  <title>CAD Forum discussion (EN) : help for surface trim</title>
  <description><![CDATA[This is an XML content feed of; CAD Forum discussion (EN) : AutoCAD : help for surface trim]]></description>
  <pubDate>Wed, 28 Oct 2026 05:58:43 +0000</pubDate>
  <lastBuildDate>Tue, 25 Jun 2013 13:57:15 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum_en/RSS_post_feed.asp?TID=9321</WebWizForums:feedURL>
   <title><![CDATA[help for surface trim : Hello rohit.jain092, I don&amp;#039;t...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9321&amp;PID=23768&amp;title=help-for-surface-trim#23768</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=175428">philippe JOSEPH</a><br /><strong>Subject:</strong> 9321<br /><strong>Posted:</strong> 25.Jun.2013 at 13:57<br /><br />Hello rohit.jain092, I don't know precisely what you want to do with your surfaces and as when you select them, no grips are available but with an UCS&nbsp;seting ( option 3 points to have the good direction ) I was able to "trim" them with the command SUBTRACT by copying a surface and then subtract it to itself ( with a certain distance otherwise you erase it entirely ).<DIV>Hope this will help.</DIV><DIV>Ask for more.</DIV>]]>
   <pubDate>Tue, 25 Jun 2013 13:57:15 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9321&amp;PID=23768&amp;title=help-for-surface-trim#23768</guid>
   <title><![CDATA[help for surface trim : Sorry, must have missed that subtle...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9321&amp;PID=23767&amp;title=help-for-surface-trim#23767</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=165260">John Connor</a><br /><strong>Subject:</strong> 9321<br /><strong>Posted:</strong> 25.Jun.2013 at 12:03<br /><br />Sorry, must have missed that subtle color change in your first post.<br>]]>
   <pubDate>Tue, 25 Jun 2013 12:03:06 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9321&amp;PID=23767&amp;title=help-for-surface-trim#23767</guid>
   <title><![CDATA[help for surface trim : Guys this is the attachmentAttachment...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9321&amp;PID=23765&amp;title=help-for-surface-trim#23765</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=385607">rohit.jain092</a><br /><strong>Subject:</strong> 9321<br /><strong>Posted:</strong> 25.Jun.2013 at 05:55<br /><br />Guys this is the attachment<div><a href="uploads/385607/Test.dwg" target="_blank" rel="nofollow">Attachment</a></div>]]>
   <pubDate>Tue, 25 Jun 2013 05:55:50 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9321&amp;PID=23765&amp;title=help-for-surface-trim#23765</guid>
   <title><![CDATA[help for surface trim : There appears to be no attachment....]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9321&amp;PID=23762&amp;title=help-for-surface-trim#23762</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=165260">John Connor</a><br /><strong>Subject:</strong> 9321<br /><strong>Posted:</strong> 24.Jun.2013 at 19:49<br /><br />There appears to be no attachment.&nbsp; Try again.<br>]]>
   <pubDate>Mon, 24 Jun 2013 19:49:23 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9321&amp;PID=23762&amp;title=help-for-surface-trim#23762</guid>
   <title><![CDATA[help for surface trim : Hi there. I m working in autoCAD&amp;#039;13....]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9321&amp;PID=23757&amp;title=help-for-surface-trim#23757</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=385607">rohit.jain092</a><br /><strong>Subject:</strong> 9321<br /><strong>Posted:</strong> 24.Jun.2013 at 11:51<br /><br /><span style="color: rgb35, 35, 35; font-family: Arial; font-size: 1.181818182em; line-height: 1.3;">Hi there. I m working in autoCAD'13. I have got this drawing from a client. I need to trim these surfaces to get only the outer surfaces. But since these are not intersecting at right angles, i m not able to trim these surfaces.&nbsp;</span><p style="margin: 0px; padding: 0px; font-size: 1.181818182em; line-height: 1.3; color: rgb35, 35, 35; font-family: Arial;">Any help will be highly appreciated.</p><p style="margin: 0px; padding: 0px; font-size: 1.181818182em; line-height: 1.3; color: rgb35, 35, 35; font-family: Arial;">Please find <a href="uploads/385607/Test.dwg" target="_blank" rel="nofollow">attached</a> a small part of the concerned drawing. The intersecting surfaces in the drawing have to be trimmed.</p>]]>
   <pubDate>Mon, 24 Jun 2013 11:51:25 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9321&amp;PID=23757&amp;title=help-for-surface-trim#23757</guid>
