  <title>CAD Forum discussion (EN) : Dim Deviation Tolerance</title>
  <description><![CDATA[This is an XML content feed of; CAD Forum discussion (EN) : CAD - general : Dim Deviation Tolerance]]></description>
  <pubDate>Fri, 14 Aug 2026 13:06:37 +0000</pubDate>
  <lastBuildDate>Sat, 13 Apr 2013 16:11:49 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum_en/RSS_post_feed.asp?TID=9140</WebWizForums:feedURL>
   <title><![CDATA[Dim Deviation Tolerance : Hello All,I have a general question.I...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9140&amp;PID=23283&amp;title=dim-deviation-tolerance#23283</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=314221">kenjg</a><br /><strong>Subject:</strong> 9140<br /><strong>Posted:</strong> 13.Apr.2013 at 16:11<br /><br />Hello All,&nbsp;<div><br></div><div>I have a general question.</div><div><br></div><div>I have a PDF file I'm re-drawing into CAD form and I show a HOLE with the following dims</div><div><br></div><div>1.98 H7. The H7 is upward of the dim, not right next to it. I think it reads a + something and - 0.000</div><div><br></div><div>I read that the H7 is a tolerance of 0.0025mm. I had the part made using this dim and the part (2mm Dowel Pin) slides easily in the hole. I measured th Pins and they are all 2mm.</div><div><br></div><div>What is H7?</div><div><br></div><div>Thanks in Advance.</div><div><br></div><div>KenJG<img src="uploads/314221/Hole_Tolerance.jpg" height="271" width="507" border="0" /></div>]]>
   <pubDate>Sat, 13 Apr 2013 16:11:49 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9140&amp;PID=23283&amp;title=dim-deviation-tolerance#23283</guid>
