  <title>CAD Forum discussion (EN) : Can&#039;t get AutoCAD 2011 started</title>
  <description><![CDATA[This is an XML content feed of; CAD Forum discussion (EN) : AutoCAD : Can&#039;t get AutoCAD 2011 started]]></description>
  <pubDate>Tue, 03 Nov 2026 17:50:50 +0000</pubDate>
  <lastBuildDate>Mon, 22 Apr 2013 17:57:26 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum_en/RSS_post_feed.asp?TID=9165</WebWizForums:feedURL>
   <title><![CDATA[Can&#039;t get AutoCAD 2011 started : Yes, I checked before I installed...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9165&amp;PID=23373&amp;title=cant-get-autocad-2011-started#23373</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=365934">kmroyce</a><br /><strong>Subject:</strong> 9165<br /><strong>Posted:</strong> 22.Apr.2013 at 17:57<br /><br />Yes, I checked before I installed the program that I had all of the system requirements. I've got windows 7. I originally started downloading AutoCAD 2013, and when that didn't work I tried AutoCAD 2011.&nbsp;<div><br></div><div>Thanks for the advice, Dave. I'll try it.</div>]]>
   <pubDate>Mon, 22 Apr 2013 17:57:26 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9165&amp;PID=23373&amp;title=cant-get-autocad-2011-started#23373</guid>
   <title><![CDATA[Can&#039;t get AutoCAD 2011 started : If all else fails you may have...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9165&amp;PID=23362&amp;title=cant-get-autocad-2011-started#23362</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=35918">heinsite</a><br /><strong>Subject:</strong> 9165<br /><strong>Posted:</strong> 22.Apr.2013 at 12:41<br /><br />If all else fails you may have to completely remove all things Autodesk from your system.&nbsp; It sounds as if something may still be left that's causing you this trouble.&nbsp; To be sure your system is clean go to the Autodesk AutoCAD Services and Support page <a href="http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&amp;id=2887771&amp;linkID=9240617" target="_blank" rel="nofollow">&gt;HERE&lt;</a> and follow the directions for removal very carefully and completely.<br><br>Then try your installation again.<br><br>Dave.<br>]]>
   <pubDate>Mon, 22 Apr 2013 12:41:22 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9165&amp;PID=23362&amp;title=cant-get-autocad-2011-started#23362</guid>
   <title><![CDATA[Can&#039;t get AutoCAD 2011 started : UAC = User Account Control. It...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9165&amp;PID=23359&amp;title=cant-get-autocad-2011-started#23359</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=165260">John Connor</a><br /><strong>Subject:</strong> 9165<br /><strong>Posted:</strong> 22.Apr.2013 at 11:53<br /><br />UAC = User Account Control.&nbsp; It is a Windows feature.<br><br>Are you running Vista or XP?<br><br>Does your computer meet the specifications for running AutoCAD 2011 in the first place?<br><br>I suppose you could try the REPAIR option.<br>]]>
   <pubDate>Mon, 22 Apr 2013 11:53:30 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9165&amp;PID=23359&amp;title=cant-get-autocad-2011-started#23359</guid>
   <title><![CDATA[Can&#039;t get AutoCAD 2011 started : I used autodesk.comIt&amp;#039;s a...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9165&amp;PID=23348&amp;title=cant-get-autocad-2011-started#23348</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=365934">kmroyce</a><br /><strong>Subject:</strong> 9165<br /><strong>Posted:</strong> 22.Apr.2013 at 00:14<br /><br />I used autodesk.com<br><br>It's a 32 bit<br><br>I have no idea if I disabled UAC or not... mostly because I don't know what that is<br>]]>
   <pubDate>Mon, 22 Apr 2013 00:14:33 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9165&amp;PID=23348&amp;title=cant-get-autocad-2011-started#23348</guid>
   <title><![CDATA[Can&#039;t get AutoCAD 2011 started : What website did you access for...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9165&amp;PID=23346&amp;title=cant-get-autocad-2011-started#23346</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=165260">John Connor</a><br /><strong>Subject:</strong> 9165<br /><strong>Posted:</strong> 22.Apr.2013 at 00:12<br /><br />What website did you access for this download?<br><br>What OS are you running?&nbsp; Is it 32-bit or 64-bit?<br><br>Did you temporarily disable the UAC during installation?<br>]]>
   <pubDate>Mon, 22 Apr 2013 00:12:10 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9165&amp;PID=23346&amp;title=cant-get-autocad-2011-started#23346</guid>
   <title><![CDATA[Can&#039;t get AutoCAD 2011 started : I&amp;#039;ve been trying to download...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9165&amp;PID=23345&amp;title=cant-get-autocad-2011-started#23345</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=365934">kmroyce</a><br /><strong>Subject:</strong> 9165<br /><strong>Posted:</strong> 22.Apr.2013 at 00:06<br /><br />I've been trying to download AutoCAD2011 on my PC with Windows 7 through the free download offered on Autodesk.com. <br><br>I finally got it downloaded and now every time I try an open it this pops up:<br>FATAL ERROR: unhandled Access Violation Writing 0x0064 Exception at 6edd651ah<br>and it won't let me go any further<br><br>any ideas?]]>
   <pubDate>Mon, 22 Apr 2013 00:06:34 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9165&amp;PID=23345&amp;title=cant-get-autocad-2011-started#23345</guid>
