  <title>CAD Forum discussion (EN) : Help with Annotative text</title>
  <description><![CDATA[This is an XML content feed of; CAD Forum discussion (EN) : AutoCAD : Help with Annotative text]]></description>
  <pubDate>Wed, 21 Oct 2026 18:18:29 +0000</pubDate>
  <lastBuildDate>Fri, 01 Mar 2013 09:33:43 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum_en/RSS_post_feed.asp?TID=9005</WebWizForums:feedURL>
   <title><![CDATA[Help with Annotative text : Remember, that if you set the...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9005&amp;PID=22935&amp;title=help-with-annotative-text#22935</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=35918">heinsite</a><br /><strong>Subject:</strong> 9005<br /><strong>Posted:</strong> 01.Mar.2013 at 09:33<br /><br />Remember, that if you set the Model space scale to 1:1 and enter annotative text, it will only show up in paper space if your viewport scale is also set to 1:1.&nbsp; You can of course associate (I call it "map") other scales to that particular text object.&nbsp; Those objects will also display in both Model space and in paper space viewports when the associated scales are set.<br><br>In only sounds confusing until it sinks in.&nbsp; <br><br>Dave.<br>]]>
   <pubDate>Fri, 01 Mar 2013 09:33:43 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9005&amp;PID=22935&amp;title=help-with-annotative-text#22935</guid>
   <title><![CDATA[Help with Annotative text : When you create your annotative...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9005&amp;PID=22934&amp;title=help-with-annotative-text#22934</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=35918">heinsite</a><br /><strong>Subject:</strong> 9005<br /><strong>Posted:</strong> 01.Mar.2013 at 09:28<br /><br />When you create your annotative text style you need to set the paper space text height size to 0.00.&nbsp; It sounds strange, but this is what works.&nbsp; Be sure also to check the Annotative box in the definition.<br><br>Before you enter any text or mtext use the TEXTSIZE command to set the text height.&nbsp; This value will stay for all future text entries until you change it to something else with the TEXTSIZE command again.<br><br>Dave<br>]]>
   <pubDate>Fri, 01 Mar 2013 09:28:59 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9005&amp;PID=22934&amp;title=help-with-annotative-text#22934</guid>
   <title><![CDATA[Help with Annotative text : Hello, I am starting from scratch...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9005&amp;PID=22930&amp;title=help-with-annotative-text#22930</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=335792">KWelton</a><br /><strong>Subject:</strong> 9005<br /><strong>Posted:</strong> 28.Feb.2013 at 20:14<br /><br />Hello,<DIV>I am starting from scratch in AutoCAD 2013 and am trying to set up my text styles. I have set the annotative scale to show 1/4" on paper space, and it is 1:1. The text shows up so small it is unreadable. Can someone help me figure out why this is? </DIV><DIV>Thank you. </DIV>]]>
   <pubDate>Thu, 28 Feb 2013 20:14:31 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9005&amp;PID=22930&amp;title=help-with-annotative-text#22930</guid>
