  <title>CAD Forum discussion (EN) : Converting Mesh to Solid</title>
  <description><![CDATA[This is an XML content feed of; CAD Forum discussion (EN) : AutoCAD : Converting Mesh to Solid]]></description>
  <pubDate>Fri, 30 Oct 2026 14:29:35 +0000</pubDate>
  <lastBuildDate>Fri, 06 Sep 2013 14:13:03 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum_en/RSS_post_feed.asp?TID=9617</WebWizForums:feedURL>
   <title><![CDATA[Converting Mesh to Solid : I&amp;#039;m using 2013 at the moment....]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9617&amp;PID=24539&amp;title=converting-mesh-to-solid#24539</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=165260">John Connor</a><br /><strong>Subject:</strong> 9617<br /><strong>Posted:</strong> 06.Sep.2013 at 14:13<br /><br />I'm using 2013 at the moment.&nbsp; Like you I was able to convert the 3D model from faces to surfaces but I was unable to convert from surfaces to a solid using two different methods.<br><br>I tried 1) CONVERTOSOLID and 2) SURFSCULPT.&nbsp; Both found inconsistencies in the model they could not handle.<br>]]>
   <pubDate>Fri, 06 Sep 2013 14:13:03 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9617&amp;PID=24539&amp;title=converting-mesh-to-solid#24539</guid>
   <title><![CDATA[Converting Mesh to Solid : Here is another utility by Sycode...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9617&amp;PID=24538&amp;title=converting-mesh-to-solid#24538</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=165260">John Connor</a><br /><strong>Subject:</strong> 9617<br /><strong>Posted:</strong> 06.Sep.2013 at 13:58<br /><br />Here is another utility by Sycode for converting a mesh to a solid.&nbsp; They offer a 7-day version for $19.99 (no free trial).<br><br>http://www.sycode.com/products/mesh_to_solid_ac/index.htm<br><span style="font-size:10px"><br /><br />Edited by John Connor - 06.Sep.2013 at 15:28</span>]]>
   <pubDate>Fri, 06 Sep 2013 13:58:50 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9617&amp;PID=24538&amp;title=converting-mesh-to-solid#24538</guid>
   <title><![CDATA[Converting Mesh to Solid : You might give AUTOMESHER a try....]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9617&amp;PID=24537&amp;title=converting-mesh-to-solid#24537</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=165260">John Connor</a><br /><strong>Subject:</strong> 9617<br /><strong>Posted:</strong> 06.Sep.2013 at 13:41<br /><br />You might give AUTOMESHER a try.&nbsp; Here is a link to the Automapki website where you can download a free, fully functional, 5-day trial version.<br><br>http://www.automapki.com/products/automesher-application.html<br>]]>
   <pubDate>Fri, 06 Sep 2013 13:41:20 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9617&amp;PID=24537&amp;title=converting-mesh-to-solid#24537</guid>
   <title><![CDATA[Converting Mesh to Solid : Did you try AutoCAD 2014&amp;#039;s...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9617&amp;PID=24536&amp;title=converting-mesh-to-solid#24536</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=165260">John Connor</a><br /><strong>Subject:</strong> 9617<br /><strong>Posted:</strong> 06.Sep.2013 at 12:59<br /><br />Did you try AutoCAD 2014's Mesh to Solid?<br><br>What was the problem using the polyhedral app?&nbsp; Did it error out?<br>]]>
   <pubDate>Fri, 06 Sep 2013 12:59:58 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9617&amp;PID=24536&amp;title=converting-mesh-to-solid#24536</guid>
   <title><![CDATA[Converting Mesh to Solid : I seriously am at my wits end...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9617&amp;PID=24529&amp;title=converting-mesh-to-solid#24529</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=402531">charbison</a><br /><strong>Subject:</strong> 9617<br /><strong>Posted:</strong> 05.Sep.2013 at 21:37<br /><br />I seriously am at my wits end on this.... I have several 3D moulding files that are currently meshes of 30k polylines, so they are complicated and busy files. &nbsp;I need to be able to slice, dice, and make unions with just part of the mesh to another 3D solid. &nbsp;I have yet to figure out a way to do this. &nbsp;I can make the shape a surface and slice everything off that I don't need, but I need to find a way to make the leaves a solid so I can add it to another moulding profile. &nbsp;I tried the new polyhedral mesh to solid app and it did not work. &nbsp;I have CAD2010 and currently have 28 days left on trial of 2014.... Thanks! &nbsp;The file is too big to attach, so please go to this page and download the 3D Cad File for the CM8820....<div><br></div><div><a href="http://shop.whiteriver.com/p/2-3-4-x-13-16-petite-acanthus-leaf-repeats-2-7-8" target="_blank" rel="nofollow">http://shop.whiteriver.com/p/2-3-4-x-13-16-petite-acanthus-leaf-repeats-2-7-8</a></div><div><br></div>]]>
   <pubDate>Thu, 05 Sep 2013 21:37:51 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9617&amp;PID=24529&amp;title=converting-mesh-to-solid#24529</guid>
