  <title>CAD Forum discussion (EN) : Draftsight buttons</title>
  <description><![CDATA[This is an XML content feed of; CAD Forum discussion (EN) : CAD - general : Draftsight buttons]]></description>
  <pubDate>Tue, 29 Sep 2026 07:56:06 +0000</pubDate>
  <lastBuildDate>Fri, 16 Aug 2013 17:03:08 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum_en/RSS_post_feed.asp?TID=9544</WebWizForums:feedURL>
   <title><![CDATA[Draftsight buttons :  Corner and Slide Polygon?That&amp;#039;s...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9544&amp;PID=24299&amp;title=draftsight-buttons#24299</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=165260">John Connor</a><br /><strong>Subject:</strong> 9544<br /><strong>Posted:</strong> 16.Aug.2013 at 17:03<br /><br /><u>C</u>orner and <u>S</u>lide Polygon?<br><br>That's supposed to be <b>Side</b>.<br><br>One is<b> inscribed</b> within a circle while the other is <b>circumscribed</b> about a circle.&nbsp; That's the difference.&nbsp; I won't tell you which is which.&nbsp; You have to find out for yourself so in the future when you use the command you will know which option to select given the situation you find yourself in.<br><br>By the way, both options (inscribed and circumscribed) are available in AutoCAD.<br><br>Question: Why would coordinate systems be of any use to you in packaging and machine parts?&nbsp; I can understand the use of polygons, tolerances and even jogged dimensions by not coordinates.&nbsp; <br><span style="font-size:10px"><br /><br />Edited by John Connor - 16.Aug.2013 at 17:39</span>]]>
   <pubDate>Fri, 16 Aug 2013 17:03:08 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9544&amp;PID=24299&amp;title=draftsight-buttons#24299</guid>
   <title><![CDATA[Draftsight buttons : &amp;#034;Jog lines are used to represent...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9544&amp;PID=24298&amp;title=draftsight-buttons#24298</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=165260">John Connor</a><br /><strong>Subject:</strong> 9544<br /><strong>Posted:</strong> 16.Aug.2013 at 16:48<br /><br />"<span ="apple-style-span"="" style="border-collapse: separate; color: rgb0, 0, 0; font-family: Arial; font-style: normal; font-variant: normal; font-weight: normal; letter-spacing: normal; line-height: normal; orphans: 2; text-align: auto; text-indent: 0px; text-trans: none; white-space: normal; widows: 2; word-spacing: 0px; -webkit-border-horizontal-spacing: 0px; -webkit-border-vertical-spacing: 0px; -webkit-text-decorations-in-effect: none; -webkit-text-size-adjust: auto; -webkit-text-stroke-width: 0px; font-size: medium; "><span ="apple-style-span"="" style="font-family: Arial, Helvetica, sans-serif; font-size: 13px; text-align: left; ">Jog lines are used to represent a dimension value that does not display the actual measurement in a linear dimension. Typically, the actual measurement value of the dimension is smaller than the displayed value."<br><br>Do you know what a jogged dimension looks like?<br><br>What types of tolerances do you normally deal with?&nbsp; Symmetrical? Deviation?&nbsp; Limits?&nbsp; Basic?&nbsp; Other?&nbsp; Each is depicted differently.<br></span></span><span style="font-size:10px"><br /><br />Edited by John Connor - 16.Aug.2013 at 16:56</span>]]>
   <pubDate>Fri, 16 Aug 2013 16:48:50 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9544&amp;PID=24298&amp;title=draftsight-buttons#24298</guid>
   <title><![CDATA[Draftsight buttons : The best way to find out is through...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9544&amp;PID=24297&amp;title=draftsight-buttons#24297</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=165260">John Connor</a><br /><strong>Subject:</strong> 9544<br /><strong>Posted:</strong> 16.Aug.2013 at 16:44<br /><br />The best way to find out is through trial and error.&nbsp; Start a new drawing and experiment.&nbsp; You won't harm anything because in the end you can close the drawing without saving it.&nbsp; The upside is you'll gain real practical experience and see all the options available to you and test each one.<br><br>And if you have one to two years of experience using AutoCAD then you should already be familiar with these commands (or their equivalents).&nbsp; There isn't much to be found in Draftsight that isn't or hasn't been included in AutoCAD.<br><br>How does one get to Carnagie hall?&nbsp; Practice, practice, practice.<br><span style="font-size:10px"><br /><br />Edited by John Connor - 16.Aug.2013 at 17:34</span>]]>
   <pubDate>Fri, 16 Aug 2013 16:44:42 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9544&amp;PID=24297&amp;title=draftsight-buttons#24297</guid>
   <title><![CDATA[Draftsight buttons : Designs for packaging and machine...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9544&amp;PID=24296&amp;title=draftsight-buttons#24296</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=396157">crelph</a><br /><strong>Subject:</strong> 9544<br /><strong>Posted:</strong> 16.Aug.2013 at 16:30<br /><br />Designs for packaging and machine parts. <br><br>About 1-2 years of experience of AutoCAD. <br><br>Student.<br><br>I understand how you are suppose to use each of the buttons, but I do not know what the buttons affect in the drawing. Can you or anyone else explain that?<br>]]>
   <pubDate>Fri, 16 Aug 2013 16:30:39 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9544&amp;PID=24296&amp;title=draftsight-buttons#24296</guid>
   <title><![CDATA[Draftsight buttons : You want to know &amp;#034;when to...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9544&amp;PID=24295&amp;title=draftsight-buttons#24295</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=165260">John Connor</a><br /><strong>Subject:</strong> 9544<br /><strong>Posted:</strong> 16.Aug.2013 at 16:17<br /><br />You want to know "when to use" each command?&nbsp; I'd have to take a week off from my full time job just to write the first chapter.<br><br>What kind of drawings are you creating?<br><br>Do you have any kind of drafting background at all?<br><br>Are you a student?<br><span style="font-size:10px"><br /><br />Edited by John Connor - 16.Aug.2013 at 16:18</span>]]>
   <pubDate>Fri, 16 Aug 2013 16:17:41 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9544&amp;PID=24295&amp;title=draftsight-buttons#24295</guid>
   <title><![CDATA[Draftsight buttons : Thank you, I have already looked...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9544&amp;PID=24294&amp;title=draftsight-buttons#24294</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=396157">crelph</a><br /><strong>Subject:</strong> 9544<br /><strong>Posted:</strong> 16.Aug.2013 at 16:13<br /><br />Thank you, I have already looked in the getting started guide and the help option. <br><br>The getting Started guide does not tell you when you are suppose to use it to benefit you. I guess I used the wrong questions. Instead knowing the difference, I meant how do you use those buttons? When would you use them when drawing in draftsight?<br><br>I appreciate the videos on youtube. I will look there for more information, but since my questions were so minute I did not think youtube had the answer.<br><br>]]>
   <pubDate>Fri, 16 Aug 2013 16:13:15 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9544&amp;PID=24294&amp;title=draftsight-buttons#24294</guid>
   <title><![CDATA[Draftsight buttons : Your questions are simple enough...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9544&amp;PID=24292&amp;title=draftsight-buttons#24292</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=165260">John Connor</a><br /><strong>Subject:</strong> 9544<br /><strong>Posted:</strong> 16.Aug.2013 at 11:52<br /><br />Your questions are simple enough to be answered using Draftsight Help or the Getting Started Guide.&nbsp; Have you looked at either?<br><br>The difference between Absolute and Relative coordinate system is mentioned on pages 45 and 46 of the Guide.<br><br>Tolerances are mentioned on page 176 of the Guide.<br><br>A jogged dimension is practically self-explanatory.<br><br>By the way, there are also hundreds of YouTube videos about Drfatsight commands.&nbsp; Here is a link to one about the Polygon command.<br><br>http://www.youtube.com/watch?v=zlMmeyCKQSw<br><br>You may also want to avail yourself of the two part Tips, Tricks and Videos Master Series Flipbook found at the Drfatsight Learning Resources.<br><br>http://www.3ds.com/products-services/draftsight/resource-center/tips-tricks/<br><br>Dassault has gone out of its way to provide its users with a wealth of information on how to use its products.&nbsp; I suggest you take full advantage of the content.<br><span style="font-size:10px"><br /><br />Edited by John Connor - 16.Aug.2013 at 12:35</span>]]>
   <pubDate>Fri, 16 Aug 2013 11:52:45 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9544&amp;PID=24292&amp;title=draftsight-buttons#24292</guid>
   <title><![CDATA[Draftsight buttons : What do you use Jogged and Tolerance...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9544&amp;PID=24282&amp;title=draftsight-buttons#24282</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=396157">crelph</a><br /><strong>Subject:</strong> 9544<br /><strong>Posted:</strong> 16.Aug.2013 at 00:31<br /><br />What do you use Jogged and Tolerance Buttons for?<br><br>What is the difference between relative and Absolute coordinates?<br><br>What is the Difference between <u>C</u>orner and <u>S</u>lide Polygon?]]>
   <pubDate>Fri, 16 Aug 2013 00:31:01 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9544&amp;PID=24282&amp;title=draftsight-buttons#24282</guid>
