  <title>CAD Forum discussion (EN) : Publishing</title>
  <description><![CDATA[This is an XML content feed of; CAD Forum discussion (EN) : AutoCAD : Publishing]]></description>
  <pubDate>Mon, 07 Sep 2026 19:14:55 +0000</pubDate>
  <lastBuildDate>Tue, 17 Sep 2013 06:44:50 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum_en/RSS_post_feed.asp?TID=9646</WebWizForums:feedURL>
   <title><![CDATA[Publishing : What is your publishing/plotting...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9646&amp;PID=24642&amp;title=publishing#24642</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=35918">heinsite</a><br /><strong>Subject:</strong> 9646<br /><strong>Posted:</strong> 17.Sep.2013 at 06:44<br /><br />What is your publishing/plotting workflow?&nbsp; Let's start there.&nbsp; Describe as carefully as you can what it is you've been doing.<br><br>Dave.<br>]]>
   <pubDate>Tue, 17 Sep 2013 06:44:50 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9646&amp;PID=24642&amp;title=publishing#24642</guid>
   <title><![CDATA[Publishing :  All quick update just tried...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9646&amp;PID=24632&amp;title=publishing#24632</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=173925">psgbs1</a><br /><strong>Subject:</strong> 9646<br /><strong>Posted:</strong> 16.Sep.2013 at 13:02<br /><br />All quick update just tried the same thing on a colleagues PC who is running 2013 LT and it has worked without a problem, could this be a PC issue or a 2012 issue???]]>
   <pubDate>Mon, 16 Sep 2013 13:02:21 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9646&amp;PID=24632&amp;title=publishing#24632</guid>
   <title><![CDATA[Publishing :  Please help me, I am using AutoCAD...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9646&amp;PID=24630&amp;title=publishing#24630</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=173925">psgbs1</a><br /><strong>Subject:</strong> 9646<br /><strong>Posted:</strong> 16.Sep.2013 at 12:21<br /><br />Please help me, I am using AutoCAD 2012 full version and I have a number of tabs set up (381 to be exact) I want to publish a range of tabs all with the same page set up i.e. DWG to PDF. I can print each tab off individually with no problem but when I try to publish a range of tabs the software just site there hanging without doing anything. <div>I have left it overnight just in case it was a speed thing but on return to the office nothing has happened.</div><div>&nbsp;</div><div>I have ensured the plot set up in publishing is to the directory of my choosing so it is not like it is printing them off to a different directory either.</div><div>&nbsp;</div><div>On the progress bar in the bottom right of the screen the publishing command it running but is always stuck on 1 of 12 or 1 of however many tabs I am trying to publish.</div><div>&nbsp;</div><div>Any ideas as to what I may be doing wrong would be greatly appreciated.</div><div>&nbsp;</div><div>&nbsp;</div>]]>
   <pubDate>Mon, 16 Sep 2013 12:21:16 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9646&amp;PID=24630&amp;title=publishing#24630</guid>
