  <title>CAD Forum discussion (EN) : 2009 to 2013</title>
  <description><![CDATA[This is an XML content feed of; CAD Forum discussion (EN) : AutoCAD : 2009 to 2013]]></description>
  <pubDate>Fri, 17 Jul 2026 03:23:36 +0000</pubDate>
  <lastBuildDate>Mon, 17 Dec 2012 15:56:41 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum_en/RSS_post_feed.asp?TID=8744</WebWizForums:feedURL>
   <title><![CDATA[2009 to 2013 :   John Connor wrote:Don&amp;#039;t...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=8744&amp;PID=22377&amp;title=2009-to-2013#22377</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=314675">mmaurigi</a><br /><strong>Subject:</strong> 8744<br /><strong>Posted:</strong> 17.Dec.2012 at 15:56<br /><br /><table width="99%"><tr><td class="BBquote"><img src="forum_images/quote_box.png" title="Originally posted by John Connor" alt="Originally posted by John Connor" style="vertical-align: text-bottom;" /> <strong>John Connor wrote:</strong><br /><br />Don't use Extrude use PressPull.</td></tr></table> <DIV></DIV><DIV></DIV><DIV></DIV><DIV>That worked! Thanks.</DIV>]]>
   <pubDate>Mon, 17 Dec 2012 15:56:41 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=8744&amp;PID=22377&amp;title=2009-to-2013#22377</guid>
   <title><![CDATA[2009 to 2013 : PressPull will work on lines,...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=8744&amp;PID=22375&amp;title=2009-to-2013#22375</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=165260">John Connor</a><br /><strong>Subject:</strong> 8744<br /><strong>Posted:</strong> 17.Dec.2012 at 14:37<br /><br />PressPull will work on lines, arcs, polylines, and splines.&nbsp; The geometry just has to be closed.&nbsp; It does not have to be represented by a closed polyline or a region.]]>
   <pubDate>Mon, 17 Dec 2012 14:37:10 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=8744&amp;PID=22375&amp;title=2009-to-2013#22375</guid>
   <title><![CDATA[2009 to 2013 : John, thanks for the presspull...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=8744&amp;PID=22374&amp;title=2009-to-2013#22374</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=175428">philippe JOSEPH</a><br /><strong>Subject:</strong> 8744<br /><strong>Posted:</strong> 17.Dec.2012 at 12:31<br /><br />John, thanks for the presspull command information.<DIV>On my french release presspull is not a command so I searched in the AutoCAD dictionnary in the site and didn't find the translation, so I tried _presspull and it worked !</DIV><DIV>Now I will explore that command with it's options.</DIV><DIV>&nbsp;</DIV><DIV>Is there a big difference between extrude and presspull ?</DIV>]]>
   <pubDate>Mon, 17 Dec 2012 12:31:05 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=8744&amp;PID=22374&amp;title=2009-to-2013#22374</guid>
   <title><![CDATA[2009 to 2013 : Don&amp;#039;t use Extrude use PressPull.  ...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=8744&amp;PID=22372&amp;title=2009-to-2013#22372</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=165260">John Connor</a><br /><strong>Subject:</strong> 8744<br /><strong>Posted:</strong> 17.Dec.2012 at 12:00<br /><br />Don't use Extrude use PressPull.]]>
   <pubDate>Mon, 17 Dec 2012 12:00:47 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=8744&amp;PID=22372&amp;title=2009-to-2013#22372</guid>
   <title><![CDATA[2009 to 2013 : Hello, maybe the object that you...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=8744&amp;PID=22369&amp;title=2009-to-2013#22369</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=175428">philippe JOSEPH</a><br /><strong>Subject:</strong> 8744<br /><strong>Posted:</strong> 17.Dec.2012 at 07:38<br /><br />Hello, maybe the object that you are trying to extrude was not a REGION ( altough it's working perfectly with circles and rectangles )&nbsp;but a "simple" closed surface, try to transform your object in a region first. <DIV>Ask for more...</DIV><span style="font-size:10px"><br /><br />Edited by philippe JOSEPH - 17.Dec.2012 at 07:40</span>]]>
   <pubDate>Mon, 17 Dec 2012 07:38:50 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=8744&amp;PID=22369&amp;title=2009-to-2013#22369</guid>
   <title><![CDATA[2009 to 2013 :   My company recently upgraded...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=8744&amp;PID=22368&amp;title=2009-to-2013#22368</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=314675">mmaurigi</a><br /><strong>Subject:</strong> 8744<br /><strong>Posted:</strong> 17.Dec.2012 at 04:12<br /><br />My company recently upgraded from ACAD 2009 to 2013. The one thing I'm having a problem with is in 3D. <div>&nbsp;</div><div>In 2009, I was able to bring a block of a structural steel shape like a channel, explode the block, change the lines and arcs into on polyline and the extrude the shape to whatever length I wanted. When I tried this in 2013, the extrusion was a not a solid, but a hollow surface. What am I doing wrong?</div>]]>
   <pubDate>Mon, 17 Dec 2012 04:12:57 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=8744&amp;PID=22368&amp;title=2009-to-2013#22368</guid>
