  <title>CAD Forum discussion (EN) : AutoDesk HW problem</title>
  <description><![CDATA[This is an XML content feed of; CAD Forum discussion (EN) : AutoCAD : AutoDesk HW problem]]></description>
  <pubDate>Sat, 05 Sep 2026 04:47:06 +0000</pubDate>
  <lastBuildDate>Wed, 25 Sep 2013 16:40:27 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum_en/RSS_post_feed.asp?TID=9668</WebWizForums:feedURL>
   <title><![CDATA[AutoDesk HW problem : oh my gosh, i try both of your...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9668&amp;PID=24710&amp;title=autodesk-hw-problem#24710</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=405868">GoplerGop</a><br /><strong>Subject:</strong> 9668<br /><strong>Posted:</strong> 25.Sep.2013 at 16:40<br /><br />oh my gosh, i try both of your methods and then after a moment of truth, yes it work. it work. Is this some kind of math illusion..?<div><br></div><div>i receive like 100 gigabyte of help from you guys</div><div><br></div><div>thx&nbsp;</div>]]>
   <pubDate>Wed, 25 Sep 2013 16:40:27 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9668&amp;PID=24710&amp;title=autodesk-hw-problem#24710</guid>
   <title><![CDATA[AutoDesk HW problem : That will be affected by what...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9668&amp;PID=24705&amp;title=autodesk-hw-problem#24705</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=353260">Kent Cooper</a><br /><strong>Subject:</strong> 9668<br /><strong>Posted:</strong> 25.Sep.2013 at 14:32<br /><br /><P>That will be affected by what you use as the base point for the rotation.&nbsp; If starting at the center-line position, you would need to know the point at which the 36-degree-angle Lines would (virtually) intersect in order to get the right result using Rotate.&nbsp; In that situation, I would draw Lines vertically from the <EM>quadrant points</EM> of the Circle, and Rotate&nbsp;each 18 degrees one way or the other, using the <EM>center</EM> of the Circle as the rotation base point.</P>]]>
   <pubDate>Wed, 25 Sep 2013 14:32:55 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9668&amp;PID=24705&amp;title=autodesk-hw-problem#24705</guid>
   <title><![CDATA[AutoDesk HW problem : First. Are you aware that the...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9668&amp;PID=24692&amp;title=autodesk-hw-problem#24692</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=165260">John Connor</a><br /><strong>Subject:</strong> 9668<br /><strong>Posted:</strong> 24.Sep.2013 at 23:45<br /><br />First.&nbsp; Are you aware that the default setting for AutoCAD measures angles in a counter-clockwise direction and East happens to be angle zero?<br><br>Second.&nbsp; Are you familiar with direct distance entry at the command line?&nbsp; If I wanted to draw a line 20 units long at a 45 degree angle I would start the line command, pick my start point then type @20&lt;45.<br><br>Third.&nbsp; Are you familiar with Polar Tracking or with the SNAPANG command.&nbsp; Both are other ways to accomplish the same task.<br>]]>
   <pubDate>Tue, 24 Sep 2013 23:45:38 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9668&amp;PID=24692&amp;title=autodesk-hw-problem#24692</guid>
   <title><![CDATA[AutoDesk HW problem : Hi Guys, thx for the previous...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9668&amp;PID=24691&amp;title=autodesk-hw-problem#24691</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=405868">GoplerGop</a><br /><strong>Subject:</strong> 9668<br /><strong>Posted:</strong> 24.Sep.2013 at 21:59<br /><br />Hi Guys, thx for the previous help<div><br></div><div><br></div><div>So far I learned, line, offset, circle, xline and rotate.</div><div><br></div><div>I don't know how to get "left and right slopes" with 36 degree. My approach was to think them as triangle with 36 degree. So I extend central line and rotate 18 degree to left and right, but it was wrong.&nbsp;</div><div><br></div><div>please give me help and tips</div><div><br></div><div>thank you so much&nbsp;</div><div><br></div><div>Gary</div><div><br></div><div><img src="uploads/405868/Problem_2.png" height="508" width="536" border="0" />ficult with</div>]]>
   <pubDate>Tue, 24 Sep 2013 21:59:04 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9668&amp;PID=24691&amp;title=autodesk-hw-problem#24691</guid>
