  <title>CAD Forum discussion (EN) : changing base point in block</title>
  <description><![CDATA[This is an XML content feed of; CAD Forum discussion (EN) : AutoCAD : changing base point in block]]></description>
  <pubDate>Sun, 06 Sep 2026 11:09:21 +0000</pubDate>
  <lastBuildDate>Fri, 25 Jan 2013 04:58:23 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum_en/RSS_post_feed.asp?TID=8890</WebWizForums:feedURL>
   <title><![CDATA[changing base point in block : It&amp;#039;s not that what you&amp;#039;re...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=8890&amp;PID=22688&amp;title=changing-base-point-in-block#22688</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=35918">heinsite</a><br /><strong>Subject:</strong> 8890<br /><strong>Posted:</strong> 25.Jan.2013 at 04:58<br /><br />It's not that what you're doing won't work, it's mostly that the "move" portion of the process is completely unnecessary.&nbsp; You can use the Block Authoring Palette to place a basepoint parameter anywhere you want on the block without worrying about where you are in coordinate space.<br><br>Dave<br>]]>
   <pubDate>Fri, 25 Jan 2013 04:58:23 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=8890&amp;PID=22688&amp;title=changing-base-point-in-block#22688</guid>
   <title><![CDATA[changing base point in block :  could you please upload the...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=8890&amp;PID=22687&amp;title=changing-base-point-in-block#22687</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=339836">power22200can</a><br /><strong>Subject:</strong> 8890<br /><strong>Posted:</strong> 25.Jan.2013 at 04:37<br /><br />could you please upload the block and&nbsp;mention&nbsp;where you want to put base point on it,&nbsp;so i can see why it can't be done?<div>&nbsp;</div>]]>
   <pubDate>Fri, 25 Jan 2013 04:37:57 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=8890&amp;PID=22687&amp;title=changing-base-point-in-block#22687</guid>
   <title><![CDATA[changing base point in block :   power22200can wrote:  then...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=8890&amp;PID=22685&amp;title=changing-base-point-in-block#22685</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=35918">heinsite</a><br /><strong>Subject:</strong> 8890<br /><strong>Posted:</strong> 25.Jan.2013 at 03:35<br /><br /><table width="99%"><tr><td class="BBquote"><img src="forum_images/quote_box.png" title="Originally posted by power22200can" alt="Originally posted by power22200can" style="vertical-align: text-bottom;" /> <strong>power22200can wrote:</strong><br /><br /><DIV>&nbsp;</DIV><DIV>then slect all and pick the point&nbsp;(i usually turn object snap on, to get the exact point) and move to "0,0,0" location.</DIV><DIV>&nbsp;</DIV><DIV></td></tr></table> </DIV><DIV>&nbsp;</DIV><DIV>Here is where this idea runs into trouble:&nbsp; Let's say you've been working in a drawing and you decide you need a block.&nbsp; So you draw the object in the model.&nbsp; Then you select it and enter the block editor.&nbsp; When you originally drew it you were FAR&nbsp;from 0,0... maybe somewhere out like x=150,000 and y=250,000.&nbsp; This is not uncommon.&nbsp; Then you finish and&nbsp;save that block with the basepoint at 0,0 without noticing the coordinates on your object.&nbsp; Oops.&nbsp; </DIV><DIV>&nbsp;</DIV><UL><LI>What do you suppose happens now when you insert this block somewhere else in the drawing and you check the&nbsp;box for "Specify&nbsp;on-screen"? <LI>What happens if you turn the "Specify on-screen" checkbox off and insert?</LI></UL><DIV>&nbsp;</DIV><DIV>Answer:&nbsp;&nbsp;Problems either way.</DIV><DIV>&nbsp;</DIV><DIV>If you are planning on xref'g drawings as blocks into other drawings, everything should be referenced to a common 0,0 basepoint, yes, because it's like pin registration.&nbsp; And if&nbsp;you create your original block geometry entirely in the block editor somewhere close to&nbsp;0,0 you can use 0,0 and&nbsp;get&nbsp;acceptable results.&nbsp; But if your object geometry is&nbsp;out in the boonies&nbsp;there's trouble&nbsp;up&nbsp;ahead!&nbsp; In&nbsp;general,&nbsp;blocks should have a basepoint somewhere on&nbsp;their geometry or things can quickly run off the rails.&nbsp;</DIV><DIV>&nbsp;</DIV><DIV>Dave.</DIV><span style="font-size:10px"><br /><br />Edited by heinsite - 25.Jan.2013 at 03:44</span>]]>
   <pubDate>Fri, 25 Jan 2013 03:35:30 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=8890&amp;PID=22685&amp;title=changing-base-point-in-block#22685</guid>
   <title><![CDATA[changing base point in block :  here is what i use, it&amp;#039;s...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=8890&amp;PID=22684&amp;title=changing-base-point-in-block#22684</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=339836">power22200can</a><br /><strong>Subject:</strong> 8890<br /><strong>Posted:</strong> 25.Jan.2013 at 02:33<br /><br />here is what i use, it's the easiest and the quickest way of doing it.<div></div><ol><li>use command and type "bedit" and "enter" it will take you there for block editing</li><li>then slect all and pick the point&nbsp;(i usually turn object snap on, to get the exact point) and move to "0,0,0" location.</li><li>then exit and save.</li></ol><p>that's what i found, it's quickest and easiest way (it might not be the right way).</p>]]>
   <pubDate>Fri, 25 Jan 2013 02:33:52 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=8890&amp;PID=22684&amp;title=changing-base-point-in-block#22684</guid>
   <title><![CDATA[changing base point in block : From the website of Ellen Finkelstein...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=8890&amp;PID=22680&amp;title=changing-base-point-in-block#22680</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=165260">John Connor</a><br /><strong>Subject:</strong> 8890<br /><strong>Posted:</strong> 24.Jan.2013 at 11:34<br /><br />From the website of Ellen Finkelstein noted AutoCAD author:<br><br>"Use the BASE command in the drawing containing the block to specify the origin of the drawing, which is usually on an object snap somewhere on the block. Then, when you insert the drawing, your basepoint will be right on the block."]]>
   <pubDate>Thu, 24 Jan 2013 11:34:54 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=8890&amp;PID=22680&amp;title=changing-base-point-in-block#22680</guid>
   <title><![CDATA[changing base point in block : You have a couple of options,...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=8890&amp;PID=22679&amp;title=changing-base-point-in-block#22679</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=35918">heinsite</a><br /><strong>Subject:</strong> 8890<br /><strong>Posted:</strong> 24.Jan.2013 at 07:58<br /><br />You have a couple of options, depending on what you really want to do.<br><br>1.&nbsp; If the block has an inconvenient basepoint location and you want to change it to somewhere else, open the block editor and make sure the Block Authoring Palettes (BAUTHORPALLET at the command line or from the ribbon) is open.&nbsp; Select the Parameters tab and then put a new Basepoint parameter in the block where you'd like it.<br><br>2.&nbsp; If you want to make a block with *multiple* insertion points (many basepoints if you will), follow all of Step 1 above, but instead of selecting Basepoint, select the Point parameter.&nbsp; Put Points in where ever you might want an insertion point for the block.&nbsp; Then when you insert this block, tap the Ctrl key to cycle thru the different alternate insertion points until you get the one you need.<br><br>Dave.<br><br><span style="font-size:10px"><br /><br />Edited by heinsite - 24.Jan.2013 at 07:59</span>]]>
   <pubDate>Thu, 24 Jan 2013 07:58:14 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=8890&amp;PID=22679&amp;title=changing-base-point-in-block#22679</guid>
   <title><![CDATA[changing base point in block : Hi friends   Plz explain how to...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=8890&amp;PID=22678&amp;title=changing-base-point-in-block#22678</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=252928">Pradeeshvb</a><br /><strong>Subject:</strong> 8890<br /><strong>Posted:</strong> 24.Jan.2013 at 07:41<br /><br />Hi friends<div>&nbsp; &nbsp;</div><div>&nbsp; &nbsp; Plz explain how to change base point of a block.</div><div>The block is inserted in several places in a drawing otherwise i can explode it and create new block.</div><div>Plzz help me..<br><br></div><div><img src="https://www.cadforum.cz/forum_en/smileys/smiley19.gif" border="0" alt="Cry" title="Cry" /><br></div><div><br></div>]]>
   <pubDate>Thu, 24 Jan 2013 07:41:15 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=8890&amp;PID=22678&amp;title=changing-base-point-in-block#22678</guid>
