  <title>CAD Forum discussion (EN) : 2D &amp; 3D conversion issues</title>
  <description><![CDATA[This is an XML content feed of; CAD Forum discussion (EN) : AutoCAD : 2D &amp; 3D conversion issues]]></description>
  <pubDate>Thu, 22 Oct 2026 15:11:02 +0000</pubDate>
  <lastBuildDate>Thu, 21 Mar 2013 10:57:21 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum_en/RSS_post_feed.asp?TID=9063</WebWizForums:feedURL>
   <title><![CDATA[2D &amp; 3D conversion issues : I made your profile a region. ]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9063&amp;PID=23091&amp;title=2d-3d-conversion-issues#23091</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=165260">John Connor</a><br /><strong>Subject:</strong> 9063<br /><strong>Posted:</strong> 21.Mar.2013 at 10:57<br /><br />I made your profile a region.<br>]]>
   <pubDate>Thu, 21 Mar 2013 10:57:21 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9063&amp;PID=23091&amp;title=2d-3d-conversion-issues#23091</guid>
   <title><![CDATA[2D &amp; 3D conversion issues : Thanks. It worked fine. Can you...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9063&amp;PID=23088&amp;title=2d-3d-conversion-issues#23088</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=355637">azbopeep</a><br /><strong>Subject:</strong> 9063<br /><strong>Posted:</strong> 21.Mar.2013 at 01:53<br /><br />Thanks. It worked fine. Can you tell me what you did?<br><br>Bob<br><br><a href="uploads/355637/WindowSillShelf.zip" target="_blank" rel="nofollow">uploads/355637/WindowSillShelf.zip</a><br>]]>
   <pubDate>Thu, 21 Mar 2013 01:53:35 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9063&amp;PID=23088&amp;title=2d-3d-conversion-issues#23088</guid>
   <title><![CDATA[2D &amp; 3D conversion issues : Here you go. Your casing profile...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9063&amp;PID=23081&amp;title=2d-3d-conversion-issues#23081</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=165260">John Connor</a><br /><strong>Subject:</strong> 9063<br /><strong>Posted:</strong> 20.Mar.2013 at 12:33<br /><br />Here you go.&nbsp; Your casing profile as a region.&nbsp; Use the Extrude command to give it height.&nbsp; You might want to change to a southeast isometric view to see it better.<br><br><a href="uploads/165260/Casing2000.dwg" target="_blank" rel="nofollow">uploads/165260/Casing2000.dwg</a>]]>
   <pubDate>Wed, 20 Mar 2013 12:33:06 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9063&amp;PID=23081&amp;title=2d-3d-conversion-issues#23081</guid>
   <title><![CDATA[2D &amp; 3D conversion issues : I clicked on some of your geometry...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9063&amp;PID=23079&amp;title=2d-3d-conversion-issues#23079</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=165260">John Connor</a><br /><strong>Subject:</strong> 9063<br /><strong>Posted:</strong> 20.Mar.2013 at 11:15<br /><br />I clicked on some of your geometry only to find it is a 3D face.&nbsp; What is the reasoning behind that?<br><br>AutoCAD 2000?&nbsp; Argh.<br><br>Well if you had something a bit more recent you could use the PressPull command to create a 3D solid model from your profile but you don't.&nbsp; That means you would normally use the Extrude command but because you used 3D faces all you'll get is a surface.<br><br>Recreate the profile using lines or polylines and arcs.&nbsp; Use the Pedit command to join everything into a single, continuous entity then use the Extrude command to give it some height.&nbsp; The result will be a 3D solid.<br><br>I'd only use surfaces if I were doing something like a sheetmetal product.&nbsp; Looks like you are attempting to create a wood casing which, if memory serves me correctly, can be cut with a saw meaning the casing would be solid wood through and through.&nbsp; Solid wood = 3D solid in my mind.&nbsp; Your's too?<br>]]>
   <pubDate>Wed, 20 Mar 2013 11:15:26 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9063&amp;PID=23079&amp;title=2d-3d-conversion-issues#23079</guid>
   <title><![CDATA[2D &amp; 3D conversion issues : How do I turn a bunch of lines...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9063&amp;PID=23078&amp;title=2d-3d-conversion-issues#23078</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=355637">azbopeep</a><br /><strong>Subject:</strong> 9063<br /><strong>Posted:</strong> 20.Mar.2013 at 09:50<br /><br />How do I turn a bunch of lines in a plane to a solid? There are so many entity names (region, surface, group, hatch. etc.) that I have major trouble just getting from lines to a 2D surface. Once I get there, I need to extrude this somehow into my 3D solid. Until I do this point, AutoCAD won't let me miter the corners by subtracting 3Dprisms. How do I get to this point?<br><br>Thanks,<br>Bob<br><a href="uploads/355637/ColonialCasing.dwg" target="_blank" rel="nofollow">uploads/355637/ColonialCasing.dwg</a><br>]]>
   <pubDate>Wed, 20 Mar 2013 09:50:54 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9063&amp;PID=23078&amp;title=2d-3d-conversion-issues#23078</guid>
