  <title>CAD Forum discussion (EN) : text block automatsche</title>
  <description><![CDATA[This is an XML content feed of; CAD Forum discussion (EN) : AutoCAD : text block automatsche]]></description>
  <pubDate>Tue, 16 Jun 2026 22:08:52 +0000</pubDate>
  <lastBuildDate>Sat, 12 Oct 2013 12:50:28 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum_en/RSS_post_feed.asp?TID=9716</WebWizForums:feedURL>
   <title><![CDATA[text block automatsche : Are you looking for a custom lisp...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9716&amp;PID=24873&amp;title=text-block-automatsche#24873</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=165260">John Connor</a><br /><strong>Subject:</strong> 9716<br /><strong>Posted:</strong> 12.Oct.2013 at 12:50<br /><br />Are you looking for a custom lisp program?<br><br>Are these base walls going to be blocks?&nbsp; If so will they be regular blocks or dynamic blocks?<br><br>]]>
   <pubDate>Sat, 12 Oct 2013 12:50:28 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9716&amp;PID=24873&amp;title=text-block-automatsche#24873</guid>
   <title><![CDATA[text block automatsche : Hello fellow users, I must draw...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9716&amp;PID=24870&amp;title=text-block-automatsche#24870</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=90355">pytha</a><br /><strong>Subject:</strong> 9716<br /><strong>Posted:</strong> 12.Oct.2013 at 09:07<br /><br /><p><span ="hps">Hello fellow</span> <span ="hps">users</span><span>,</span><br><br> <span ="hps">I must</span> <span ="hps">draw</span> <span ="hps">base walls</span> <span ="hps">with a</span> <span ="hps">number</span> <span ="hps alt-edited">for example</span> <span ="hps">2010 2011 2012</span><br> <span ="hps">If</span> <span ="hps">a panel</span> <span ="hps">is</span> <span ="hps">to</span> <span ="hps">be</span> <span ="hps">removed</span> <span ="hps">or</span><br> <span ="hps">I must</span> <span ="hps">start</span> <span ="hps">with</span> <span ="hps">new</span> <span ="hps alt-edited">number</span><span>.</span><br> <span ="hps">this can not</span> <span ="hps">automatsche</span><span>.</p><div></div>groet Bart</span>]]>
   <pubDate>Sat, 12 Oct 2013 09:07:31 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=9716&amp;PID=24870&amp;title=text-block-automatsche#24870</guid>
