  <title>CAD Forum discussion (EN) : True View Converter</title>
  <description><![CDATA[This is an XML content feed of; CAD Forum discussion (EN) : AutoCAD : True View Converter]]></description>
  <pubDate>Fri, 04 Sep 2026 23:21:11 +0000</pubDate>
  <lastBuildDate>Sat, 13 Apr 2013 03:14:12 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum_en/RSS_post_feed.asp?TID=9135</WebWizForums:feedURL>
   <title><![CDATA[True View Converter :    Hi,everything is working...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9135&amp;PID=23278&amp;title=true-view-converter#23278</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=297983">Gill39</a><br /><strong>Subject:</strong> 9135<br /><strong>Posted:</strong> 13.Apr.2013 at 03:14<br /><br /><font face="Times New Roman" size="3"></font><p ="MsoNormal" style="margin: 0in 0in 10pt;"><font face="Calibri" size="3">Hi,&nbsp;everything &nbsp;is working fine now; I just wish Auto Cad wouldcreate software that would be compatible with all versions <span style="mso-spacerun: yes;">&nbsp;</span><span style="mso-spacerun: yes;">&nbsp;</span>insteadof developing new software every year to make a profit. Thank you so much forall your time and effort I really appreciate all the help. </font></p><font face="Times New Roman" size="3"></font><font face="Calibri" size="3"><p ="MsoNormal" style="margin: 0in 0in 10pt;">Kind Regards</p></font><p ="MsoNormal" style="margin: 0in 0in 10pt;"><font face="Calibri" size="3">Gill</font><font face="Times New Roman" size="3"></font></p><p ="MsoNormal" style="margin: 0in 0in 10pt;"><?: prefix = "o" ns = "urn:schemas-microsoft-com:office:office" /><o:p><font face="Calibri" size="3">&nbsp;</font></o:p></p><font face="Times New Roman" size="3"></font>]]>
   <pubDate>Sat, 13 Apr 2013 03:14:12 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9135&amp;PID=23278&amp;title=true-view-converter#23278</guid>
   <title><![CDATA[True View Converter :  Found these discussions:http...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9135&amp;PID=23274&amp;title=true-view-converter#23274</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=73469">CarlB</a><br /><strong>Subject:</strong> 9135<br /><strong>Posted:</strong> 12.Apr.2013 at 19:20<br /><br />Found these discussions:<div><a href="http://forums.augi.com/showthread.php?104445-remove-Trueview-as-Default" target="_blank" rel="nofollow">http://forums.augi.com/showthread.php?104445-remove-Trueview-as-Default</a></div><div><a href="http://www.cadtutor.net/forum/archive/index.php/t-70162.html?s=9c13c69d407ba66f6476402de6ae557c" target="_blank" rel="nofollow">http://www.cadtutor.net/forum/archive/index.php/t-70162.html?s=9c13c69d407ba66f6476402de6ae557c</a></div><div>&nbsp;</div><div>Didn't read it all. Looks like one way is to not double-click on file name, rather start AutoCAD LT, then browse to file.</div>]]>
   <pubDate>Fri, 12 Apr 2013 19:20:09 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9135&amp;PID=23274&amp;title=true-view-converter#23274</guid>
   <title><![CDATA[True View Converter :    Hi, thank you for your reply....]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9135&amp;PID=23271&amp;title=true-view-converter#23271</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=297983">Gill39</a><br /><strong>Subject:</strong> 9135<br /><strong>Posted:</strong> 12.Apr.2013 at 17:54<br /><br /><font face="Times New Roman" size="3"></font><p ="MsoNormal" style="margin: 0in 0in 10pt;"><font face="Calibri" size="3">Hi, thank you for your reply. I should have mention thatI have set AC 2008LT as the default program to open DWG, also when â€śopen withâ€ťAC LT,&nbsp;DWG file will only open in theTrue View program?</font></p><font face="Times New Roman" size="3"></font>]]>
   <pubDate>Fri, 12 Apr 2013 17:54:40 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9135&amp;PID=23271&amp;title=true-view-converter#23271</guid>
   <title><![CDATA[True View Converter : Sounds like you need to change...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9135&amp;PID=23265&amp;title=true-view-converter#23265</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=73469">CarlB</a><br /><strong>Subject:</strong> 9135<br /><strong>Posted:</strong> 12.Apr.2013 at 04:40<br /><br />Sounds like you need to change a windows setting so Autocad lt is the default program for opening .dwg files. <br />You also could right click on a dwg file, "open with" then select AC LT. <br />]]>
   <pubDate>Fri, 12 Apr 2013 04:40:43 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9135&amp;PID=23265&amp;title=true-view-converter#23265</guid>
   <title><![CDATA[True View Converter :     Hi, I use AutoCAD 2008...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9135&amp;PID=23264&amp;title=true-view-converter#23264</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=297983">Gill39</a><br /><strong>Subject:</strong> 9135<br /><strong>Posted:</strong> 12.Apr.2013 at 04:32<br /><br /><font size="3">&nbsp; <font face="Times New Roman"></font></font><p ="MsoNormal" style="margin: 0in 0in 10pt;"><font face="Calibri" size="3">Hi, I use AutoCAD 2008 LT for creating electrical drawings.I have no problem with the program and have created many good quality drawingsfor my customers. What Iâ€™m having a problem is when I receive a DWG from a architector try to use blocks from trusted web site that are created <span style="mso-spacerun: yes;">&nbsp;</span>in a more recent version of Acad. I downloadedTrue View DWG from Autodesk to convert. When I download the program all my DWGfile will only open in the True View program and Iâ€™m not able to open any of thefile that were sent . Any help would be appreciated. </font></p><font face="Times New Roman" size="3"></font>]]>
   <pubDate>Fri, 12 Apr 2013 04:32:34 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9135&amp;PID=23264&amp;title=true-view-converter#23264</guid>
