  <title>CAD Forum discussion (EN) : DWG to DXF</title>
  <description><![CDATA[This is an XML content feed of; CAD Forum discussion (EN) : AutoCAD : DWG to DXF]]></description>
  <pubDate>Sun, 17 May 2026 14:51:17 +0000</pubDate>
  <lastBuildDate>Tue, 12 Mar 2013 16:45:38 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum_en/RSS_post_feed.asp?TID=9032</WebWizForums:feedURL>
   <title><![CDATA[DWG to DXF : Hello Dave, 	I will look more...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9032&amp;PID=23026&amp;title=dwg-to-dxf#23026</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=314221">kenjg</a><br /><strong>Subject:</strong> 9032<br /><strong>Posted:</strong> 12.Mar.2013 at 16:45<br /><br />Hello Dave,&nbsp;<!--  bmi_SafeAdd&#079;nload(bmi_load,"bmi_orig_img",0);//--><div><br></div><div><span ="Apple-tab-span" style="white-space:pre">	</span>I will look more into this issue and let you know how/what etc things come out. &nbsp;Thanks a million for your reply and advice. &nbsp;Take care and see you soon with more "Q's".</div><div><br></div><div><br></div><div>KenJG</div><div>AutoCad 2009&nbsp;</div><div><br></div>]]>
   <pubDate>Tue, 12 Mar 2013 16:45:38 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9032&amp;PID=23026&amp;title=dwg-to-dxf#23026</guid>
   <title><![CDATA[DWG to DXF : Hi, Ken!You might be over thinking...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9032&amp;PID=23009&amp;title=dwg-to-dxf#23009</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=35918">heinsite</a><br /><strong>Subject:</strong> 9032<br /><strong>Posted:</strong> 10.Mar.2013 at 22:39<br /><br />Hi, Ken!<br><br>You might be over thinking this.&nbsp; I wouldn't accuse you of anything like that if I wasn't guilty of it myself sometimes.&nbsp; But here's the thing:&nbsp; I don't think you need to worry about the model space scales when sending the DXF file to your machinist.&nbsp; The 1:1 and 1:10 (which is what I used for dimensioning the drawing) don't make a difference - don't change the model - if you've drawn everything full scale.&nbsp; The scales are just there to make annotation easy.<br><br>I used a DIMSTYLE modified from one of my typical ones and did dimensioning with the model scale set to 1:10.&nbsp; From what I can see this will print this full part quite easily on ANSI A paper (or larger).<br><br>I redrew the part and dimensioned it to match your tolerance settings.&nbsp; No critique from me on that because I'm not familiar with machine work ... but I duplicated what you did as best I could.&nbsp; I mapped each dimension object to both 1:1 and 1:10 scales.&nbsp; What you'll see in the attachment is probably what bothered you too... things look "good" at 1:10 but really small and useless at 1:1.&nbsp; But the real dimensions of the DXF model (check them with MEASUREGEOM) don't change regardless of the scale setting.&nbsp; This is the important part.&nbsp; Without knowing what your machinist is doing or what software he's using at least this tells you the part should be the right size.<br><br>Let us know if that last assumption is incorrect.<br><br>Dave.<br><br><a href="uploads/35918/machinist.zip" target="_blank" rel="nofollow">uploads/35918/machinist.zip</a> <br>]]>
   <pubDate>Sun, 10 Mar 2013 22:39:22 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9032&amp;PID=23009&amp;title=dwg-to-dxf#23009</guid>
   <title><![CDATA[DWG to DXF : Hello Dave,	Thank you very much...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9032&amp;PID=23007&amp;title=dwg-to-dxf#23007</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=314221">kenjg</a><br /><strong>Subject:</strong> 9032<br /><strong>Posted:</strong> 10.Mar.2013 at 17:06<br /><br />Hello Dave,&nbsp;<div><br></div><div><span ="Apple-tab-span" style="white-space:pre">	</span>Thank you very much for the info. &nbsp;First of all, I just started ACAD drawings just about 6 months ago. &nbsp;Previously I just used to edit drawings here and there, very simple stuff. &nbsp;Now I'm taking full&nbsp;responsibility&nbsp;of doing them myself which is not easy , but not to hard either. &nbsp;</div><div><br></div><div>I first did the drawings at 1:1 scaling. &nbsp;Since some of the parts are small I&nbsp;re-sized&nbsp;them for printing purposes as well as for the&nbsp;machinist. &nbsp;We&nbsp;recently&nbsp;switch to a new&nbsp;machinist&nbsp;and he requires them 1:1 and in DXF format. The DWG to DXF was no problem but the dims -(lines, arrows, tolerances etc.) seem to reset&nbsp;themselves&nbsp;when I do an update to also reduce to the size to match the 1:1 scale drawing. &nbsp;I know I can change ALL the dim settings manually. &nbsp;So my big questions how can I do this when I&nbsp;re-size&nbsp;the drawing.</div><div><br></div><div>I have attached a screenshot of a drawing converted to DXF and not&nbsp;re-sized&nbsp;and the other re-sized 1:1</div><div><br></div><div>Hope this helps.</div><div><br></div><div><a href="uploads/314221/Downloads.rar" target="_blank" rel="nofollow">uploads/314221/Downloads.rar</a><br></div><div><br></div><div>Best Regards</div><div>KenJG</div>]]>
   <pubDate>Sun, 10 Mar 2013 17:06:38 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9032&amp;PID=23007&amp;title=dwg-to-dxf#23007</guid>
   <title><![CDATA[DWG to DXF : Ken, wait... what? You&amp;#039;re...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9032&amp;PID=23003&amp;title=dwg-to-dxf#23003</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=35918">heinsite</a><br /><strong>Subject:</strong> 9032<br /><strong>Posted:</strong> 09.Mar.2013 at 12:13<br /><br />Ken, wait... what?&nbsp; You're drawing isn't full scale to start with?&nbsp; Not 1:1?!&nbsp; That's a no-no if so.&nbsp; It might also be your problem.&nbsp; Everything should always be drawn as if it's real size... even if you're dimensioning something out to the moon; it should be real scale... 238,900 miles (384,400 km).<br><br>When you change the drawing scale in Model space you're not affecting the size of the drawing linework at all.&nbsp; Real units are still in play.&nbsp; What's really happening is that the scale is there for Annotative scaling of annotative objects such as text notes or dimensions.&nbsp; You can provide dimensions, notes, and other object in model space at 1:1 if you want (and if the machinist wants), but they will be large objects quite possibly.&nbsp; But you can also put dimensions, notes, etc in at other scales for yourself for your own uses.&nbsp; If you don't want the machinist to see them you can use a variety of tricks to do that.<br><br>If we're still missing the point, post a couple sample files showing what you're doing and what's happening.&nbsp; I have a feeling the solution may be simple but we're missing a couple pieces of key info.<br><br>Dave.<br><span style="font-size:10px"><br /><br />Edited by heinsite - 09.Mar.2013 at 12:18</span>]]>
   <pubDate>Sat, 09 Mar 2013 12:13:14 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9032&amp;PID=23003&amp;title=dwg-to-dxf#23003</guid>
   <title><![CDATA[DWG to DXF : Hello John,I need to convert my...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9032&amp;PID=22997&amp;title=dwg-to-dxf#22997</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=314221">kenjg</a><br /><strong>Subject:</strong> 9032<br /><strong>Posted:</strong> 08.Mar.2013 at 15:22<br /><br />Hello John,<div><br></div><div>I need to convert my DWG to DXF files for the machinist who requires these to be in the DXF format. &nbsp;I'm not&nbsp;familiar&nbsp;with what programs they use. &nbsp;My main issue as stated before is that when I&nbsp;re-size&nbsp;the drawing back to 1:1 scale and update the size of text, arrows, lines etc. I lose some dimension settings. &nbsp;I then need to add back in some formatting of these which basically means I'm re-dimensioning the drawing again.</div><div><br></div><div>What I would like to do is when I resise the drawing ALL the data remains the same.</div><div><br></div><div>For ex: &nbsp;I have a dim with plus or minus dim, but when I update the dimension with the correct text size I lose those dims.</div><div><br></div><div><br></div><div>Thanks &amp; Regards</div><div>KenJG</div>]]>
   <pubDate>Fri, 08 Mar 2013 15:22:27 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9032&amp;PID=22997&amp;title=dwg-to-dxf#22997</guid>
   <title><![CDATA[DWG to DXF : Easy way? There&amp;#039;s AutoDesk&amp;#039;s...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9032&amp;PID=22994&amp;title=dwg-to-dxf#22994</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=165260">John Connor</a><br /><strong>Subject:</strong> 9032<br /><strong>Posted:</strong> 08.Mar.2013 at 15:06<br /><br />Easy way?&nbsp; There's AutoDesk's way and then there is.........nothing else.&nbsp; AutoDesk created the DXF file format and everyone adopted it.<br><br>Who are you exchanging drawings with and what program are they using that you are required to save to the DXF file format?<br><span style="font-size:10px"><br /><br />Edited by John Connor - 08.Mar.2013 at 15:06</span>]]>
   <pubDate>Fri, 08 Mar 2013 15:06:03 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9032&amp;PID=22994&amp;title=dwg-to-dxf#22994</guid>
   <title><![CDATA[DWG to DXF : Hello All,I was giving the task...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9032&amp;PID=22992&amp;title=dwg-to-dxf#22992</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=314221">kenjg</a><br /><strong>Subject:</strong> 9032<br /><strong>Posted:</strong> 08.Mar.2013 at 05:28<br /><br />Hello All,&nbsp;<div><br></div><div>I was giving the task of converting DWG files to DXF. &nbsp;Here's what I have quesiton on.</div><div><br></div><div>1. The DWG file was created with certain formats such as text, arrow, lines types as well as the drawing being in a diff scale, ex: 2:1. &nbsp;Later changed to 1:1 for the DXF file.</div><div><br></div><div>2. When I convert the file, which was straight forward, no I lost all my settings as describes above. &nbsp;For ex: &nbsp;I have some dims with tolerances, but now gone. &nbsp;</div><div><br></div><div>3. &nbsp;I think I might know the answer but I'm going to ask anyways. &nbsp;Is there an EASY way of changing the DWG to DXF without losing any formats?</div><div>I'm sure more info is needed, please ask.</div><div><br></div><div>Thanks</div><div>KenJG</div><div><br></div>]]>
   <pubDate>Fri, 08 Mar 2013 05:28:01 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9032&amp;PID=22992&amp;title=dwg-to-dxf#22992</guid>
