead of Advanced tab pick Visual Effects tab, pick adjust for best performance, then if youmust go to custom and pick the few settings you can't do without.</span></p><p ="ms&#111;normal"=""><span style="font-size:10.0pt;font-family:Verdana;  color:black"><br>Lower hardware acceleration setting, in Control panel, Display, settings,advanced, troubleshoot, move the hardware acceleration slider to the left one click and try it out, keep moving it right and watching for a change in performance and also fewer crashes. Find a setting you can live with.</span></p><!--&#091;if gte mso 9&#093;> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles><!&#091;endif&#093;--><!--&#091;if gte mso 10&#093;> /* Style Definitions */ table.MsoNormalTable	{mso-style-name:"Table Normal";	mso-tstyle-rowband-size:0;	mso-tstyle-colband-size:0;	mso-style-noshow:yes;	mso-style-parent:"";	mso-padding-alt:0in 5.4pt 0in 5.4pt;	mso-para-margin:0in;	mso-para-margin-bottom:.0001pt;	mso-pagination:widow-orphan;	font-size:10.0pt;	font-family:"Times New Roman";	mso-ansi-language:#0400;	mso-fareast-language:#0400;	mso-bidi-language:#0400;}<!&#091;endif&#093;--><span style="font-size:10px"><br /><br />Edited by John Connor - 16.Oct.2012 at 12:33</span>]]>
   <pubDate>Tue, 16 Oct 2012 12:33:07 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=8488&amp;PID=21790&amp;title=landscapes#21790</guid>
   <title><![CDATA[Landscapes : Thank you John, I&amp;#039;ll try...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=8488&amp;PID=21789&amp;title=landscapes#21789</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=306228">Mimokiller</a><br /><strong>Subject:</strong> 8488<br /><strong>Posted:</strong> 16.Oct.2012 at 12:27<br /><br />Thank you John, I'll try some of them.<br><br>Kind regards!<br>]]>
   <pubDate>Tue, 16 Oct 2012 12:27:45 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=8488&amp;PID=21789&amp;title=landscapes#21789</guid>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=8488&amp;PID=21788&amp;title=landscapes#21788</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=165260">John Connor</a><br /><strong>Subject:</strong> 8488<br /><strong>Posted:</strong> 16.Oct.2012 at 12:25<br /><br /><!--&#091;if gte mso 9&#093;> <w:Word>  <w:View>Normal</w:View>  <w:Zoom>0</w:Zoom>  <w:Punctuati&#111;nKerning/>  <w:ValidateAgainstSchemas/>  <w:SaveIfInvalid>false</w:SaveIfInvalid>  <w:IgnoreMixedC&#111;ntent>false</w:IgnoreMixedC&#111;ntent>  <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText>  <w:Compatibility>   <w:BreakWrappedTables/>   <w:SnapToGridInCell/>   <w:WrapTextWithPunct/>   <w:UseAsianBreakRules/>   <w:D&#111;ntGrowAutofit/>  </w:Compatibility>  <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:Word><!&#091;endif&#093;--><p ="Ms&#111;normal"><b>Speed up Windows 7</b></p><p ="Ms&#111;normal">Disable search indexing feature</p><p ="Ms&#111;normal">Disable Aero theme</p><p ="Ms&#111;normal">Disable unwanted visual effects</p><p ="Ms&#111;normal">Disable unwanted services</p><p ="Ms&#111;normal">Disable User Account Control</p><p ="Ms&#111;normal">Enable ReadyBoost (use USB drive like RAM) <i>This is the best tip.</i><br></p><p ="Ms&#111;normal">Turn off unused features</p><p ="Ms&#111;normal">Disable Sidebar (Gadgets)</p><p ="Ms&#111;normal">Disable Aero Peek and Aero Snap</p><p ="Ms&#111;normal">Change Power Plan to maximum</p><p ="Ms&#111;normal">Disable thumbnail preview</p><p ="Ms&#111;normal">Turn off screen saver and wallpaper</p><p ="Ms&#111;normal">Disable unwanted start-up items</p><p ="Ms&#111;normal">Disable unwanted system sounds</p><!--&#091;if gte mso 9&#093;> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles><!&#091;endif&#093;--><!--&#091;if gte mso 10&#093;> /* Style Definitions */ table.MsoNormalTable	{mso-style-name:"Table Normal";	mso-tstyle-rowband-size:0;	mso-tstyle-colband-size:0;	mso-style-noshow:yes;	mso-style-parent:"";	mso-padding-alt:0in 5.4pt 0in 5.4pt;	mso-para-margin:0in;	mso-para-margin-bottom:.0001pt;	mso-pagination:widow-orphan;	font-size:10.0pt;	font-family:"Times New Roman";	mso-ansi-language:#0400;	mso-fareast-language:#0400;	mso-bidi-language:#0400;}<!&#091;endif&#093;-->]]>
   <pubDate>Tue, 16 Oct 2012 12:25:15 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=8488&amp;PID=21788&amp;title=landscapes#21788</guid>
   <title><![CDATA[Landscapes :  5400 rpm hard drives are notoriously...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=8488&amp;PID=21787&amp;title=landscapes#21787</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=165260">John Connor</a><br /><strong>Subject:</strong> 8488<br /><strong>Posted:</strong> 16.Oct.2012 at 12:14<br /><br />5400 rpm hard drives are notoriously slow.&nbsp; You should have spent a little more and upgraded to a 7200 rpm hard drive or gone with SSD.<br><br>Out of memory errors are a result of an undersized virtual memory setting.<br><br>One of the first things you should do when experiencing a slow computer is turn off all the bells and whistles of the OS then start killing programs that are running in the background.<br><br>Does your laptop use a built-in graphics chip or does it have a dedicated graphics card?<br><br>You might try disabling (temporarily) your anti-virus program too.<br><span style="font-size:10px"><br /><br />Edited by John Connor - 16.Oct.2012 at 12:27</span>]]>
   <pubDate>Tue, 16 Oct 2012 12:14:02 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=8488&amp;PID=21787&amp;title=landscapes#21787</guid>
   <title><![CDATA[Landscapes : &amp;#034;Are you seeing an &amp;#034;out...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=8488&amp;PID=21786&amp;title=landscapes#21786</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=306228">Mimokiller</a><br /><strong>Subject:</strong> 8488<br /><strong>Posted:</strong> 16.Oct.2012 at 12:06<br /><br />"Are you seeing an "out of memory" errors?"<br><i>Not at this laptop, but yes on a 3GbRAM laptop<br><br></i>"What are the full specs of your laptop?"<br><i>W7 64bit, Intel I5 3rd generation, 8 Gb RAM, 750Gb HD at 5400RPM</i><br><br>"What other applications are running in the background?"<br><i>Mozilla firefox, Mozilla thunderbird and Skype</i><br><br>Than you!<br>]]>
   <pubDate>Tue, 16 Oct 2012 12:06:47 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=8488&amp;PID=21786&amp;title=landscapes#21786</guid>
   <title><![CDATA[Landscapes : Are you seeing an &amp;#034;out of...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=8488&amp;PID=21784&amp;title=landscapes#21784</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=165260">John Connor</a><br /><strong>Subject:</strong> 8488<br /><strong>Posted:</strong> 16.Oct.2012 at 11:48<br /><br />Are you seeing an "out of memory" errors?<br><br>What are the full specs of your laptop?<br><br>What is the capacity of your hard drive?&nbsp; What speed is your hard drive?<br><br>What OS are you running?<br><br>What other applications are running in the background?<br>]]>
   <pubDate>Tue, 16 Oct 2012 11:48:36 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=8488&amp;PID=21784&amp;title=landscapes#21784</guid>
   <title><![CDATA[Landscapes : Dear all,I&amp;#039;m making lots...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=8488&amp;PID=21772&amp;title=landscapes#21772</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=306228">Mimokiller</a><br /><strong>Subject:</strong> 8488<br /><strong>Posted:</strong> 15.Oct.2012 at 18:51<br /><br />Dear all,<br><br>I'm making lots of landscapes (more than 20) on a drawing. That drawing have 5 X-refs.<br>My problem is that, when I'm making the landscapes, or working on that, the RAM on my laptop become higher and higher. I have an 8Gb RAM laptop with a 2Gb dedicated video target, but in thatcases the use of RAM memory became of 99% and Autocad starts to run slow.<br><br>Anyone can tell what can be happening?<br><br>Thank you!<br>]]>
   <pubDate>Mon, 15 Oct 2012 18:51:39 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=8488&amp;PID=21772&amp;title=landscapes#21772</guid>
