  <title>CAD Forum discussion (EN) : Annotative Text</title>
  <description><![CDATA[This is an XML content feed of; CAD Forum discussion (EN) : AutoCAD : Annotative Text]]></description>
  <pubDate>Thu, 22 Oct 2026 21:59:12 +0000</pubDate>
  <lastBuildDate>Thu, 10 Jan 2013 08:35:49 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum_en/RSS_post_feed.asp?TID=8833</WebWizForums:feedURL>
   <title><![CDATA[Annotative Text : Hey, Jess!Glad it works. The first...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=8833&amp;PID=22563&amp;title=annotative-text#22563</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=35918">heinsite</a><br /><strong>Subject:</strong> 8833<br /><strong>Posted:</strong> 10.Jan.2013 at 08:35<br /><br />Hey, Jess!<br><br>Glad it works.&nbsp; The first priority always is to get the job done... whatever it takes.<br>The next priority is to figure out how to do it better the next time. <br><br>You'll always have time for priority #2 if you take care of #1.&nbsp; <img src="https://www.cadforum.cz/forum_en/smileys/smiley2.gif" border="0" align="absmiddle" alt="Wink" /><br><br>Dave<br>]]>
   <pubDate>Thu, 10 Jan 2013 08:35:49 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=8833&amp;PID=22563&amp;title=annotative-text#22563</guid>
   <title><![CDATA[Annotative Text : Hi Dave,  This is what I have...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=8833&amp;PID=22561&amp;title=annotative-text#22561</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=336188">Jessica Healy</a><br /><strong>Subject:</strong> 8833<br /><strong>Posted:</strong> 10.Jan.2013 at 08:10<br /><br />Hi Dave,<DIV>&nbsp;</DIV><DIV>This is what I have ended up doing, not quite my intentions at the start but works for what&nbsp;I need it to do this time as I wont need to edit the text often. </DIV><DIV>&nbsp;</DIV><DIV>Thanks for replying.</DIV><DIV>&nbsp;</DIV><DIV>Jess</DIV>]]>
   <pubDate>Thu, 10 Jan 2013 08:10:52 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=8833&amp;PID=22561&amp;title=annotative-text#22561</guid>
   <title><![CDATA[Annotative Text :    Hi, Jessica!I love annotative...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=8833&amp;PID=22560&amp;title=annotative-text#22560</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=35918">heinsite</a><br /><strong>Subject:</strong> 8833<br /><strong>Posted:</strong> 10.Jan.2013 at 07:48<br /><br />Hi, Jessica!<br><br>I love annotative text questions, so I played with this.&nbsp; I think you can do what you want all in the base file that you'll eventually use as your xref.&nbsp; Simply create the text in that file as you need it.&nbsp; Make the text you want to see at 1:500 annotative at 1:500 and any other text you want to see at 1:1500 annotative at 1:1500.&nbsp; Then save the file.<br><br>When you xref it you'll need to be sure you have 1:500 and 1:1500 scales in the destination drawing.&nbsp; If you don't, create them.&nbsp; But as far as I can see, when you set 1:500 or 1:1500 in the new drawing the correct text from the xref will display the way you'd expect.<br><br>I created a simple example for you.&nbsp; Save this file and xref it into another file to see what happens at the different scale settings.&nbsp; Let me know if this isn't what you're after.<br><br>Dave.<br><br><a href="uploads/20130110_075321_xref_basefile.dwg" target="_blank" rel="nofollow">uploads/20130110_075321_xref_basefile.dwg</a><br><span style="font-size:10px"><br /><br />Edited by heinsite - 10.Jan.2013 at 07:57</span>]]>
   <pubDate>Thu, 10 Jan 2013 07:48:18 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=8833&amp;PID=22560&amp;title=annotative-text#22560</guid>
   <title><![CDATA[Annotative Text : Hi   I trying to create a an...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=8833&amp;PID=22557&amp;title=annotative-text#22557</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=336188">Jessica Healy</a><br /><strong>Subject:</strong> 8833<br /><strong>Posted:</strong> 10.Jan.2013 at 01:25<br /><br />Hi<DIV></DIV><DIV></DIV><DIV></DIV>I trying to create a an xref that contains annotative text (Lot No's), that will allow me to have multiple copies of the text at one scale say (1:500) in different position and a different a different no. of text at different scale say (1:1500).<DIV>&nbsp;</DIV><DIV>Is this possible to do using annotative text or do i need to revert back to the old way of different layers at different scale?</DIV>]]>
   <pubDate>Thu, 10 Jan 2013 01:25:18 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=8833&amp;PID=22557&amp;title=annotative-text#22557</guid>
