  <title>CAD Forum discussion (EN) : Dividing contour lines</title>
  <description><![CDATA[This is an XML content feed of; CAD Forum discussion (EN) : AutoCAD : Dividing contour lines]]></description>
  <pubDate>Mon, 07 Sep 2026 03:50:36 +0000</pubDate>
  <lastBuildDate>Fri, 18 Jan 2013 11:26:14 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum_en/RSS_post_feed.asp?TID=8861</WebWizForums:feedURL>
   <title><![CDATA[Dividing contour lines : Another option would be to reconstruct...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=8861&amp;PID=22630&amp;title=dividing-contour-lines#22630</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=3">Vladimir Michl</a><br /><strong>Subject:</strong> 8861<br /><strong>Posted:</strong> 18.Jan.2013 at 11:26<br /><br />Another option would be to reconstruct the 3D digital terrain model from your contours and then re-create contours (more densely) from the DTM.]]>
   <pubDate>Fri, 18 Jan 2013 11:26:14 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=8861&amp;PID=22630&amp;title=dividing-contour-lines#22630</guid>
   <title><![CDATA[Dividing contour lines : You could use the lisp routine...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=8861&amp;PID=22627&amp;title=dividing-contour-lines#22627</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=73469">CarlB</a><br /><strong>Subject:</strong> 8861<br /><strong>Posted:</strong> 18.Jan.2013 at 08:45<br /><br />You could use the lisp routine from the below site to generate intermediate contours.<br />I don't believe it has options for multiple intermediate contours though. <br /><br />http://www.jefferypsanders.com/autolisp_Rollin.html]]>
   <pubDate>Fri, 18 Jan 2013 08:45:51 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=8861&amp;PID=22627&amp;title=dividing-contour-lines#22627</guid>
   <title><![CDATA[Dividing contour lines : If you don&amp;#039;t have a program...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=8861&amp;PID=22626&amp;title=dividing-contour-lines#22626</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=35918">heinsite</a><br /><strong>Subject:</strong> 8861<br /><strong>Posted:</strong> 18.Jan.2013 at 06:36<br /><br />If you don't have a program like Civil 3D you may be out of luck.&nbsp; You're going to have to draw perpendicular lines between critical areas, divide them into 10 increments, and then fit a spline thru the points.&nbsp; If all you have are two contours to do this with the manual effort shouldn't take too long.&nbsp; If you had a full drawing with many contours it would be a nightmare.&nbsp; But if you need to get the work out I'd attack it this way and look for a better method somewhere on down the line.<br><br>Dave.<br>]]>
   <pubDate>Fri, 18 Jan 2013 06:36:08 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=8861&amp;PID=22626&amp;title=dividing-contour-lines#22626</guid>
   <title><![CDATA[Dividing contour lines : i have two contour lines noting...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=8861&amp;PID=22619&amp;title=dividing-contour-lines#22619</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=338176">edwinjebb</a><br /><strong>Subject:</strong> 8861<br /><strong>Posted:</strong> 17.Jan.2013 at 17:53<br /><br />i have two contour lines noting increments of 1m but i want to divide the space between them evenly so that they read as 100mm roughly. I know this isn't accurate but it gives the topographical idea. Offsetting doesnt work because it needs to be evenly divided in 10 parts at the fat and thin areas.]]>
   <pubDate>Thu, 17 Jan 2013 17:53:03 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=8861&amp;PID=22619&amp;title=dividing-contour-lines#22619</guid>
