  <title>CAD Forum discussion (EN) : Scaling</title>
  <description><![CDATA[This is an XML content feed of; CAD Forum discussion (EN) : CAD - general : Scaling]]></description>
  <pubDate>Wed, 30 Sep 2026 01:14:39 +0000</pubDate>
  <lastBuildDate>Fri, 16 Aug 2013 11:51:33 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum_en/RSS_post_feed.asp?TID=9545</WebWizForums:feedURL>
   <title><![CDATA[Scaling : Scales are assigned to viewports...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9545&amp;PID=24291&amp;title=scaling#24291</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=165260">John Connor</a><br /><strong>Subject:</strong> 9545<br /><strong>Posted:</strong> 16.Aug.2013 at 11:51<br /><br />Scales are assigned to viewports in a sheet.&nbsp; Do you have at least one viewport?<br><br>The list in and of itself does not affect anything.&nbsp; It's only use is for assigning viewport scales.&nbsp; It can be edited (you can add or delete scales).<br>]]>
   <pubDate>Fri, 16 Aug 2013 11:51:33 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9545&amp;PID=24291&amp;title=scaling#24291</guid>
   <title><![CDATA[Scaling : When would you change the drawing...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9545&amp;PID=24283&amp;title=scaling#24283</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=396157">crelph</a><br /><strong>Subject:</strong> 9545<br /><strong>Posted:</strong> 16.Aug.2013 at 00:32<br /><br />When would you change the drawing scale list in Draftsight?<br><br>What does the Drawing Scale list affect?<br><br>Thank you in advance.<br>]]>
   <pubDate>Fri, 16 Aug 2013 00:32:13 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9545&amp;PID=24283&amp;title=scaling#24283</guid>
