  <title>CAD Forum discussion (EN) : Protect a drawing against editing</title>
  <description><![CDATA[This is an XML content feed of; CAD Forum discussion (EN) : AutoCAD : Protect a drawing against editing]]></description>
  <pubDate>Tue, 03 Nov 2026 03:26:39 +0000</pubDate>
  <lastBuildDate>Mon, 17 Jun 2013 12:55:17 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum_en/RSS_post_feed.asp?TID=9299</WebWizForums:feedURL>
   <title><![CDATA[Protect a drawing against editing : Either by and use CADLock or don&amp;#039;t...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9299&amp;PID=23694&amp;title=protect-a-drawing-against-editing#23694</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=165260">John Connor</a><br /><strong>Subject:</strong> 9299<br /><strong>Posted:</strong> 17.Jun.2013 at 12:55<br /><br />Either by and use CADLock or don't bother sending DWG files.&nbsp; Short of that, nothing you do can't be undone at the other end by a person who is determined.<br>]]>
   <pubDate>Mon, 17 Jun 2013 12:55:17 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9299&amp;PID=23694&amp;title=protect-a-drawing-against-editing#23694</guid>
   <title><![CDATA[Protect a drawing against editing : Does your agreement/contract with...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9299&amp;PID=23692&amp;title=protect-a-drawing-against-editing#23692</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=35918">heinsite</a><br /><strong>Subject:</strong> 9299<br /><strong>Posted:</strong> 16.Jun.2013 at 04:53<br /><br />Does your agreement/contract with the vendor include you providing original CAD files?&nbsp; If not, don't send them.&nbsp; Any time you transmit original CAD files to someone else you run the risk they can change something <b>you</b> are responsible for without your knowledge.&nbsp; Unless you feel okay with this you will always be better off sending drawings in PDF or DWF format.&nbsp; <br><br>If Autodesk really wanted to support a CAD editing lock feature they would do so.&nbsp; But they haven't, and that's enough for me to protect original work unless it's being shared with parties I trust.&nbsp; My advice:&nbsp; Don't rely on 3rd party vendors to protect your critical drawings.<br><br>Dave.<br>]]>
   <pubDate>Sun, 16 Jun 2013 04:53:58 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9299&amp;PID=23692&amp;title=protect-a-drawing-against-editing#23692</guid>
   <title><![CDATA[Protect a drawing against editing : I am a new mamber to the forum....]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9299&amp;PID=23689&amp;title=protect-a-drawing-against-editing#23689</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=383307">ms1679</a><br /><strong>Subject:</strong> 9299<br /><strong>Posted:</strong> 15.Jun.2013 at 09:44<br /><br />I am a new mamber to the forum. I need to send a drawing to one of our vendor and I dont want him to edit the drawing. I have searched the internet and found that by certain addon application (like Cadlock, DWGguard etc.) this is possible. I have downloaded the dwgguard.vlx file and tried to add the same in my machine using appload command, but failed. Cad gives message "error: ARXLOAD failed". I have Auocad Mechanical 2011 in my machine with XP OS.<br /><br />Can anyone help on the matter. <br /><br />I also want to ask that wheather there is any other way to achieve the wanted results. ]]>
   <pubDate>Sat, 15 Jun 2013 09:44:02 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9299&amp;PID=23689&amp;title=protect-a-drawing-against-editing#23689</guid>
