  <title>CAD Forum discussion (EN) : autocad map3D</title>
  <description><![CDATA[This is an XML content feed of; CAD Forum discussion (EN) : Civil 3D, Map, InfraWorks : autocad map3D]]></description>
  <pubDate>Tue, 29 Sep 2026 01:10:08 +0000</pubDate>
  <lastBuildDate>Wed, 24 Jul 2013 15:35:09 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum_en/RSS_post_feed.asp?TID=9285</WebWizForums:feedURL>
   <title><![CDATA[autocad map3D : Autodesk Infraworks really helps...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9285&amp;PID=24044&amp;title=autocad-map3d#24044</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=391245">andrew_neil</a><br /><strong>Subject:</strong> 9285<br /><strong>Posted:</strong> 24.Jul.2013 at 15:35<br /><br /><span style="color: rgb54, 69, 90; font-size: small; line-height: 18px; : rgb251, 251, 253;">Autodesk Infraworks really helps engineers to make those building models and 3d illustrations.Not just that you can also use it from your mobile if it supports</span><span style="line-height: 18px; : rgb251, 251, 253; font-size: 12px;"><font color="#636466" face="Arial, Helvetica, sans-serif">&nbsp;</font></span><font color="#636466" face="Arial, Helvetica, sans-serif"><span style="font-size: 12px; line-height: 18px;">mobile that supports Building Information Modeling (BIM) workflows.</span></font><div><font color="#636466" face="Arial, Helvetica, sans-serif"><span style="font-size: 12px; line-height: 18px;">Thanks</span></font></div>]]>
   <pubDate>Wed, 24 Jul 2013 15:35:09 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9285&amp;PID=24044&amp;title=autocad-map3d#24044</guid>
   <title><![CDATA[autocad map3D : Can you advise me something on...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9285&amp;PID=23918&amp;title=autocad-map3d#23918</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=381960">sourDK</a><br /><strong>Subject:</strong> 9285<br /><strong>Posted:</strong> 09.Jul.2013 at 06:58<br /><br />Can you advise me something on this project?<div>Really appreciate it</div>]]>
   <pubDate>Tue, 09 Jul 2013 06:58:56 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9285&amp;PID=23918&amp;title=autocad-map3d#23918</guid>
   <title><![CDATA[autocad map3D : Really hard to success with this...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9285&amp;PID=23671&amp;title=autocad-map3d#23671</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=381960">sourDK</a><br /><strong>Subject:</strong> 9285<br /><strong>Posted:</strong> 13.Jun.2013 at 03:48<br /><br />Really hard to success with this research. Wish some solution!<div><br></div>]]>
   <pubDate>Thu, 13 Jun 2013 03:48:16 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9285&amp;PID=23671&amp;title=autocad-map3d#23671</guid>
   <title><![CDATA[autocad map3D : Thx q for your comment. I thought...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9285&amp;PID=23662&amp;title=autocad-map3d#23662</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=381960">sourDK</a><br /><strong>Subject:</strong> 9285<br /><strong>Posted:</strong> 11.Jun.2013 at 16:54<br /><br />Thx q for your comment. I thought like this way too, I don't know whether map3D can make animation or not but I thought it couldn't. So that is why I wanna ask that how can I continue from this step( I have greated with a 2D plan by using that city's GIS data) so to make it becomes 3D I use eventary(height) to Make it become 3D. The problem is building? I don know how to input the building to my 2D plan]]>
   <pubDate>Tue, 11 Jun 2013 16:54:54 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9285&amp;PID=23662&amp;title=autocad-map3d#23662</guid>
   <title><![CDATA[autocad map3D : From my perspective (as a civil...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9285&amp;PID=23660&amp;title=autocad-map3d#23660</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=355362">JSC</a><br /><strong>Subject:</strong> 9285<br /><strong>Posted:</strong> 11.Jun.2013 at 15:52<br /><br />From my perspective (as a civil designer using Civil3D, the Map 3D features embedded in Civil 3D and sometimes Map 3D), I would be surprised to learn that Map 3D can generate an animation. Can it really do that? I thought a more likely Autodesk-centric workflow would call for modeling in C3D and/or Map 3D and then importing that content into 3Ds Max Design for animation. You may end up with a good animation that way, but the skills required to do that are varied &amp; hard to learn if you're not experienced. I'm hoping to use 3Ds Max Design in that way soon, but I see it requires an object enabler (not included with a standard installation) to deal with the C3D objects. Haven't done anything with it yet, but I'm hoping to soon.<br><br>Any attempt to explain specific tasks &amp; steps for a complicated process like this is not likely to work. I think you must first discuss things like what data you have and what you want to accomplish with your animation...<br><br>Joe Carter <br>]]>
   <pubDate>Tue, 11 Jun 2013 15:52:10 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9285&amp;PID=23660&amp;title=autocad-map3d#23660</guid>
   <title><![CDATA[autocad map3D : Could you explain me more specially?...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9285&amp;PID=23654&amp;title=autocad-map3d#23654</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=381960">sourDK</a><br /><strong>Subject:</strong> 9285<br /><strong>Posted:</strong> 11.Jun.2013 at 09:47<br /><br />Could you explain me more specially?]]>
   <pubDate>Tue, 11 Jun 2013 09:47:05 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9285&amp;PID=23654&amp;title=autocad-map3d#23654</guid>
   <title><![CDATA[autocad map3D : It is a quite complicated task....]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9285&amp;PID=23653&amp;title=autocad-map3d#23653</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=3">Vladimir Michl</a><br /><strong>Subject:</strong> 9285<br /><strong>Posted:</strong> 11.Jun.2013 at 09:10<br /><br />It is a quite complicated task. While it is possible to do this in AutoCAD Map 3D, you may get easier results with Autodesk Infraworks.]]>
   <pubDate>Tue, 11 Jun 2013 09:10:21 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9285&amp;PID=23653&amp;title=autocad-map3d#23653</guid>
   <title><![CDATA[autocad map3D : I really complicated in finding...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9285&amp;PID=23652&amp;title=autocad-map3d#23652</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=381960">sourDK</a><br /><strong>Subject:</strong> 9285<br /><strong>Posted:</strong> 11.Jun.2013 at 08:41<br /><br />I really complicated in finding the way to use this software. In fact, I plan to make an animation to show about one city's building, transportation,etc. So I got up with a plan to use autocad map 3d to make a city map. I wonder it is connect to my topic or not. Now i can create a map by using GIS data (SHP files) with elevation data in 3D.<div>Right now, i don't know what to do more? what to learn....<br>As my opinion, i think that it is useful to make 3D building samples to put on the created map.</div><div>&nbsp;Really appreciate with your helpw with this subject. &nbsp;</div><div>&nbsp;</div><div>Sincerely,</div>]]>
   <pubDate>Tue, 11 Jun 2013 08:41:57 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9285&amp;PID=23652&amp;title=autocad-map3d#23652</guid>
