  <title>CAD Forum discussion (EN) : Fabrication Detailing in Revit</title>
  <description><![CDATA[This is an XML content feed of; CAD Forum discussion (EN) : Revit : Fabrication Detailing in Revit]]></description>
  <pubDate>Sun, 10 May 2026 04:11:31 +0000</pubDate>
  <lastBuildDate>Mon, 26 May 2014 14:18:12 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum_en/RSS_post_feed.asp?TID=9621</WebWizForums:feedURL>
   <title><![CDATA[Fabrication Detailing in Revit :  No, you can use the AutoCAD...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9621&amp;PID=27221&amp;title=fabrication-detailing-in-revit#27221</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=3">Vladimir Michl</a><br /><strong>Subject:</strong> 9621<br /><strong>Posted:</strong> 26.May.2014 at 14:18<br /><br />No, you can use the AutoCAD forum for AutoCAD SD questions.<div>&nbsp;</div><div>As for fabrication - Autodesk has a whole family of fabrication tools - see Autodesk Fabrication at:</div><div><a href="http://www.autodesk.com/products/fabrication-products/overview" target="_blank" rel="nofollow">http://www.autodesk.com/products/fabrication-products/overview</a></div>]]>
   <pubDate>Mon, 26 May 2014 14:18:12 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9621&amp;PID=27221&amp;title=fabrication-detailing-in-revit#27221</guid>
   <title><![CDATA[Fabrication Detailing in Revit :  It has also Autocad Structural...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9621&amp;PID=27212&amp;title=fabrication-detailing-in-revit#27212</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=474068">Daroit</a><br /><strong>Subject:</strong> 9621<br /><strong>Posted:</strong> 24.May.2014 at 00:01<br /><br /><span ="hps">It has</span> <span ="hps">also</span> <span ="hps">Autocad</span> <span ="hps">Structural Detailing</span><span>.</span> <span ="hps">Have a</span> <span ="hps">topic</span> <span ="hps">in</span> <span ="hps">CAD</span> <span ="hps">â€‹â€‹FĂłrum</span><span>?</span>]]>
   <pubDate>Sat, 24 May 2014 00:01:39 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9621&amp;PID=27212&amp;title=fabrication-detailing-in-revit#27212</guid>
   <title><![CDATA[Fabrication Detailing in Revit : I&amp;#039;d add Inventor to the list...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9621&amp;PID=25451&amp;title=fabrication-detailing-in-revit#25451</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=165260">John Connor</a><br /><strong>Subject:</strong> 9621<br /><strong>Posted:</strong> 12.Dec.2013 at 18:06<br /><br />I'd add Inventor to the list too.<br>]]>
   <pubDate>Thu, 12 Dec 2013 18:06:00 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9621&amp;PID=25451&amp;title=fabrication-detailing-in-revit#25451</guid>
   <title><![CDATA[Fabrication Detailing in Revit : yes, Autocad mep ]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9621&amp;PID=25450&amp;title=fabrication-detailing-in-revit#25450</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=428532">Varghesejoy</a><br /><strong>Subject:</strong> 9621<br /><strong>Posted:</strong> 12.Dec.2013 at 17:54<br /><br />yes, Autocad mep<div><br></div>]]>
   <pubDate>Thu, 12 Dec 2013 17:54:43 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9621&amp;PID=25450&amp;title=fabrication-detailing-in-revit#25450</guid>
   <title><![CDATA[Fabrication Detailing in Revit : Anyone knows if fabrication detailing...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9621&amp;PID=24545&amp;title=fabrication-detailing-in-revit#24545</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=394955">3dbim</a><br /><strong>Subject:</strong> 9621<br /><strong>Posted:</strong> 07.Sep.2013 at 09:51<br /><br />Anyone knows if fabrication detailing can be done in Revit? Which other software enables it?]]>
   <pubDate>Sat, 07 Sep 2013 09:51:14 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9621&amp;PID=24545&amp;title=fabrication-detailing-in-revit#24545</guid>
