  <title>CAD Forum discussion (EN) : New to the forum..</title>
  <description><![CDATA[This is an XML content feed of; CAD Forum discussion (EN) : AutoCAD : New to the forum..]]></description>
  <pubDate>Sat, 05 Sep 2026 13:54:57 +0000</pubDate>
  <lastBuildDate>Sat, 08 Jun 2013 12:37:18 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum_en/RSS_post_feed.asp?TID=9275</WebWizForums:feedURL>
   <title><![CDATA[New to the forum.. : Can we assume you are working...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9275&amp;PID=23628&amp;title=new-to-the-forum#23628</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=165260">John Connor</a><br /><strong>Subject:</strong> 9275<br /><strong>Posted:</strong> 08.Jun.2013 at 12:37<br /><br />Can we assume you are working in 3D?&nbsp; If so, have you looked at using the Dynamic UCS option?&nbsp; And are you familiar with the PressPull command?<br>]]>
   <pubDate>Sat, 08 Jun 2013 12:37:18 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9275&amp;PID=23628&amp;title=new-to-the-forum#23628</guid>
   <title><![CDATA[New to the forum.. :  I am new to this forum, and...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9275&amp;PID=23627&amp;title=new-to-the-forum#23627</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=381179">wilsonreef</a><br /><strong>Subject:</strong> 9275<br /><strong>Posted:</strong> 08.Jun.2013 at 04:43<br /><br />I am new to this forum, and to AutoCad.&nbsp; I have played around with it for some time, but I'm, by far, not good at it yet.&nbsp; I was wondering how do you pick a surface to work on?&nbsp; Meaning, for example, I have a box and want to put a slot in the top of it 1/4" x 1/4" dp.&nbsp; Then I want to go to the end (either one) and put a slot in the end of the box with the same dimensions.&nbsp; After I make the slot in the top, how do I go to the end and pick that surface to put the slot in the end?&nbsp; <div>Hope I haven't made this too terribly confusing.&nbsp; I will have other questions I'm sure.&nbsp; Thanks for anyone's help.</div><div>&nbsp;</div><div>Carl</div>]]>
   <pubDate>Sat, 08 Jun 2013 04:43:15 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9275&amp;PID=23627&amp;title=new-to-the-forum#23627</guid>
