  <title>CAD Forum discussion (EN) : Opening and editing files</title>
  <description><![CDATA[This is an XML content feed of; CAD Forum discussion (EN) : AutoCAD : Opening and editing files]]></description>
  <pubDate>Sat, 05 Sep 2026 03:43:44 +0000</pubDate>
  <lastBuildDate>Thu, 25 Jul 2013 08:30:30 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum_en/RSS_post_feed.asp?TID=9418</WebWizForums:feedURL>
   <title><![CDATA[Opening and editing files : I&amp;#039;m on the same page as Kent....]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9418&amp;PID=24050&amp;title=opening-and-editing-files#24050</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=35918">heinsite</a><br /><strong>Subject:</strong> 9418<br /><strong>Posted:</strong> 25.Jul.2013 at 08:30<br /><br />I'm on the same page as Kent.&nbsp; If you can open the drawing there should be no reason why you can't create new objects.<br><br>Try this:&nbsp; Open the layers palette and set Layer 0 current.&nbsp; Then create a new layer and make it current.&nbsp; Now try and draw something.&nbsp; This does assume that Layer 0 has been effectively left alone in the drawing you got.&nbsp; <br><br>Dave.<br>]]>
   <pubDate>Thu, 25 Jul 2013 08:30:30 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9418&amp;PID=24050&amp;title=opening-and-editing-files#24050</guid>
   <title><![CDATA[Opening and editing files : &amp;lt;&amp;lt; .... I can&amp;#039;t seem...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9418&amp;PID=24027&amp;title=opening-and-editing-files#24027</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=353260">Kent Cooper</a><br /><strong>Subject:</strong> 9418<br /><strong>Posted:</strong> 22.Jul.2013 at 21:08<br /><br />&lt;&lt; .... I can't seem to draw anything ....<DIV>&nbsp;</DIV><DIV>Is the current Layer turned off?&nbsp; As unlikely as anyone would be to do that intentionally, it's possible to achieve that, under certain circumstances.</DIV>]]>
   <pubDate>Mon, 22 Jul 2013 21:08:22 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9418&amp;PID=24027&amp;title=opening-and-editing-files#24027</guid>
   <title><![CDATA[Opening and editing files : There is no library of pre-drawn...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9418&amp;PID=24023&amp;title=opening-and-editing-files#24023</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=165260">John Connor</a><br /><strong>Subject:</strong> 9418<br /><strong>Posted:</strong> 22.Jul.2013 at 18:29<br /><br />There is no library of pre-drawn machines.&nbsp; In all likelihood the industrial engineer either created his own blocks/symbols, downloaded them from a website like this (CADForum) where someone else drew and uploaded them for others like yourself to use for free, or he bought a symbol library from a 3rd-party provided.&nbsp; My guess it was either of the first two.&nbsp; Most people want it for free.<br><br>Can't draw anything?&nbsp; Is the layer you are trying to draw on locked? <br>]]>
   <pubDate>Mon, 22 Jul 2013 18:29:45 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9418&amp;PID=24023&amp;title=opening-and-editing-files#24023</guid>
   <title><![CDATA[Opening and editing files : Hello all,I am currently using...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9418&amp;PID=24022&amp;title=opening-and-editing-files#24022</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=392370">Drexel</a><br /><strong>Subject:</strong> 9418<br /><strong>Posted:</strong> 22.Jul.2013 at 18:01<br /><br />Hello all,<div><br></div><div>I am currently using AutoCAD LT 2013. &nbsp;A building contractor sent me the building layout for a new manufacturing facility. &nbsp;I can open the .dwg file, but I am having trouble drawing additional lines. &nbsp;I am coming up with a floor layout, but I can't seem to draw anything. &nbsp;When I start a new project I can draw without an issue.</div><div><br></div><div>Also, &nbsp;I am looking for guidance when it comes to machine placement. &nbsp;I remember seeing another industrial engineer with 2d machines already drawn and inserted into a layout. &nbsp;At this moment I am looking for pallet racking I can import into my floor model. &nbsp;Does anything like this exist? &nbsp;I thought there mite be a library with pre-drawn machines.</div><div><br></div><div>Thank you,</div><div><br></div><div>Alex</div>]]>
   <pubDate>Mon, 22 Jul 2013 18:01:52 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9418&amp;PID=24022&amp;title=opening-and-editing-files#24022</guid>
