  <title>CAD Forum discussion (EN) : match paper space viewport</title>
  <description><![CDATA[This is an XML content feed of; CAD Forum discussion (EN) : AutoCAD : match paper space viewport]]></description>
  <pubDate>Sat, 05 Sep 2026 03:52:05 +0000</pubDate>
  <lastBuildDate>Wed, 04 Sep 2013 14:45:43 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum_en/RSS_post_feed.asp?TID=9592</WebWizForums:feedURL>
   <title><![CDATA[match paper space viewport :  Thank you. VP Freeze seems to...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9592&amp;PID=24502&amp;title=match-paper-space-viewport#24502</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=191872">ncespedes</a><br /><strong>Subject:</strong> 9592<br /><strong>Posted:</strong> 04.Sep.2013 at 14:45<br /><br />Thank you. VP Freeze seems to work.<div></div><div>However, and this would be a complain to AutoCAD/Autodesk, the "match command" should be able to do this. And I should be able to match view ports within a file, at present I can match from one file to another, but can't within the same file (as soon as I change layout it disappears). </div><div>&nbsp;</div><div>Thank you Dave.</div>]]>
   <pubDate>Wed, 04 Sep 2013 14:45:43 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9592&amp;PID=24502&amp;title=match-paper-space-viewport#24502</guid>
   <title><![CDATA[match paper space viewport : If you are having trouble with...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9592&amp;PID=24497&amp;title=match-paper-space-viewport#24497</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=165260">John Connor</a><br /><strong>Subject:</strong> 9592<br /><strong>Posted:</strong> 04.Sep.2013 at 11:33<br /><br />If you are having trouble with your keyboard shortcuts in general try resetting your Profile.<br>]]>
   <pubDate>Wed, 04 Sep 2013 11:33:27 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9592&amp;PID=24497&amp;title=match-paper-space-viewport#24497</guid>
   <title><![CDATA[match paper space viewport : I can&amp;#039;t tell you what you&amp;#039;re...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9592&amp;PID=24491&amp;title=match-paper-space-viewport#24491</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=35918">heinsite</a><br /><strong>Subject:</strong> 9592<br /><strong>Posted:</strong> 04.Sep.2013 at 09:28<br /><br />I can't tell you what you're doing wrong, but I can tell you that what I just tried worked fine.&nbsp; Here's what I did:<br><br>I set up a Layout with a viewport and then activated it (meaning I double-clicked inside the viewport to work in Model space).<br>Then I VPort froze a couple of layers.&nbsp; VP Freeze may be your answer here to creating different vport looks.<br>At this point I Ctrl-Shift Copied the VPort using 0,0 as the base point.<br><br>When I Ctrl-V pasted this vport in another Layout all the settings carried across.<br><br>I don't think it matters how many Layouts you have.&nbsp; But it's important to know what your source viewport is and how things are set before you start copying and pasting.<br><br>Dave. <br>]]>
   <pubDate>Wed, 04 Sep 2013 09:28:17 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9592&amp;PID=24491&amp;title=match-paper-space-viewport#24491</guid>
   <title><![CDATA[match paper space viewport : I&amp;#039;m trying to match viewports...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9592&amp;PID=24441&amp;title=match-paper-space-viewport#24441</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=191872">ncespedes</a><br /><strong>Subject:</strong> 9592<br /><strong>Posted:</strong> 29.Aug.2013 at 22:00<br /><br />I'm trying to match viewports in paper space to inherit the layer set up. All of a sudden I'm not able to do it. The whole story is that I have one file with several layouts and want to match its paperspace viewports. I know that you can't use the match properties within one file, so I created a junk file where I can copy from, but it is not working now. Could it be because I have 20 layouts in the same file?<div>Control-C is not working either, it copies, but I don't carry the original viewport layout. What am I doing wrong?</div>]]>
   <pubDate>Thu, 29 Aug 2013 22:00:41 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9592&amp;PID=24441&amp;title=match-paper-space-viewport#24441</guid>
