  <title>CAD Forum discussion (EN) : AutoCAD File Naming</title>
  <description><![CDATA[This is an XML content feed of; CAD Forum discussion (EN) : AutoCAD : AutoCAD File Naming]]></description>
  <pubDate>Fri, 06 Nov 2026 01:34:38 +0000</pubDate>
  <lastBuildDate>Tue, 20 Aug 2013 09:46:49 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum_en/RSS_post_feed.asp?TID=9542</WebWizForums:feedURL>
   <title><![CDATA[AutoCAD File Naming : It makes sense to have only one...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9542&amp;PID=24323&amp;title=autocad-file-naming#24323</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=35918">heinsite</a><br /><strong>Subject:</strong> 9542<br /><strong>Posted:</strong> 20.Aug.2013 at 09:46<br /><br />It makes sense to have only one model drawing as it simplifies revisions.&nbsp; If you split them you'd quickly run into all sorts of trouble trying to figure out which file has the revisions you want.&nbsp; But when it comes time to keep track of whether a print is for a client or the fabrication shop you do need another system.<br><br>Have you thought about using the layout tabs themselves to help with print file naming?&nbsp; I like to use the system variable "CTAB" as my Layout name.&nbsp; This is then called somewhere in the title block and gets used whenever I print that sheet to either a PDF or DWF.&nbsp; If you go with John's idea of appending a "D" or "A" to that name you'll always have a set of print files that will easily identify themselves.<br><br>As for the model filename itself... isn't that always going to be the base part number?&nbsp; If so, simply save those files with nothing appended to them.&nbsp; Let the separation happen with printing.&nbsp; This way you can continue to use multiple layouts as you have in the past.<br><br>Dave.<br>]]>
   <pubDate>Tue, 20 Aug 2013 09:46:49 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9542&amp;PID=24323&amp;title=autocad-file-naming#24323</guid>
   <title><![CDATA[AutoCAD File Naming : Then you&amp;#039;ll just have to...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9542&amp;PID=24290&amp;title=autocad-file-naming#24290</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=165260">John Connor</a><br /><strong>Subject:</strong> 9542<br /><strong>Posted:</strong> 16.Aug.2013 at 11:48<br /><br />Then you'll just have to append an "A" or a "D" to the end of each name so you know which is which.<br>]]>
   <pubDate>Fri, 16 Aug 2013 11:48:51 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9542&amp;PID=24290&amp;title=autocad-file-naming#24290</guid>
   <title><![CDATA[AutoCAD File Naming :  I didn&amp;#039;t have any part...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9542&amp;PID=24285&amp;title=autocad-file-naming#24285</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=314675">mmaurigi</a><br /><strong>Subject:</strong> 9542<br /><strong>Posted:</strong> 16.Aug.2013 at 02:28<br /><br />I didn't have any part of the drawing number convention. Company had it in place when I was hired. I would have done something easier.]]>
   <pubDate>Fri, 16 Aug 2013 02:28:21 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9542&amp;PID=24285&amp;title=autocad-file-naming#24285</guid>
   <title><![CDATA[AutoCAD File Naming : Maybe you should have given that...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9542&amp;PID=24280&amp;title=autocad-file-naming#24280</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=165260">John Connor</a><br /><strong>Subject:</strong> 9542<br /><strong>Posted:</strong> 15.Aug.2013 at 23:39<br /><br />Maybe you should have given that some thought when you first started naming your files.&nbsp; Somehow I would have incorporated something that differentiates between an Assembly (Asbly) and a Detail (Dtl).<br>]]>
   <pubDate>Thu, 15 Aug 2013 23:39:08 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9542&amp;PID=24280&amp;title=autocad-file-naming#24280</guid>
   <title><![CDATA[AutoCAD File Naming : I have a drawing (.dwg) file thatconsists...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9542&amp;PID=24279&amp;title=autocad-file-naming#24279</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=314675">mmaurigi</a><br /><strong>Subject:</strong> 9542<br /><strong>Posted:</strong> 15.Aug.2013 at 22:25<br /><br /><P>I have a drawing (.dwg) file that&nbsp;consists of&nbsp;one model with two layout tabs. One layout tab is an assembly drawing (to the client), the other layout tab is the detail drawing (to fabrication shop). We create drawings in this manner using layers that are turned on or off in the layout viewports to be show&nbsp;graphics that might be needed in the detail drawing, but not in the assembly drawing and vise versa. The reason we create drawings this way is so if something changes, we change the model and it changes in both the assembly drawing and detail drawing. Each Layout tab has a unique number as follows:</P><DIV>Assembly: 12345-M-D-2004-001</DIV><DIV>Detail: 12345-M-D-2005-001</DIV><DIV>&nbsp;</DIV><DIV>My problem is how do I create a file name for saving this file on our network&nbsp;that will clearing identify that this file contains the assembly and detail drawings? If they were individual drawings, it would be easy, 12345-M-D-2004-001.dwg and 12345-M-D-2005-001.dwg.</DIV><DIV>&nbsp;</DIV><DIV>I'm looking for suggestions on a file naming convention&nbsp;for drawings with one model and multiple layouts that have unique numbers. Any advise or suggestions is appreciated.</DIV><DIV>&nbsp;</DIV><DIV>Thanks in advance.</DIV>]]>
   <pubDate>Thu, 15 Aug 2013 22:25:39 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9542&amp;PID=24279&amp;title=autocad-file-naming#24279</guid>
