  <title>CAD Forum discussion (EN) : 3D Cylinders in ACAD 2011</title>
  <description><![CDATA[This is an XML content feed of; CAD Forum discussion (EN) : AutoCAD : 3D Cylinders in ACAD 2011]]></description>
  <pubDate>Fri, 04 Sep 2026 23:00:31 +0000</pubDate>
  <lastBuildDate>Tue, 09 Apr 2013 18:27:10 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum_en/RSS_post_feed.asp?TID=9118</WebWizForums:feedURL>
   <title><![CDATA[3D Cylinders in ACAD 2011 : Use the SLICE command then. Or...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9118&amp;PID=23237&amp;title=3d-cylinders-in-acad-2011#23237</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=165260">John Connor</a><br /><strong>Subject:</strong> 9118<br /><strong>Posted:</strong> 09.Apr.2013 at 18:27<br /><br />Use the SLICE command then.&nbsp; Or sweep a circle along a path that represents a 90 degree corner.&nbsp; Either or both should work.<br><span style="font-size:10px"><br /><br />Edited by John Connor - 09.Apr.2013 at 18:28</span>]]>
   <pubDate>Tue, 09 Apr 2013 18:27:10 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9118&amp;PID=23237&amp;title=3d-cylinders-in-acad-2011#23237</guid>
   <title><![CDATA[3D Cylinders in ACAD 2011 :  John,Thanks for the help. I...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9118&amp;PID=23235&amp;title=3d-cylinders-in-acad-2011#23235</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=359149">GHiatt</a><br /><strong>Subject:</strong> 9118<br /><strong>Posted:</strong> 09.Apr.2013 at 15:37<br /><br />John,<div>&nbsp;</div><div>Thanks for the help.&nbsp; I am trying create an "L" shape where the cylinders are cleaned up at the corner, rather than the "T" that you described.</div><div>&nbsp;</div><div>Thanks!</div>]]>
   <pubDate>Tue, 09 Apr 2013 15:37:23 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9118&amp;PID=23235&amp;title=3d-cylinders-in-acad-2011#23235</guid>
   <title><![CDATA[3D Cylinders in ACAD 2011 : The original cylinders are on...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9118&amp;PID=23218&amp;title=3d-cylinders-in-acad-2011#23218</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=165260">John Connor</a><br /><strong>Subject:</strong> 9118<br /><strong>Posted:</strong> 05.Apr.2013 at 18:26<br /><br /><img src="uploads/165260/MiteredCylinders.JPG" height="523" width="582" border="0" /><br>The original cylinders are on the left.&nbsp; The mitered ones are on the right.<br><span style="font-size:10px"><br /><br />Edited by John Connor - 05.Apr.2013 at 18:27</span>]]>
   <pubDate>Fri, 05 Apr 2013 18:26:05 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9118&amp;PID=23218&amp;title=3d-cylinders-in-acad-2011#23218</guid>
   <title><![CDATA[3D Cylinders in ACAD 2011 : Copy your original objects twice.In...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9118&amp;PID=23217&amp;title=3d-cylinders-in-acad-2011#23217</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=165260">John Connor</a><br /><strong>Subject:</strong> 9118<br /><strong>Posted:</strong> 05.Apr.2013 at 17:36<br /><br />Copy your original objects twice.<br><br>In the first pair of cylinders subtract cylinder A from cylinder B.<br><br>In the second pair of cylinders subtract cylinder B from cylinder A.<br><br>Combine the results.&nbsp; If you like what you got erase the original cylinders.&nbsp; If you don't start over and use a different technique.<br><span style="font-size:10px"><br /><br />Edited by John Connor - 05.Apr.2013 at 18:24</span>]]>
   <pubDate>Fri, 05 Apr 2013 17:36:59 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9118&amp;PID=23217&amp;title=3d-cylinders-in-acad-2011#23217</guid>
   <title><![CDATA[3D Cylinders in ACAD 2011 :  I am new to 3D, and would like...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9118&amp;PID=23215&amp;title=3d-cylinders-in-acad-2011#23215</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=359149">GHiatt</a><br /><strong>Subject:</strong> 9118<br /><strong>Posted:</strong> 05.Apr.2013 at 17:05<br /><br />I am new to 3D, and would like to join 2 cylinders at right angles to one another, and clean up the corners where they intersect, so that the appear mitered.&nbsp; Any suggestions?<div>&nbsp;</div><div>Thanks for the great forum.</div>]]>
   <pubDate>Fri, 05 Apr 2013 17:05:49 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9118&amp;PID=23215&amp;title=3d-cylinders-in-acad-2011#23215</guid>
