  <title>CAD Forum discussion (EN) : LAYERS ON &amp; OFF</title>
  <description><![CDATA[This is an XML content feed of; CAD Forum discussion (EN) : AutoCAD : LAYERS ON &amp; OFF]]></description>
  <pubDate>Thu, 22 Oct 2026 01:41:18 +0000</pubDate>
  <lastBuildDate>Tue, 11 Sep 2007 08:33:29 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum_en/RSS_post_feed.asp?TID=92</WebWizForums:feedURL>
   <title><![CDATA[LAYERS ON &amp; OFF : Hi Vladimir  What i&amp;#039;m basically...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=92&amp;PID=221&amp;title=layers-on-off#221</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=371">GaryM</a><br /><strong>Subject:</strong> 92<br /><strong>Posted:</strong> 11.Sep.2007 at 08:33<br /><br />Hi Vladimir<DIV>&nbsp;</DIV><DIV>What i'm basically doing is converting a lisp routine into VBA. So its a about 6 compiled routines i'm trying to make convert into 1 vba routine.</DIV><DIV>&nbsp;</DIV><DIV>Thanks</DIV><DIV>&nbsp;</DIV><DIV>&nbsp;</DIV>]]>
   <pubDate>Tue, 11 Sep 2007 08:33:29 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=92&amp;PID=221&amp;title=layers-on-off#221</guid>
   <title><![CDATA[LAYERS ON &amp; OFF : You don&amp;#039;t need any VBA for...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=92&amp;PID=213&amp;title=layers-on-off#213</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=3">Vladimir Michl</a><br /><strong>Subject:</strong> 92<br /><strong>Posted:</strong> 10.Sep.2007 at 08:12<br /><br />You don't need any VBA for this. Just use a simple menu macro:<DIV>&nbsp;</DIV><DIV><strong>_-LAYER;_OFF;FFA_*,FCA_*;;</strong></DIV><DIV>&nbsp;</DIV>]]>
   <pubDate>Mon, 10 Sep 2007 08:12:46 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=92&amp;PID=213&amp;title=layers-on-off#213</guid>
   <title><![CDATA[LAYERS ON &amp; OFF : Hi guys  Working in autocad...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=92&amp;PID=211&amp;title=layers-on-off#211</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=371">GaryM</a><br /><strong>Subject:</strong> 92<br /><strong>Posted:</strong> 10.Sep.2007 at 07:55<br /><br />Hi guys<DIV>&nbsp;</DIV><DIV>Working in autocad 2008, would like to switch off certain layers and turn on certain layers with a command button in VBA. For example:</DIV><DIV>&nbsp;</DIV><DIV>There is more than one layer that starts with "FFA_" is there a way i can use that text to switch off all the layers starting with "FFA_" and all Layers starting with "FCA_" in one command.</DIV><DIV>&nbsp;</DIV><DIV>&nbsp;</DIV><DIV>Thanks</DIV>]]>
   <pubDate>Mon, 10 Sep 2007 07:55:06 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=92&amp;PID=211&amp;title=layers-on-off#211</guid>
