  <title>CAD Forum discussion (EN) : OLE not plotting</title>
  <description><![CDATA[This is an XML content feed of; CAD Forum discussion (EN) : AutoCAD : OLE not plotting]]></description>
  <pubDate>Sat, 31 Oct 2026 17:09:08 +0000</pubDate>
  <lastBuildDate>Thu, 22 Aug 2013 11:09:26 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum_en/RSS_post_feed.asp?TID=9558</WebWizForums:feedURL>
   <title><![CDATA[OLE not plotting : You say you can get it to print...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9558&amp;PID=24349&amp;title=ole-not-plotting#24349</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=35918">heinsite</a><br /><strong>Subject:</strong> 9558<br /><strong>Posted:</strong> 22.Aug.2013 at 11:09<br /><br />You say you can get it to print correctly to a local printer... can you get it to print equally well as a DWF?&nbsp; If so, from there you should be able to print it properly to any other printer or plotter.<br><br>Dave.<br>]]>
   <pubDate>Thu, 22 Aug 2013 11:09:26 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9558&amp;PID=24349&amp;title=ole-not-plotting#24349</guid>
   <title><![CDATA[OLE not plotting : I think there&amp;#039;s way for resolve...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9558&amp;PID=24345&amp;title=ole-not-plotting#24345</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=398952">ahmad.muammar</a><br /><strong>Subject:</strong> 9558<br /><strong>Posted:</strong> 21.Aug.2013 at 15:14<br /><br />I think there's way for resolve that by going to menu -&gt; then edit -&gt; then select paste special &nbsp;-&gt; then you have to select AutoCAD entries &nbsp;before doing above steps you should go to excel sheet and make copy from your work]]>
   <pubDate>Wed, 21 Aug 2013 15:14:00 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9558&amp;PID=24345&amp;title=ole-not-plotting#24345</guid>
   <title><![CDATA[OLE not plotting : Try inserting it is paper space...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9558&amp;PID=24336&amp;title=ole-not-plotting#24336</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=165260">John Connor</a><br /><strong>Subject:</strong> 9558<br /><strong>Posted:</strong> 20.Aug.2013 at 19:45<br /><br />Try inserting it is paper space instead.<br><br>I too tried AutoTable at one point but it did not do what I needed.&nbsp; Did you look at the Readme file that came with the trial version?<br>]]>
   <pubDate>Tue, 20 Aug 2013 19:45:39 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9558&amp;PID=24336&amp;title=ole-not-plotting#24336</guid>
   <title><![CDATA[OLE not plotting : Model space....Ya, I was looking...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9558&amp;PID=24334&amp;title=ole-not-plotting#24334</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=5081">onlysee2d</a><br /><strong>Subject:</strong> 9558<br /><strong>Posted:</strong> 20.Aug.2013 at 18:53<br /><br />Model space....Ya, I was looking for some 3rd party s/w and the one I found didn't work either (AutoTable)..at least I couldn't get the trial to work...<br>]]>
   <pubDate>Tue, 20 Aug 2013 18:53:24 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9558&amp;PID=24334&amp;title=ole-not-plotting#24334</guid>
   <title><![CDATA[OLE not plotting : That&amp;#039;s one of the reasons...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9558&amp;PID=24333&amp;title=ole-not-plotting#24333</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=165260">John Connor</a><br /><strong>Subject:</strong> 9558<br /><strong>Posted:</strong> 20.Aug.2013 at 18:50<br /><br />That's one of the reasons I avoid using OLE objects.&nbsp; Unfortunately your version of AutoCAD is too old to have the Table &gt; DataLink feature that came along in 2008.&nbsp; <br><br>Is your table in model space or in paper space?<br>]]>
   <pubDate>Tue, 20 Aug 2013 18:50:06 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9558&amp;PID=24333&amp;title=ole-not-plotting#24333</guid>
   <title><![CDATA[OLE not plotting : Yes it will print from excel just...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9558&amp;PID=24330&amp;title=ole-not-plotting#24330</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=5081">onlysee2d</a><br /><strong>Subject:</strong> 9558<br /><strong>Posted:</strong> 20.Aug.2013 at 16:44<br /><br />Yes it will print from excel just fine, whether I print the original or the embedded page (opened from CAD)...I'm trying to figure out the difference between inserting an OLE and just copying and pasting from excel into cad....is there any difference? It shows up on the print preview....it's like it's 'white' and thinks it's printing it...I tried selecting it and changing the color but no change...<br>]]>
   <pubDate>Tue, 20 Aug 2013 16:44:01 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9558&amp;PID=24330&amp;title=ole-not-plotting#24330</guid>
   <title><![CDATA[OLE not plotting : And what happens if you print...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9558&amp;PID=24329&amp;title=ole-not-plotting#24329</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=165260">John Connor</a><br /><strong>Subject:</strong> 9558<br /><strong>Posted:</strong> 20.Aug.2013 at 16:26<br /><br />And what happens if you print directly from Excel?&nbsp; Does the spreadsheet print?<br><span style="font-size:10px"><br /><br />Edited by John Connor - 20.Aug.2013 at 16:27</span>]]>
   <pubDate>Tue, 20 Aug 2013 16:26:30 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9558&amp;PID=24329&amp;title=ole-not-plotting#24329</guid>
   <title><![CDATA[OLE not plotting : I&amp;#039;ve copy and pasted an excel...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9558&amp;PID=24328&amp;title=ole-not-plotting#24328</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=5081">onlysee2d</a><br /><strong>Subject:</strong> 9558<br /><strong>Posted:</strong> 20.Aug.2013 at 16:24<br /><br />I've copy and pasted an excel (office 2003) page into an autocad 2004 drawing, as well as 'inserted' it as an OLE....either way, I can get it to print on my local printer, but not on a (2 different) network printer...it prints the drawing, just not the OLE....I cannot find any printer specific settings that would effect the contents of what's being printed...I'm sure it's something ridiculous....any ideas?]]>
   <pubDate>Tue, 20 Aug 2013 16:24:17 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9558&amp;PID=24328&amp;title=ole-not-plotting#24328</guid>
