  <title>CAD Forum discussion (EN) : Plot styles file path</title>
  <description><![CDATA[This is an XML content feed of; CAD Forum discussion (EN) : AutoCAD : Plot styles file path]]></description>
  <pubDate>Tue, 20 Oct 2026 02:36:38 +0000</pubDate>
  <lastBuildDate>Sat, 19 Jan 2013 15:23:14 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum_en/RSS_post_feed.asp?TID=8868</WebWizForums:feedURL>
   <title><![CDATA[Plot styles file path : Is the path hard coded or relative?...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=8868&amp;PID=22653&amp;title=plot-styles-file-path#22653</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=165260">John Connor</a><br /><strong>Subject:</strong> 8868<br /><strong>Posted:</strong> 19.Jan.2013 at 15:23<br /><br />Is the path hard coded or relative?<br>]]>
   <pubDate>Sat, 19 Jan 2013 15:23:14 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=8868&amp;PID=22653&amp;title=plot-styles-file-path#22653</guid>
   <title><![CDATA[Plot styles file path : One quick solution would be to...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=8868&amp;PID=22648&amp;title=plot-styles-file-path#22648</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=35918">heinsite</a><br /><strong>Subject:</strong> 8868<br /><strong>Posted:</strong> 19.Jan.2013 at 08:25<br /><br />One quick solution would be to send the files to your boss via eTransmit.&nbsp; That will ensure that everything needed to recreate and print the file will be included.<br><br>It doesn't answer your question however.<br><br>Dave<br>]]>
   <pubDate>Sat, 19 Jan 2013 08:25:18 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=8868&amp;PID=22648&amp;title=plot-styles-file-path#22648</guid>
   <title><![CDATA[Plot styles file path : Very strange problem concerning...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=8868&amp;PID=22644&amp;title=plot-styles-file-path#22644</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=338483">hipichik75</a><br /><strong>Subject:</strong> 8868<br /><strong>Posted:</strong> 18.Jan.2013 at 20:51<br /><br /><font face="Georgia, Times New Roman, Times, serif" size="2"><span style="line-height: 1.4;">Very strange problem concerning Plot Styles.</span></font><p ="Ms&#111;normal"><font face="Georgia, Times New Roman, Times, serif" size="2"><o:p></o:p></font></p><p ="Ms&#111;normal"><font face="Georgia, Times New Roman, Times, serif" size="2">I have a drawing with many paper space sheets.&nbsp; All these sheets have been created from thesame template.&nbsp; If someone tries to plotthis drawing from their computer, some sheets find the correct file path for theplot table, but some sheets do not.&nbsp; Becauseof this, my boss cannot plot the whole drawing herself.<o:p></o:p></font></p><p ="Ms&#111;normal"><font face="Georgia, Times New Roman, Times, serif" size="2">How can I make sure every page is set to the correct filepath?<o:p></o:p></font></p><p ="Ms&#111;normal" style="margin-bottom:0in;margin-bottom:.0001pt"><font face="Georgia, Times New Roman, Times, serif" size="2">Thanks,<o:p></o:p></font></p><p ="Ms&#111;normal" style="margin-bottom:0in;margin-bottom:.0001pt"><font face="Georgia, Times New Roman, Times, serif" size="2">Hipi</font><o:p></o:p></p>]]>
   <pubDate>Fri, 18 Jan 2013 20:51:52 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=8868&amp;PID=22644&amp;title=plot-styles-file-path#22644</guid>
