  <title>CAD Forum discussion (EN) : Model Import Accuracy Problem!</title>
  <description><![CDATA[This is an XML content feed of; CAD Forum discussion (EN) : AutoCAD : Model Import Accuracy Problem!]]></description>
  <pubDate>Mon, 19 Oct 2026 22:11:13 +0000</pubDate>
  <lastBuildDate>Fri, 11 Jul 2008 02:02:15 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum_en/RSS_post_feed.asp?TID=891</WebWizForums:feedURL>
   <title><![CDATA[Model Import Accuracy Problem! : Hello, I need help on importing...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=891&amp;PID=2312&amp;title=model-import-accuracy-problem#2312</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=14344">rsanabria80</a><br /><strong>Subject:</strong> 891<br /><strong>Posted:</strong> 11.Jul.2008 at 02:02<br /><br />Hello, I need help on importing a 3D model from Autocad 2008 to Autodesk 3D Studio Max 9 32-bit... I am modeling a mall and I have been using the extrude tool on AutoCad for every object.. When I try to import my model to 3D Studio Max i get a very unprecise model losing many of the object thickness and some uniform objects turn into an object composed by many irregular subobjects... I used to use older versions of Autocad and 3D Studio Max without problems, but now I don't get to have an accurate model... <br>I can send an image of how does the model looks like on 3dsMax..<br><br>Please help me out with this... <br>]]>
   <pubDate>Fri, 11 Jul 2008 02:02:15 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=891&amp;PID=2312&amp;title=model-import-accuracy-problem#2312</guid>
