  <title>CAD Forum discussion (EN) : NOTHING APPEARING</title>
  <description><![CDATA[This is an XML content feed of; CAD Forum discussion (EN) : AutoCAD : NOTHING APPEARING]]></description>
  <pubDate>Wed, 28 Oct 2026 13:11:09 +0000</pubDate>
  <lastBuildDate>Mon, 16 Sep 2013 11:41:20 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum_en/RSS_post_feed.asp?TID=9642</WebWizForums:feedURL>
   <title><![CDATA[NOTHING APPEARING : If you do not see your whole drawing...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9642&amp;PID=24627&amp;title=nothing-appearing#24627</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=165260">John Connor</a><br /><strong>Subject:</strong> 9642<br /><strong>Posted:</strong> 16.Sep.2013 at 11:41<br /><br />If you do not see your whole drawing while working in model space do a Zoom &gt; All or a Zoom &gt; Extents.&nbsp; Now do you see the whole drawing?<br><br>Purging a drawing eliminates unreferenced objects such as linetypes, multileaders, layers, etc.&nbsp; To do this one must use the PURGE command.&nbsp; There are two versions of the command.&nbsp; The first is PURGE and it will bring up a dialog box.&nbsp; The second is the command line version -PURGE (notice the dash?).&nbsp; I recommend using the second version and first purging REGAPPS.&nbsp; Then repeat the command and do a Purge &gt; All.<br><br>Audit is a command used to check the drawing database for errors.&nbsp; This is usually run after one has purged a drawing.<br><br>It seems there is a whole lot about AutoCAD that you do not know.&nbsp; Is there a CAD Manager?<br><br>If you are not seeing a dialog box when it comes to saving your drawing then maybe the system variable FILEDIA has been set to "0" instead of "1".&nbsp; I would check if I were you.&nbsp; Type FILEDIA at the command line and AutoCAD will report what the setting is.&nbsp; Change it if necessary.<br><br>Is there any chance you are working in a paper space layout using viewports?<br><br>If all else fails you may have to run the REPAIR option.<br>]]>
   <pubDate>Mon, 16 Sep 2013 11:41:20 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9642&amp;PID=24627&amp;title=nothing-appearing#24627</guid>
   <title><![CDATA[NOTHING APPEARING : Almost all the drawings i work...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9642&amp;PID=24625&amp;title=nothing-appearing#24625</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=402811">jaggy2013</a><br /><strong>Subject:</strong> 9642<br /><strong>Posted:</strong> 15.Sep.2013 at 21:33<br /><br />Almost all the drawings i work on AUTOCAD'13.<div><br></div><div>No idea abt second point, as i am basic learner and dunno how to check too. .</div><div><br></div><div>No i didn't use the command as you mentioned.</div><div><br></div><div>Nope, What is meant by purge. I havn't go through basic yet now.</div><div><br></div><div>No idea about scale list bloat ? Can you clearly explain abt this?</div><div><br></div><div>No, But it seems some updation done from my admin side,</div><div><br></div><div>No.</div><div><br></div><div>And other colleague Working on 2011, and she has the same problem,</div><div><br></div><div>I'm using '14 now, so far nothing happened like before.</div><div><br></div><div>BUT MOSTLY HAPPENED DURING WHEN I AM ERASING SOMETHING. . &nbsp;BUT AM SURE I AM SELECTING THE PARTICULAR THING AND ERASING.</div><div><br></div><div><br></div>]]>
   <pubDate>Sun, 15 Sep 2013 21:33:19 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9642&amp;PID=24625&amp;title=nothing-appearing#24625</guid>
   <title><![CDATA[NOTHING APPEARING : Yes, When i am doing some modifications...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9642&amp;PID=24624&amp;title=nothing-appearing#24624</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=402811">jaggy2013</a><br /><strong>Subject:</strong> 9642<br /><strong>Posted:</strong> 15.Sep.2013 at 21:26<br /><br />Yes, When i am doing some modifications (Mostly erasing something) the whole drawing is not visible on my drawing.<div><br></div><div>Yeah, after diagram and i didn't try to save, But, Usually it will ask to save rite ???</div><div><br></div><div>No dialogue box and yeah can see " REGENERATING MODEL, DRAWING IS BUSY" NOthing else, and i work on AUTOCAD'13 during this happened. . .</div><div><br></div><div>Gimmie some ideas inorder to save my time, every tym i use to edit 5-6 tym's :( i feel pity of myself.</div>]]>
   <pubDate>Sun, 15 Sep 2013 21:26:27 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9642&amp;PID=24624&amp;title=nothing-appearing#24624</guid>
   <title><![CDATA[NOTHING APPEARING : Is this happening in every drawing...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9642&amp;PID=24619&amp;title=nothing-appearing#24619</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=35918">heinsite</a><br /><strong>Subject:</strong> 9642<br /><strong>Posted:</strong> 15.Sep.2013 at 00:55<br /><br />Is this happening in every drawing you work on, or just a particular one?<br><br>By any chance is your version of AutoCAD 2013 on Subscription?&nbsp; If so, why not update it to 2014?&nbsp; But if not, are you certain you have installed all available Service Packs and Hotfixes for it?&nbsp; Check your installation and then go <a href="http://usa.autodesk.com/adsk/servlet/ps/dl/index?siteID=123112&amp;id=2334435&amp;linkID=9240618#section2" target="_blank" rel="nofollow">HERE</a> to check and download files as needed.<br><br>Have you run an AUDIT on the file you're working on?<br><br>Have you PURGEd the file recently?<br><br>Do you have scale list bloat?<br><br>Have you recently installed new virus protection software?<br><br>Have you recently run any type of Registry cleaner?<br><br>You have an unusual problem that may be difficult to trouble shoot.&nbsp; If all else fails you could try and see if this is unique to your computer or if it happens on another.&nbsp; If it's just happening on your machine, then it's probably something to do with your version of AutoCAD.&nbsp; If it happens with this file on another computer then there's likely something wrong with the file.<br><br>You need to do a bit more hunting and get back to us.<br><br>Dave.<br><span style="font-size:10px"><br /><br />Edited by heinsite - 15.Sep.2013 at 00:56</span>]]>
   <pubDate>Sun, 15 Sep 2013 00:55:00 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9642&amp;PID=24619&amp;title=nothing-appearing#24619</guid>
   <title><![CDATA[NOTHING APPEARING : You edit a drawing, go to close...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9642&amp;PID=24615&amp;title=nothing-appearing#24615</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=165260">John Connor</a><br /><strong>Subject:</strong> 9642<br /><strong>Posted:</strong> 14.Sep.2013 at 23:12<br /><br />You edit a drawing, go to close it and AutoCAD doesn't even ask if you want to save it?&nbsp; That sounds serious.<br><br>When did this first start happening?<br><br>Does a dialog box appear onscreen?&nbsp; If "no" do you see anything on the command line itself?<br><br><span style="font-size:10px"><br /><br />Edited by John Connor - 14.Sep.2013 at 23:14</span>]]>
   <pubDate>Sat, 14 Sep 2013 23:12:38 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9642&amp;PID=24615&amp;title=nothing-appearing#24615</guid>
   <title><![CDATA[NOTHING APPEARING : Hello my dears&amp;#039;I am facing...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9642&amp;PID=24614&amp;title=nothing-appearing#24614</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=402811">jaggy2013</a><br /><strong>Subject:</strong> 9642<br /><strong>Posted:</strong> 14.Sep.2013 at 20:52<br /><br />Hello my dears'<div><br></div><div>I am facing problem with some toughest problem, Do help me dears,</div><div><br></div><div>When i am doing some thing on client drawings(eg, copy, paste, delete) after some time " Nothing is appearing on my drawing and its responds" REGENERATING MODEL, DRAWING IS BUSY" and when i use to cloase the drawing (Usually it will ask save "Yes" or "No" rite ?) But it doesn't ask.&nbsp;</div><div><br></div><div>When i close the drawing nothing asking either to save or something. PLease help me what i have to do ?</div><div><br></div><div>I use to do modifications and after sometime nothing is there in drawings, Frequently its happening to me,</div>]]>
   <pubDate>Sat, 14 Sep 2013 20:52:47 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9642&amp;PID=24614&amp;title=nothing-appearing#24614</guid>
