  <title>CAD Forum discussion (EN) : Parameters in Block Definition</title>
  <description><![CDATA[This is an XML content feed of; CAD Forum discussion (EN) : AutoCAD : Parameters in Block Definition]]></description>
  <pubDate>Thu, 22 Oct 2026 08:18:02 +0000</pubDate>
  <lastBuildDate>Wed, 11 Sep 2013 10:13:27 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum_en/RSS_post_feed.asp?TID=9633</WebWizForums:feedURL>
   <title><![CDATA[Parameters in Block Definition :  Hey everyone,So I have a question...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9633&amp;PID=24587&amp;title=parameters-in-block-definition#24587</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=66884">PhAntoMAMD</a><br /><strong>Subject:</strong> 9633<br /><strong>Posted:</strong> 11.Sep.2013 at 10:13<br /><br /><font size="2">Hey everyone,<br><br>So I have a question regarding parameters in a block definition, or more specifically how to constrain parameters. I have attached a PDF showing exactly what I am working on. Basically I have an arm for a monitor which I need to add some parameters to. I need to be able to have a point that I can grab where the "primary grab" is located, and when I grab that I need the arm to pivot at the indicated pivot point, but be restrained by the first arm that is constrained to the circle. Is this possible to do in AutoCAD?<br><br>Hopefully that makes sense, and really hope that someone can help me out here!<a href="uploads/66884/Parameter_Example.pdf" target="_blank" rel="nofollow">uploads/66884/Parameter_Example.pdf</a></font>]]>
   <pubDate>Wed, 11 Sep 2013 10:13:27 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9633&amp;PID=24587&amp;title=parameters-in-block-definition#24587</guid>
